RTEMS 6.2
Modules | Files | Macros | Variables
spec:/testsuites/validation-cache
This validation test suite provides enough resources to run tests for the directives of the Cache Manager. More...
 spec:/rtems/cache/val/cache
 Tests some Cache Manager directives.
 spec:/rtems/cache/val/cache-disable-data
 spec:/rtems/cache/val/cache-no-disable-data
file  ts-validation-cache.c
#define CONFIGURE_MAXIMUM_PROCESSORS   4
const char rtems_test_name [] = "TestsuitesValidationCache"
 Each test must define a test name string.
In SMP configurations, up to three scheduler instances using the SMP EDF scheduler are provided using up to four processors.
