RTEMS 6.2
This header file defines the GRSPW2 register block interface. More...
#include <stdint.h>Go to the source code of this file.
| struct | grspw2_dma |
| This structure defines the GRSPW2 DMA register block memory map. More... | |
| struct | grspw2 |
| This structure defines the GRSPW2 register block memory map. More... | |
| #define | GRSPW2_DMACTRL_INTNUM_SHIFT 26 |
| #define | GRSPW2_DMACTRL_INTNUM_MASK 0xfc000000U |
| #define | GRSPW2_DMACTRL_INTNUM_GET(_reg) |
| #define | GRSPW2_DMACTRL_INTNUM_SET(_reg, _val) |
| #define | GRSPW2_DMACTRL_INTNUM(_val) |
| #define | GRSPW2_DMACTRL_RES_SHIFT 24 |
| #define | GRSPW2_DMACTRL_RES_MASK 0x3000000U |
| #define | GRSPW2_DMACTRL_RES_GET(_reg) |
| #define | GRSPW2_DMACTRL_RES_SET(_reg, _val) |
| #define | GRSPW2_DMACTRL_RES(_val) |
| #define | GRSPW2_DMACTRL_EP 0x800000U |
| #define | GRSPW2_DMACTRL_TR 0x400000U |
| #define | GRSPW2_DMACTRL_IE 0x200000U |
| #define | GRSPW2_DMACTRL_IT 0x100000U |
| #define | GRSPW2_DMACTRL_RP 0x80000U |
| #define | GRSPW2_DMACTRL_TP 0x40000U |
| #define | GRSPW2_DMACTRL_TL 0x20000U |
| #define | GRSPW2_DMACTRL_LE 0x10000U |
| #define | GRSPW2_DMACTRL_SP 0x8000U |
| #define | GRSPW2_DMACTRL_SA 0x4000U |
| #define | GRSPW2_DMACTRL_EN 0x2000U |
| #define | GRSPW2_DMACTRL_NS 0x1000U |
| #define | GRSPW2_DMACTRL_RD 0x800U |
| #define | GRSPW2_DMACTRL_RX 0x400U |
| #define | GRSPW2_DMACTRL_AT 0x200U |
| #define | GRSPW2_DMACTRL_RA 0x100U |
| #define | GRSPW2_DMACTRL_TA 0x80U |
| #define | GRSPW2_DMACTRL_PR 0x40U |
| #define | GRSPW2_DMACTRL_PS 0x20U |
| #define | GRSPW2_DMACTRL_AI 0x10U |
| #define | GRSPW2_DMACTRL_RI 0x8U |
| #define | GRSPW2_DMACTRL_TI 0x4U |
| #define | GRSPW2_DMACTRL_RE 0x2U |
| #define | GRSPW2_DMACTRL_TE 0x1U |
| #define | GRSPW2_DMAMAXLEN_RXMAXLEN_SHIFT 2 |
| #define | GRSPW2_DMAMAXLEN_RXMAXLEN_MASK 0x1fffffcU |
| #define | GRSPW2_DMAMAXLEN_RXMAXLEN_GET(_reg) |
| #define | GRSPW2_DMAMAXLEN_RXMAXLEN_SET(_reg, _val) |
| #define | GRSPW2_DMAMAXLEN_RXMAXLEN(_val) |
| #define | GRSPW2_DMAMAXLEN_RES_SHIFT 0 |
| #define | GRSPW2_DMAMAXLEN_RES_MASK 0x3U |
| #define | GRSPW2_DMAMAXLEN_RES_GET(_reg) |
| #define | GRSPW2_DMAMAXLEN_RES_SET(_reg, _val) |
| #define | GRSPW2_DMAMAXLEN_RES(_val) |
| #define | GRSPW2_DMATXDESC_DESCBASEADDR_SHIFT 0 |
| #define | GRSPW2_DMATXDESC_DESCBASEADDR_MASK 0xffffffffU |
| #define | GRSPW2_DMATXDESC_DESCBASEADDR_GET(_reg) |
| #define | GRSPW2_DMATXDESC_DESCBASEADDR_SET(_reg, _val) |
| #define | GRSPW2_DMATXDESC_DESCBASEADDR(_val) |
| #define | GRSPW2_DMATXDESC_DESCSEL_SHIFT 4 |
