RTEMS 6.2
This group contains the GRIOMMU interfaces. More...
Modules | |
| AHB failing access register (AHBFAS) | |
| This group contains register bit definitions. | |
| ASMP access control registers 0 - 3 (ASMPCTRL) | |
| Capability register 0 (CAP0) | |
| Capability register 1 (CAP1) | |
| Capability register 2 (CAP2) | |
| Control register (CTRL) | |
| Data RAM error injection register (DERRI) | |
| Diagnostic cache access data register 0 - 7 (DIAGD) | |
| Diagnostic cache access register (DIAGCTRL) | |
| Diagnostic cache access tag register (DIAGT) | |
| Group control register 0 - 7 (GRPCTRL) | |
| Interrupt mask register (IMASK) | |
| Master configuration register 0 - 9 (MSTCFG) | |
| Status register (STATUS) | |
| TLB/cache flush register (FLUSH) | |
| Tag RAM error injection register (TERRI) | |
Files | |
| file | griommu-regs.h |
| This header file defines the GRIOMMU register block interface. | |
| struct | griommu |
| This structure defines the GRIOMMU register block memory map. More... | |
Typedefs | |
| typedef struct griommu | griommu |
| This structure defines the GRIOMMU register block memory map. | |
