RTEMS 6.2
irq_asm.h
1
7/* irq_asm.h
8 *
9 * This include file has defines to represent some contant used
10 * to program and manage the Intel 8259 interrupt controller
11 *
12 *
13 * COPYRIGHT (c) 1998 valette@crf.canon.fr
14 *
15 * Copyright (c) 2016 Chris Johns <chrisj@rtems.org>
16 *
17 * The license and distribution terms for this file may be
18 * found in the file LICENSE in this distribution or at
19 * http://www.rtems.org/license/LICENSE.
20 */
21#ifndef __I8259S_H__
22#define __I8259S_H__
23
24#define BSP_ASM_IRQ_VECTOR_BASE 0x20
26#define PIC_MASTER_COMMAND_IO_PORT 0x20
27#define PIC_SLAVE_COMMAND_IO_PORT 0xa0
28#define PIC_MASTER_IMR_IO_PORT 0x21
29#define PIC_SLAVE_IMR_IO_PORT 0xa1
30
32#define PIC_EOSI 0x60
33#define PIC_EOI 0x20
34
35/* Operation control word type 3. Bit 3 (0x08) must be set. Even address. */
36#define PIC_OCW3_RIS 0x01 /* 1 = read IS, 0 = read IR */
37#define PIC_OCW3_RR 0x02 /* register read */
38#define PIC_OCW3_P 0x04 /* poll mode command */
39/* 0x08 must be 1 to select OCW3 vs OCW2 */
40#define PIC_OCW3_SEL 0x08 /* must be 1 */
41/* 0x10 must be 0 to select OCW3 vs ICW1 */
42#define PIC_OCW3_SMM 0x20 /* special mode mask */
43#define PIC_OCW3_ESMM 0x40 /* enable SMM */
44
45#endif