| #define | GRSPW2_DMATXDESC_DESCSEL_MASK 0xfffffff0U |
| #define | GRSPW2_DMATXDESC_DESCSEL_GET(_reg) |
| #define | GRSPW2_DMATXDESC_DESCSEL_SET(_reg, _val) |
| #define | GRSPW2_DMATXDESC_DESCSEL(_val) |
| #define | GRSPW2_DMARXDESC_DESCBASEADDR_SHIFT 10 |
| #define | GRSPW2_DMARXDESC_DESCBASEADDR_MASK 0xfffffc00U |
| #define | GRSPW2_DMARXDESC_DESCBASEADDR_GET(_reg) |
| #define | GRSPW2_DMARXDESC_DESCBASEADDR_SET(_reg, _val) |
| #define | GRSPW2_DMARXDESC_DESCBASEADDR(_val) |
| #define | GRSPW2_DMARXDESC_DESCSEL_SHIFT 3 |
| #define | GRSPW2_DMARXDESC_DESCSEL_MASK 0x3f8U |
| #define | GRSPW2_DMARXDESC_DESCSEL_GET(_reg) |
| #define | GRSPW2_DMARXDESC_DESCSEL_SET(_reg, _val) |
| #define | GRSPW2_DMARXDESC_DESCSEL(_val) |
| #define | GRSPW2_DMAADDR_MASK_SHIFT 8 |
| #define | GRSPW2_DMAADDR_MASK_MASK 0xff00U |
| #define | GRSPW2_DMAADDR_MASK_GET(_reg) |
| #define | GRSPW2_DMAADDR_MASK_SET(_reg, _val) |
| #define | GRSPW2_DMAADDR_MASK(_val) |
| #define | GRSPW2_DMAADDR_ADDR_SHIFT 0 |
| #define | GRSPW2_DMAADDR_ADDR_MASK 0xffU |
| #define | GRSPW2_DMAADDR_ADDR_GET(_reg) |
| #define | GRSPW2_DMAADDR_ADDR_SET(_reg, _val) |
| #define | GRSPW2_DMAADDR_ADDR(_val) |
| #define | GRSPW2_CTRL_RA 0x80000000U |
| #define | GRSPW2_CTRL_RX 0x40000000U |
| #define | GRSPW2_CTRL_RC 0x20000000U |
| #define | GRSPW2_CTRL_NCH_SHIFT 27 |
| #define | GRSPW2_CTRL_NCH_MASK 0x18000000U |
| #define | GRSPW2_CTRL_NCH_GET(_reg) |
| #define | GRSPW2_CTRL_NCH_SET(_reg, _val) |
| #define | GRSPW2_CTRL_NCH(_val) |
| #define | GRSPW2_CTRL_PO 0x4000000U |
| #define | GRSPW2_CTRL_CC 0x2000000U |
| #define | GRSPW2_CTRL_ID 0x1000000U |
| #define | GRSPW2_CTRL_R 0x800000U |
| #define | GRSPW2_CTRL_LE 0x400000U |
| #define | GRSPW2_CTRL_PS 0x200000U |
| #define | GRSPW2_CTRL_NP 0x100000U |
| #define | GRSPW2_CTRL_PNPA_SHIFT 18 |
| #define | GRSPW2_CTRL_PNPA_MASK 0xc0000U |
| #define | GRSPW2_CTRL_PNPA_GET(_reg) |
| #define | GRSPW2_CTRL_PNPA_SET(_reg, _val) |
| #define | GRSPW2_CTRL_PNPA(_val) |
| #define | GRSPW2_CTRL_RD 0x20000U |
| #define | GRSPW2_CTRL_RE 0x10000U |
| #define | GRSPW2_CTRL_PE 0x8000U |
| #define | GRSPW2_CTRL_R 0x4000U |
| #define | GRSPW2_CTRL_TL 0x2000U |
| #define | GRSPW2_CTRL_TF 0x1000U |
| #define | GRSPW2_CTRL_TR 0x800U |
| #define | GRSPW2_CTRL_TT 0x400U |
| #define | GRSPW2_CTRL_LI 0x200U |
| #define | GRSPW2_CTRL_TQ 0x100U |
| #define | GRSPW2_CTRL_R 0x80U |
| #define | GRSPW2_CTRL_RS 0x40U |
| #define | GRSPW2_CTRL_PM 0x20U |
| #define | GRSPW2_CTRL_TI 0x10U |
| #define | GRSPW2_CTRL_IE 0x8U |
| #define | GRSPW2_CTRL_AS 0x4U |
