RTEMS 6.2
Modules | Files | Data Structures | Typedefs
This group contains the FTMCTRL interfaces. More...
 Memory configuration register 1 (MCFG1)
 This group contains register bit definitions.
 Memory configuration register 3 (MCFG3)
 Memory configuration register 5 (MCFG5)
 Memory configuration register 7 (MCFG7)
file  ftmctrl-regs.h
 This header file defines the FTMCTRL register block interface.
struct  ftmctrl
 This structure defines the FTMCTRL register block memory map. More...
typedef struct ftmctrl ftmctrl
