RTEMS
6.2
bsps
include
grlib
gr_701.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
/* GR-701 PCI Target driver.
4
5
* COPYRIGHT (c) 2008.
6
* Cobham Gaisler AB.
7
8
* Configures the GR-701 interface PCI board.
9
* This driver provides a AMBA PnP bus by using the general part
10
* of the AMBA PnP bus driver (ambapp_bus.c).
11
12
* Driver resources for the AMBA PnP bus provided can be set using
13
* gr701_set_resources().
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
#ifndef __GR_701_H__
38
#define __GR_701_H__
39
40
drvmgr/drvmgr.h
41
42
#ifdef __cplusplus
43
extern
"C"
44
#endif
45
46
/* An array of pointers to GR-701 resources. The resources will be
47
* used by the drivers controlling the cores on the GR-701 target AMBA bus.
48
49
* The gr701_resources is declared weak so that the user can override the
50
* default configuration. The array must be terminated with a NULL resource.
51
52
extern
struct
drvmgr_bus_res
*gr701_resources[];
53
54
#define GR701_OPTIONS_AMBA 0x01
55
#define GR701_OPTIONS_IRQ 0x02
56
57
/* Print information about all GR-701 PCI boards */
58
void
gr701_print(
int
options);
59
60
/* Print information about one GR-701 PCI board */
61
void
gr701_print_dev(
struct
drvmgr_dev
*dev,
int
options);
62
63
/* Register GR-701 driver */
64
void
gr701_register_drv(
void
65
66
#ifdef __cplusplus
67
68
#endif
69
70
#endif
drvmgr.h
Driver Manager Interface.
drvmgr_bus_res
Definition:
drvmgr.h:238
drvmgr_dev
Definition:
drvmgr.h:297