| #define | GRSPW2_CTRL_LS 0x2U |
| #define | GRSPW2_CTRL_LD 0x1U |
| #define | GRSPW2_STS_NRXD_SHIFT 26 |
| #define | GRSPW2_STS_NRXD_MASK 0xc000000U |
| #define | GRSPW2_STS_NRXD_GET(_reg) |
| #define | GRSPW2_STS_NRXD_SET(_reg, _val) |
| #define | GRSPW2_STS_NRXD(_val) |
| #define | GRSPW2_STS_NTXD 0x2000000U |
| #define | GRSPW2_STS_LS_SHIFT 21 |
| #define | GRSPW2_STS_LS_MASK 0xe00000U |
| #define | GRSPW2_STS_LS_GET(_reg) |
| #define | GRSPW2_STS_LS_SET(_reg, _val) |
| #define | GRSPW2_STS_LS(_val) |
| #define | GRSPW2_STS_AP 0x200U |
| #define | GRSPW2_STS_EE 0x100U |
| #define | GRSPW2_STS_IA 0x80U |
| #define | GRSPW2_STS_RES_SHIFT 5 |
| #define | GRSPW2_STS_RES_MASK 0x60U |
| #define | GRSPW2_STS_RES_GET(_reg) |
| #define | GRSPW2_STS_RES_SET(_reg, _val) |
| #define | GRSPW2_STS_RES(_val) |
| #define | GRSPW2_STS_PE 0x10U |
| #define | GRSPW2_STS_DE 0x8U |
| #define | GRSPW2_STS_ER 0x4U |
| #define | GRSPW2_STS_CE 0x2U |
| #define | GRSPW2_STS_TO 0x1U |
| #define | GRSPW2_DEFADDR_DEFMASK_SHIFT 8 |
| #define | GRSPW2_DEFADDR_DEFMASK_MASK 0xff00U |
| #define | GRSPW2_DEFADDR_DEFMASK_GET(_reg) |
| #define | GRSPW2_DEFADDR_DEFMASK_SET(_reg, _val) |
| #define | GRSPW2_DEFADDR_DEFMASK(_val) |
| #define | GRSPW2_DEFADDR_DEFADDR_SHIFT 0 |
| #define | GRSPW2_DEFADDR_DEFADDR_MASK 0xffU |
| #define | GRSPW2_DEFADDR_DEFADDR_GET(_reg) |
| #define | GRSPW2_DEFADDR_DEFADDR_SET(_reg, _val) |
| #define | GRSPW2_DEFADDR_DEFADDR(_val) |
| #define | GRSPW2_CLKDIV_CLKDIVSTART_SHIFT 8 |
| #define | GRSPW2_CLKDIV_CLKDIVSTART_MASK 0xff00U |
| #define | GRSPW2_CLKDIV_CLKDIVSTART_GET(_reg) |
| #define | GRSPW2_CLKDIV_CLKDIVSTART_SET(_reg, _val) |
| #define | GRSPW2_CLKDIV_CLKDIVSTART(_val) |
| #define | GRSPW2_CLKDIV_CLKDIVRUN_SHIFT 0 |
| #define | GRSPW2_CLKDIV_CLKDIVRUN_MASK 0xffU |
| #define | GRSPW2_CLKDIV_CLKDIVRUN_GET(_reg) |
| #define | GRSPW2_CLKDIV_CLKDIVRUN_SET(_reg, _val) |
| #define | GRSPW2_CLKDIV_CLKDIVRUN(_val) |
| #define | GRSPW2_DKEY_DESTKEY_SHIFT 0 |
| #define | GRSPW2_DKEY_DESTKEY_MASK 0xffU |
| #define | GRSPW2_DKEY_DESTKEY_GET(_reg) |
| #define | GRSPW2_DKEY_DESTKEY_SET(_reg, _val) |
| #define | GRSPW2_DKEY_DESTKEY(_val) |
| #define | GRSPW2_TC_TCTRL_SHIFT 6 |
| #define | GRSPW2_TC_TCTRL_MASK 0xc0U |
| #define | GRSPW2_TC_TCTRL_GET(_reg) |
| #define | GRSPW2_TC_TCTRL_SET(_reg, _val) |
| #define | GRSPW2_TC_TCTRL(_val) |
| #define | GRSPW2_TC_TIMECNT_SHIFT 0 |
| #define | GRSPW2_TC_TIMECNT_MASK 0x3fU |
| #define | GRSPW2_TC_TIMECNT_GET(_reg) |
| #define | GRSPW2_TC_TIMECNT_SET(_reg, _val) |
