RTEMS 6.2
Files | Data Structures | Macros | Functions | Variables
GRSPW Device Driver. More...
file  grspw.h
struct  spw_ioctl_packetsize
struct  spw_ioctl_pkt_send
struct  spw_stats
struct  spw_config
#define SPW_LINKERR_EVENT   RTEMS_EVENT_0
#define GRSPW_PKTSEND_OPTION_HDR_CRC   0x1
#define GRSPW_PKTSEND_OPTION_DATA_CRC   0x2
#define GRSPW_PKTSEND_OPTION_NOCRCLEN(len)   ((len & 0xf) << 8)
#define GRSPW_PKTSEND_OPTION_NOCRCLEN_MASK   0xf00
#define SPACEWIRE_IOCTRL_SET_NODEADDR   1
#define SPACEWIRE_IOCTRL_SET_RXBLOCK   2
#define SPACEWIRE_IOCTRL_SET_DESTKEY   4
#define SPACEWIRE_IOCTRL_SET_CLKDIV   5
#define SPACEWIRE_IOCTRL_SET_TIMER   6
#define SPACEWIRE_IOCTRL_SET_DISCONNECT   7
#define SPACEWIRE_IOCTRL_SET_PROMISCUOUS   8
#define SPACEWIRE_IOCTRL_SET_RMAPEN   9
#define SPACEWIRE_IOCTRL_SET_RMAPBUFDIS   10
#define SPACEWIRE_IOCTRL_SET_CHECK_RMAP   11
#define SPACEWIRE_IOCTRL_SET_RM_PROT_ID   12
#define SPACEWIRE_IOCTRL_SET_TXBLOCK   14
#define SPACEWIRE_IOCTRL_SET_DISABLE_ERR   15
#define SPACEWIRE_IOCTRL_SET_LINK_ERR_IRQ   16
#define SPACEWIRE_IOCTRL_SET_EVENT_ID   17
#define SPACEWIRE_IOCTRL_SET_PACKETSIZE   20
#define SPACEWIRE_IOCTRL_GET_LINK_STATUS   23
#define SPACEWIRE_IOCTRL_GET_CONFIG   25
#define SPACEWIRE_IOCTRL_GET_STATISTICS   26
#define SPACEWIRE_IOCTRL_CLR_STATISTICS   27
#define SPACEWIRE_IOCTRL_SEND   28
#define SPACEWIRE_IOCTRL_LINKDISABLE   29
#define SPACEWIRE_IOCTRL_LINKSTART   30
#define SPACEWIRE_IOCTRL_SET_TXBLOCK_ON_FULL   31
#define SPACEWIRE_IOCTRL_SET_COREFREQ   32
#define SPACEWIRE_IOCTRL_SET_CLKDIVSTART   33
#define SPACEWIRE_IOCTRL_SET_NODEMASK   34
#define SPACEWIRE_IOCTRL_SET_KEEP_SOURCE   35
#define SPACEWIRE_IOCTRL_SET_TCODE_CTRL   36
#define SPACEWIRE_IOCTRL_SET_TCODE   37
#define SPACEWIRE_IOCTRL_GET_TCODE   38
#define SPACEWIRE_IOCTRL_SET_READ_TIMEOUT   39
#define SPACEWIRE_IOCTRL_START   64
#define SPACEWIRE_IOCTRL_STOP   65
#define SPACEWIRE_TCODE_CTRL_IE_MSK   0x001
#define SPACEWIRE_TCODE_CTRL_TT_MSK   0x004
#define SPACEWIRE_TCODE_CTRL_TR_MSK   0x008
#define SPACEWIRE_TCODE_CTRL_IE   0x100
#define SPACEWIRE_TCODE_CTRL_TT   0x400
#define SPACEWIRE_TCODE_CTRL_TR   0x800
#define SPACEWIRE_TCODE_TCODE   0x0ff
#define SPACEWIRE_TCODE_SET   0x100 /* Set Timecode register */
#define SPACEWIRE_TCODE_TX   0x400
void grspw_register_drv (void)
void grspw_print (int options)
void(* grspw_timecode_callback )(void *pDev, void *regs, int minor, unsigned int tc)
