RTEMS
6.2
include
crc.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
12
13
* Copyright (C) 2024 embedded brains GmbH & Co. KG
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
#ifndef _RTEMS_CRC_H
38
#define _RTEMS_CRC_H
39
40
#include <stddef.h>
41
#include <stdint.h>
42
43
#ifdef __cplusplus
44
extern
"C"
45
#endif
/* __cplusplus */
46
62
#define CRC24Q_SEED 0U
63
68
#define CRC24Q_MASK 0xffffffU
69
80
uint32_t
_CRC24Q_Update
( uint32_t crc, uint8_t
byte
81
94
uint32_t
_CRC24Q_Sequence_update
95
uint32_t crc,
96
const
void
*bytes,
97
size_t
size_in_bytes
98
99
102
#ifdef __cplusplus
103
104
#endif
/* __cplusplus */
105
106
#endif
/* _RTEMS_CRC_H */
uint32_t _CRC24Q_Sequence_update(uint32_t crc, const void *bytes, size_t size_in_bytes)
Updates the CRC-24Q state using a sequence of bytes.
Definition:
crc24q.c:138
_CRC24Q_Update
uint32_t _CRC24Q_Update(uint32_t crc, uint8_t byte)
Updates the CRC-24Q state using a byte.
Definition:
crc24q.c:134