| #define | GRSPW2_TC_TIMECNT(_val) |
| #define | GRSPW2_INTCTRL_INTNUM_SHIFT 26 |
| #define | GRSPW2_INTCTRL_INTNUM_MASK 0xfc000000U |
| #define | GRSPW2_INTCTRL_INTNUM_GET(_reg) |
| #define | GRSPW2_INTCTRL_INTNUM_SET(_reg, _val) |
| #define | GRSPW2_INTCTRL_INTNUM(_val) |
| #define | GRSPW2_INTCTRL_RS 0x2000000U |
| #define | GRSPW2_INTCTRL_EE 0x1000000U |
| #define | GRSPW2_INTCTRL_IA 0x800000U |
| #define | GRSPW2_INTCTRL_RES 0x2U |
| #define | GRSPW2_INTCTRL_TQ_SHIFT 21 |
| #define | GRSPW2_INTCTRL_TQ_MASK 0x600000U |
| #define | GRSPW2_INTCTRL_TQ_GET(_reg) |
| #define | GRSPW2_INTCTRL_TQ_SET(_reg, _val) |
| #define | GRSPW2_INTCTRL_TQ(_val) |
| #define | GRSPW2_INTCTRL_AQ 0x100000U |
| #define | GRSPW2_INTCTRL_IQ 0x80000U |
| #define | GRSPW2_INTCTRL_RES 0x40000U |
| #define | GRSPW2_INTCTRL_AA_SHIFT 16 |
| #define | GRSPW2_INTCTRL_AA_MASK 0x30000U |
| #define | GRSPW2_INTCTRL_AA_GET(_reg) |
| #define | GRSPW2_INTCTRL_AA_SET(_reg, _val) |
| #define | GRSPW2_INTCTRL_AA(_val) |
| #define | GRSPW2_INTCTRL_AT 0x8000U |
| #define | GRSPW2_INTCTRL_IT 0x4000U |
| #define | GRSPW2_INTCTRL_RES 0x2000U |
| #define | GRSPW2_INTCTRL_ID_SHIFT 8 |
| #define | GRSPW2_INTCTRL_ID_MASK 0x1f00U |
| #define | GRSPW2_INTCTRL_ID_GET(_reg) |
| #define | GRSPW2_INTCTRL_ID_SET(_reg, _val) |
| #define | GRSPW2_INTCTRL_ID(_val) |
| #define | GRSPW2_INTCTRL_II 0x80U |
| #define | GRSPW2_INTCTRL_TXINT 0x40U |
| #define | GRSPW2_INTRX_RXIRQ_SHIFT 0 |
| #define | GRSPW2_INTRX_RXIRQ_MASK 0xffffffffU |
| #define | GRSPW2_INTRX_RXIRQ_GET(_reg) |
| #define | GRSPW2_INTRX_RXIRQ_SET(_reg, _val) |
| #define | GRSPW2_INTRX_RXIRQ(_val) |
| #define | GRSPW2_INTTO_INTTO_SHIFT 0 |
| #define | GRSPW2_INTTO_INTTO_MASK 0xffffffffU |
| #define | GRSPW2_INTTO_INTTO_GET(_reg) |
| #define | GRSPW2_INTTO_INTTO_SET(_reg, _val) |
| #define | GRSPW2_INTTO_INTTO(_val) |
| #define | GRSPW2_INTTOEXT_INTTOEXT_SHIFT 0 |
| #define | GRSPW2_INTTOEXT_INTTOEXT_MASK 0xffffffffU |
| #define | GRSPW2_INTTOEXT_INTTOEXT_GET(_reg) |
| #define | GRSPW2_INTTOEXT_INTTOEXT_SET(_reg, _val) |
| #define | GRSPW2_INTTOEXT_INTTOEXT(_val) |
| #define | GRSPW2_TICKMASK_MASK_SHIFT 0 |
| #define | GRSPW2_TICKMASK_MASK_MASK 0xffffffffU |
| #define | GRSPW2_TICKMASK_MASK_GET(_reg) |
| #define | GRSPW2_TICKMASK_MASK_SET(_reg, _val) |
| #define | GRSPW2_TICKMASK_MASK(_val) |
| #define | GRSPW2_AUTOACK_TICKMASKEXT_AAMASK_SHIFT 0 |
| #define | GRSPW2_AUTOACK_TICKMASKEXT_AAMASK_MASK 0xffffffffU |
| #define | GRSPW2_AUTOACK_TICKMASKEXT_AAMASK_GET(_reg) |
