RTEMS
6.2
include
dumpbuf.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
12
13
* COPYRIGHT (c) 1997-2011.
14
* On-Line Applications Research Corporation (OAR).
15
16
17
* modification, are permitted provided that the following conditions
18
* are met:
19
* 1. Redistributions of source code must retain the above copyright
20
* notice, this list of conditions and the following disclaimer.
21
* 2. Redistributions in binary form must reproduce the above copyright
22
* notice, this list of conditions and the following disclaimer in the
23
* documentation and/or other materials provided with the distribution.
24
25
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35
* POSSIBILITY OF SUCH DAMAGE.
36
37
38
#ifndef __DUMP_BUFFER_h
39
#define __DUMP_BUFFER_h
40
47
#ifdef __cplusplus
48
extern
"C"
49
#endif
50
61
void
rtems_print_buffer
62
const
unsigned
char
*buffer,
63
int
length
64
65
66
#ifdef __cplusplus
67
68
#endif
70
#endif
71
/* end of include file */
rtems_print_buffer
void rtems_print_buffer(const unsigned char *buffer, int length)
Print memory buffer.
Definition:
dumpbuf.c:70
