RTEMS 6.2
Modules | Files | Data Structures | Typedefs
This group contains the SPICTRL interfaces. More...
 Automatic slave select register (ASLVSEL)
 This group contains register bit definitions.
 Capability register (CAP)
 Command register (CMD)
 Event register (EVENT)
 Mask register (MASK)
 Mode register (MODE)
 Receive register (RX)
 Slave select register (SLVSEL)
 Transmit register (TX)
file  spictrl-regs.h
 This header file defines the SPICTRL register block interface.
struct  spictrl
 This structure defines the SPICTRL register block memory map. More...
typedef struct spictrl spictrl