| #define | GRSPW2_AUTOACK_TICKMASKEXT_AAMASK_SET(_reg, _val) |
| #define | GRSPW2_AUTOACK_TICKMASKEXT_AAMASK(_val) |
| #define | GRSPW2_INTCFG_INTNUM3_SHIFT 26 |
| #define | GRSPW2_INTCFG_INTNUM3_MASK 0xfc000000U |
| #define | GRSPW2_INTCFG_INTNUM3_GET(_reg) |
| #define | GRSPW2_INTCFG_INTNUM3_SET(_reg, _val) |
| #define | GRSPW2_INTCFG_INTNUM3(_val) |
| #define | GRSPW2_INTCFG_INTNUM2_SHIFT 20 |
| #define | GRSPW2_INTCFG_INTNUM2_MASK 0x3f00000U |
| #define | GRSPW2_INTCFG_INTNUM2_GET(_reg) |
| #define | GRSPW2_INTCFG_INTNUM2_SET(_reg, _val) |
| #define | GRSPW2_INTCFG_INTNUM2(_val) |
| #define | GRSPW2_INTCFG_INTNUM1_SHIFT 14 |
| #define | GRSPW2_INTCFG_INTNUM1_MASK 0xfc000U |
| #define | GRSPW2_INTCFG_INTNUM1_GET(_reg) |
| #define | GRSPW2_INTCFG_INTNUM1_SET(_reg, _val) |
| #define | GRSPW2_INTCFG_INTNUM1(_val) |
| #define | GRSPW2_INTCFG_INTNUM0_SHIFT 8 |
| #define | GRSPW2_INTCFG_INTNUM0_MASK 0x3f00U |
| #define | GRSPW2_INTCFG_INTNUM0_GET(_reg) |
| #define | GRSPW2_INTCFG_INTNUM0_SET(_reg, _val) |
| #define | GRSPW2_INTCFG_INTNUM0(_val) |
| #define | GRSPW2_INTCFG_NUMINT_SHIFT 4 |
| #define | GRSPW2_INTCFG_NUMINT_MASK 0xf0U |
| #define | GRSPW2_INTCFG_NUMINT_GET(_reg) |
| #define | GRSPW2_INTCFG_NUMINT_SET(_reg, _val) |
| #define | GRSPW2_INTCFG_NUMINT(_val) |
| #define | GRSPW2_INTCFG_PR 0x8U |
| #define | GRSPW2_INTCFG_IR 0x4U |
| #define | GRSPW2_INTCFG_IT 0x2U |
| #define | GRSPW2_INTCFG_EE 0x1U |
| #define | GRSPW2_ISR_ISR_SHIFT 0 |
| #define | GRSPW2_ISR_ISR_MASK 0xffffffffU |
| #define | GRSPW2_ISR_ISR_GET(_reg) |
| #define | GRSPW2_ISR_ISR_SET(_reg, _val) |
| #define | GRSPW2_ISR_ISR(_val) |
| #define | GRSPW2_ISREXT_ISR_SHIFT 0 |
| #define | GRSPW2_ISREXT_ISR_MASK 0xffffffffU |
| #define | GRSPW2_ISREXT_ISR_GET(_reg) |
| #define | GRSPW2_ISREXT_ISR_SET(_reg, _val) |
| #define | GRSPW2_ISREXT_ISR(_val) |
| #define | GRSPW2_PRESCALER_R 0x80000000U |
| #define | GRSPW2_PRESCALER_RL_SHIFT 0 |
| #define | GRSPW2_PRESCALER_RL_MASK 0x7fffffffU |
| #define | GRSPW2_PRESCALER_RL_GET(_reg) |
| #define | GRSPW2_PRESCALER_RL_SET(_reg, _val) |
| #define | GRSPW2_PRESCALER_RL(_val) |
| #define | GRSPW2_ISRTIMER_EN 0x80000000U |
| #define | GRSPW2_ISRTIMER_RL_SHIFT 0 |
| #define | GRSPW2_ISRTIMER_RL_MASK 0x7fffffffU |
| #define | GRSPW2_ISRTIMER_RL_GET(_reg) |
| #define | GRSPW2_ISRTIMER_RL_SET(_reg, _val) |
| #define | GRSPW2_ISRTIMER_RL(_val) |
| #define | GRSPW2_IATIMER_EN 0x80000000U |
| #define | GRSPW2_IATIMER_RL_SHIFT 0 |
| #define | GRSPW2_IATIMER_RL_MASK 0x7fffffffU |
| #define | GRSPW2_IATIMER_RL_GET(_reg) |
