RTEMS 6.2
tm27.h
1
9/*
10 * tm27.h
11 *
12 * The license and distribution terms for this file may be
13 * found in the file LICENSE in this distribution or at
14 * http://www.rtems.org/license/LICENSE.
15 */
16
17#ifndef _RTEMS_TMTEST27
18#error "This is an RTEMS internal file you must not include directly."
19#endif
20
21#ifndef __tm27_h
22#define __tm27_h
23
24/*
25 * Define the interrupt mechanism for Time Test 27
26 */
27
28#define MUST_WAIT_FOR_INTERRUPT 0
29
30#define Install_tm27_vector(handler) (void) handler
31
32#define Cause_tm27_intr() __asm__ volatile("int $0x90" : :);
33
34#define Clear_tm27_intr() /* empty */
35
36#define Lower_tm27_intr() /* empty */
37
38#endif
