RTEMS 6.2
Files | Data Structures | Macros | Typedefs | Enumerations | Functions
file  tc-signal-send.c
struct  RtemsSignalReqSend_Entry
struct  RtemsSignalReqSend_Context
 Test context for spec:/rtems/signal/req/send test case. More...
#define EVENT_START   RTEMS_EVENT_0
#define EVENT_SEND_DONE   RTEMS_EVENT_1
#define EVENT_DO_ENABLE   RTEMS_EVENT_2
#define EVENT_END   RTEMS_EVENT_3
#define EVENT_WORKER_DONE   RTEMS_EVENT_4
typedef RtemsSignalReqSend_Context Context
enum  RtemsSignalReqSend_Pre_Task { RtemsSignalReqSend_Pre_Task_NoObj , RtemsSignalReqSend_Pre_Task_Self , RtemsSignalReqSend_Pre_Task_Other , RtemsSignalReqSend_Pre_Task_NA }
enum  RtemsSignalReqSend_Pre_Set { RtemsSignalReqSend_Pre_Set_Zero , RtemsSignalReqSend_Pre_Set_NonZero , RtemsSignalReqSend_Pre_Set_NA }
enum  RtemsSignalReqSend_Pre_Handler { RtemsSignalReqSend_Pre_Handler_Invalid , RtemsSignalReqSend_Pre_Handler_Valid , RtemsSignalReqSend_Pre_Handler_NA }
enum  RtemsSignalReqSend_Pre_ASR { RtemsSignalReqSend_Pre_ASR_Enabled , RtemsSignalReqSend_Pre_ASR_Disabled , RtemsSignalReqSend_Pre_ASR_NA }
enum  RtemsSignalReqSend_Pre_Nested { RtemsSignalReqSend_Pre_Nested_Yes , RtemsSignalReqSend_Pre_Nested_No , RtemsSignalReqSend_Pre_Nested_NA }
enum  RtemsSignalReqSend_Post_Status {
  RtemsSignalReqSend_Post_Status_Ok , RtemsSignalReqSend_Post_Status_InvNum , RtemsSignalReqSend_Post_Status_InvId , RtemsSignalReqSend_Post_Status_NotDef ,
  RtemsSignalReqSend_Post_Status_NA
enum  RtemsSignalReqSend_Post_Handler {
  RtemsSignalReqSend_Post_Handler_NoCall , RtemsSignalReqSend_Post_Handler_DuringSend , RtemsSignalReqSend_Post_Handler_AfterDispatch , RtemsSignalReqSend_Post_Handler_AfterEnable ,
  RtemsSignalReqSend_Post_Handler_NA
enum  RtemsSignalReqSend_Post_Recursive { RtemsSignalReqSend_Post_Recursive_Yes , RtemsSignalReqSend_Post_Recursive_No , RtemsSignalReqSend_Post_Recursive_NA }
 T_TEST_CASE_FIXTURE (RtemsSignalReqSend, &RtemsSignalReqSend_Fixture)
