RTEMS 6.2
extensiondata.h
2
12/*
13 * COPYRIGHT (c) 1989-2008.
14 * On-Line Applications Research Corporation (OAR).
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 * 1. Redistributions of source code must retain the above copyright
20 * notice, this list of conditions and the following disclaimer.
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in the
23 * documentation and/or other materials provided with the distribution.
24 *
25 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35 * POSSIBILITY OF SUCH DAMAGE.
36 */
37
38#ifndef _RTEMS_EXTENSIONDATA_H
39#define _RTEMS_EXTENSIONDATA_H
40
41#include <rtems/extension.h>
44
45#ifdef __cplusplus
46extern "C" {
47#endif
48
55typedef struct {
56 Objects_Control Object;
59
64
74#define EXTENSION_INFORMATION_DEFINE( max ) \
75 OBJECTS_INFORMATION_DEFINE( \
76 _Extension, \
77 OBJECTS_CLASSIC_API, \
78 OBJECTS_RTEMS_EXTENSIONS, \
79 Extension_Control, \
80 max, \
81 OBJECTS_NO_STRING_NAME, \
82 NULL \
83 )
84
87#ifdef __cplusplus
88}
89#endif
90
91#endif
92/* end of include file */
This header file defines the User Extensions Manager API.
Objects_Information _Extension_Information
The Classic Extensions objects information.
This header file provides data structures used by the implementation and the Application Configuratio...
Definition: extensiondata.h:55
Definition: objectdata.h:61
The information structure used to manage each API class of objects.
Definition: objectdata.h:198
Manages each user extension set.
Definition: userextdata.h:72