| #define | GRSPW2_IATIMER_RL_SET(_reg, _val) |
| #define | GRSPW2_IATIMER_RL(_val) |
| #define | GRSPW2_ICTIMER_EN 0x80000000U |
| #define | GRSPW2_ICTIMER_RL_SHIFT 0 |
| #define | GRSPW2_ICTIMER_RL_MASK 0x7fffffffU |
| #define | GRSPW2_ICTIMER_RL_GET(_reg) |
| #define | GRSPW2_ICTIMER_RL_SET(_reg, _val) |
| #define | GRSPW2_ICTIMER_RL(_val) |
| #define | GRSPW2_PNPVEND_VEND_SHIFT 16 |
| #define | GRSPW2_PNPVEND_VEND_MASK 0xffff0000U |
| #define | GRSPW2_PNPVEND_VEND_GET(_reg) |
| #define | GRSPW2_PNPVEND_VEND_SET(_reg, _val) |
| #define | GRSPW2_PNPVEND_VEND(_val) |
| #define | GRSPW2_PNPVEND_PROD_SHIFT 0 |
| #define | GRSPW2_PNPVEND_PROD_MASK 0xffffU |
| #define | GRSPW2_PNPVEND_PROD_GET(_reg) |
| #define | GRSPW2_PNPVEND_PROD_SET(_reg, _val) |
| #define | GRSPW2_PNPVEND_PROD(_val) |
| #define | GRSPW2_PNPOA0_RA_SHIFT 0 |
| #define | GRSPW2_PNPOA0_RA_MASK 0xffffffffU |
| #define | GRSPW2_PNPOA0_RA_GET(_reg) |
| #define | GRSPW2_PNPOA0_RA_SET(_reg, _val) |
| #define | GRSPW2_PNPOA0_RA(_val) |
| #define | GRSPW2_PNPOA1_RA_SHIFT 0 |
| #define | GRSPW2_PNPOA1_RA_MASK 0xffffffffU |
| #define | GRSPW2_PNPOA1_RA_GET(_reg) |
| #define | GRSPW2_PNPOA1_RA_SET(_reg, _val) |
| #define | GRSPW2_PNPOA1_RA(_val) |
| #define | GRSPW2_PNPOA2_RA_SHIFT 0 |
| #define | GRSPW2_PNPOA2_RA_MASK 0xffffffffU |
| #define | GRSPW2_PNPOA2_RA_GET(_reg) |
| #define | GRSPW2_PNPOA2_RA_SET(_reg, _val) |
| #define | GRSPW2_PNPOA2_RA(_val) |
| #define | GRSPW2_PNPDEVID_DID_SHIFT 0 |
| #define | GRSPW2_PNPDEVID_DID_MASK 0xffffffffU |
| #define | GRSPW2_PNPDEVID_DID_GET(_reg) |
| #define | GRSPW2_PNPDEVID_DID_SET(_reg, _val) |
| #define | GRSPW2_PNPDEVID_DID(_val) |
| #define | GRSPW2_PNPUVEND_VEND_SHIFT 16 |
| #define | GRSPW2_PNPUVEND_VEND_MASK 0xffff0000U |
| #define | GRSPW2_PNPUVEND_VEND_GET(_reg) |
| #define | GRSPW2_PNPUVEND_VEND_SET(_reg, _val) |
| #define | GRSPW2_PNPUVEND_VEND(_val) |
| #define | GRSPW2_PNPUVEND_PROD_SHIFT 0 |
| #define | GRSPW2_PNPUVEND_PROD_MASK 0xffffU |
| #define | GRSPW2_PNPUVEND_PROD_GET(_reg) |
| #define | GRSPW2_PNPUVEND_PROD_SET(_reg, _val) |
| #define | GRSPW2_PNPUVEND_PROD(_val) |
| #define | GRSPW2_PNPUSN_USN_SHIFT 0 |
| #define | GRSPW2_PNPUSN_USN_MASK 0xffffffffU |
| #define | GRSPW2_PNPUSN_USN_GET(_reg) |
| #define | GRSPW2_PNPUSN_USN_SET(_reg, _val) |
| #define | GRSPW2_PNPUSN_USN(_val) |
Typedefs | |
| typedef struct grspw2_dma | grspw2_dma |
| This structure defines the GRSPW2 DMA register block memory map. | |
| typedef struct grspw2 | grspw2 |
| This structure defines the GRSPW2 register block memory map. | |
