RTEMS 6.2
gr1553bm.h
2
3/* GR1553B BM driver
4 *
5 * COPYRIGHT (c) 2010.
6 * Cobham Gaisler AB.
7 *
8 * Redistribution and use in source and binary forms, with or without
9 * modification, are permitted provided that the following conditions
10 * are met:
11 * 1. Redistributions of source code must retain the above copyright
12 * notice, this list of conditions and the following disclaimer.
13 * 2. Redistributions in binary form must reproduce the above copyright
14 * notice, this list of conditions and the following disclaimer in the
15 * documentation and/or other materials provided with the distribution.
16 *
17 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
18 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
21 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
22 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
23 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
24 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
25 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
26 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
27 * POSSIBILITY OF SUCH DAMAGE.
28 */
29
30#ifndef __GR1553BM_H__
31#define __GR1553BM_H__
32
33#ifdef __cplusplus
34extern "C" {
35#endif
36
37/* Register GR1553B driver needed by BM driver */
38extern void gr1553bm_register(void);
39
41 uint32_t time; /* bit31=1, bit 30=0 */
42 uint32_t data; /* bit31=0, bit 30=0 */
43};
44
45#define GR1553BM_ERROPTS_MANL 0x02
46#define GR1553BM_ERROPTS_UDWL 0x04
47#define GR1553BM_ERROPTS_IMCL 0x08
48#define GR1553BM_ERROPTS_ALL 0x0e
49
50/* Function used to implement a custom copy routine.
51 * Returns number of bytes the desctionation address
52 * should be incremented with.
53 *
54 * \param dst Optional Destination address
55 * \param src Source DMA address
56 * \param nentires Number of entries to be processed.
57 * \param data Custom Data (set by config)
58 */
59typedef int (*bmcopy_func_t)(
60 unsigned int dst,
61 struct gr1553bm_entry *src,
62 int nentries,
63 void *data
64 );
65
66/* IRQ function callback, called on BM DMA error */
67typedef void (*bmisr_func_t)(void *bm, void *data);
68
69/* BM driver configuration */
71
72 /*** Time options ***/
73
74 /* 8-bit time resolution, the BM will update the time according
75 * to this setting. 0 will make the time tag be of highest
76 * resolution (no division), 1 will make the BM increment the
77 * time tag once for two time ticks (div with 2), etc.
78 */
79 uint8_t time_resolution;
80
81 /* Enable Time Overflow IRQ handling. Setting this to 1
82 * makes the driver to update the 64-bit time by it self,
83 * it will use time overflow IRQ to detect when the 64-bit
84 * time counter must be incremented.
85 *
86 * If set to zero, the driver expect the user to call
87 * gr1553bm_time() regularly, it must be called more often
88 * than the time overflows to avoid an incorrect time.
89 */
90 int time_ovf_irq;
91
92
93
94 /*** Filtering options ***/
95
96 /* Bus error log options
97 *
98 * bit0,4-31 = reserved, set to zero
99 * Bit1 = Enables logging of Invalid mode code errors
100 * Bit2 = Enables logging of Unexpected Data errors
101 * Bit3 = Enables logging of Manchester/parity errors
102 */
103 unsigned int filt_error_options;
104
105 /* RT Address filtering bit mask. Each bit enables (if set)
106 * logging of a certain RT sub address. Bit 31 enables logging
107 * of broadcast messages.
108 */
109 unsigned int filt_rtadr;
110
111 /* RT Subaddress filtering bit mask, bit definition:
112 * 31: Enables logging of mode commands on subadr 31
113 * 1..30: BitN enables/disables logging of RT subadr N
114 * 0: Enables logging of mode commands on subadr 0
115 */
116 unsigned int filt_subadr;
117
118 /* Mode code Filter, is written into "BM RT Mode code filter"
119 * register, please see hardware manual for bit declarations.
120 */
121 unsigned int filt_mc;
122
123
124
125 /*** Buffer options ***/
126
127 /* Size of buffer in bytes, must be aligned to 8-byte
128 * The size is limited to max 4Mb.
129 */
130 unsigned int buffer_size;
131
132 /* Custom buffer, must be aligned to 8-byte and be of buffer_size
133 * length. If NULL dynamic memory allocation is used.
134 */
135 void *buffer_custom;
136
137 /* Custom Copy function, may be used to implement a more
138 * effective way of copying the DMA buffer. For example
139 * the DMA log may need to be compressed before copied
140 * onto a storage, this function can be used to avoid an
141 * extra copy.
142 */
143 bmcopy_func_t copy_func;
144
145 /* Optional Custom Data passed on to copy_func() */
146 void *copy_func_arg;
147
148
149
150 /*** Interrupt options ***/
151
152 /* Custom DMA error function, note that this function is called
153 * from Interrupt Context. Set to NULL to disable this callback.
154 */
155 bmisr_func_t dma_error_isr;
156
157 /* Optional Custom Data passed on to dma_error_isr() */
158 void *dma_error_arg;
159};
160
161/* Open BM device by instance number (minor)
162 *
163 * The return value is used as input parameter in all other function calls
164 * in the A
165 */
166extern void *gr1553bm_open(int minor);
167
168/* Close previously opened Bm device */
169extern void gr1553bm_close(void *bm);
170
171/* Configure the BM driver before starting */
172extern int gr1553bm_config(void *bm, struct gr1553bm_config *cfg);
173
174/* Start logging */
175extern int gr1553bm_start(void *bm);
176
177/* Get 64-bit 1553 Time. Low 24-bit time is acquired from BM hardware,
178 * the MSB is taken from a software counter internal to the driver. The
179 * counter is incremented every time the Time overflows by:
180 * - using "Time overflow" IRQ if enabled in user configuration
181 * - by checking IRQ flag (IRQ disabled), it is required that user
182 * calls this function before the next time overflow.
183 *
184 * The BM timer is limited to 24-bits, in order to handle overflows
185 * correctly and maintain a valid time an Interrupt handler is used
186 * or this function must be called when IRQ is not used.
187 *
188 * Update software time counters and return the current time.
189 */
190extern void gr1553bm_time(void *bm, uint64_t *time);
191
192/* Return zero when logging has not been started, non-zero when logging
193 * has been started
194 */
195extern int gr1553bm_started(void *bm);
196
197/* Check how many entries are currently stored in the BM Log DMA-area */
198extern int gr1553bm_available(void *bm, int *nentries);
199
200/* Stop logging */
201extern void gr1553bm_stop(void *bm);
202
203/* Read a maximum number of entries from LOG buffer. This function
204 * must be
205 *
206 * Arguments
207 * bm - Private pointer returned by gr1553bm_open()
208 * dst - Address where log data is written
209 * max - (IN/OUT) Maximum number of entires, when successfull
210 * the number of entries actually written is stored
211 * into the address of max.
212 *
213 * Result
214 * 0 = success
215 * -1 = fail. (may be due to BM logging not started)
216 */
217extern int gr1553bm_read(void *bm, struct gr1553bm_entry *dst, int *max);
218
219#ifdef __cplusplus
220}
221#endif
222
223#endif /* __GR1553BM_H__ */
Definition: gr1553bm.h:70
Definition: gr1553bm.h:40
