RTEMS 6.2
Global BSP definitions. More...
#include "mcf5206/mcf5206e.h"#include <bspopts.h>#include <rtems.h>#include <bsp/default-initial-extension.h>Go to the source code of this file.
| #define | BSP_MEM_ADDR_FLASH (0xFFE00000) |
| #define | BSP_MEM_SIZE_FLASH (1*1024*1024) |
| #define | BSP_MEM_MASK_FLASH (MCF5206E_CSMR_MASK_1M) |
| #define | BSP_MEM_ADDR_ESRAM (0x30000000) |
| #define | BSP_MEM_SIZE_ESRAM (1*1024*1024) |
| #define | BSP_MEM_MASK_ESRAM (MCF5206E_CSMR_MASK_1M) |
| #define | BSP_MEM_ADDR_GPIO (0x40000000) |
| #define | BSP_MEM_SIZE_GPIO (64*1024) |
| #define | BSP_MEM_MASK_GPIO (MCF5206E_CSMR_MASK_64K) |
| #define | BSP_MEM_ADDR_DRAM (0x00000000) |
| #define | BSP_MEM_SIZE_DRAM (16*1024*1024) |
| #define | BSP_MEM_MASK_DRAM (MCF5206E_DCMR_MASK_16M) |
| #define | BSP_MEM_ADDR_SRAM (0x20000000) |
| #define | BSP_MEM_SIZE_SRAM (8*1024) |
| #define | BSP_MEM_ADDR_IMM (0x10000000) |
| #define | BSP_MEM_SIZE_IMM (1*1024) |
| #define | MBAR BSP_MEM_ADDR_IMM |
| #define | BSP_INTVEC_AVEC1 (25) |
| #define | BSP_INTLVL_AVEC1 (1) |
| #define | BSP_INTPRIO_AVEC1 (3) |
| #define | BSP_INTVEC_AVEC2 (26) |
| #define | BSP_INTLVL_AVEC2 (2) |
| #define | BSP_INTPRIO_AVEC2 (3) |
| #define | BSP_INTVEC_AVEC3 (27) |
| #define | BSP_INTLVL_AVEC3 (3) |
| #define | BSP_INTPRIO_AVEC3 (3) |
| #define | BSP_INTVEC_AVEC4 (28) |
| #define | BSP_INTLVL_AVEC4 (4) |
| #define | BSP_INTPRIO_AVEC4 (3) |
| #define | BSP_INTVEC_AVEC5 (29) |
| #define | BSP_INTLVL_AVEC5 (5) |
| #define | BSP_INTPRIO_AVEC5 (3) |
| #define | BSP_INTVEC_AVEC6 (30) |
| #define | BSP_INTLVL_AVEC6 (6) |
| #define | BSP_INTPRIO_AVEC6 (3) |
| #define | BSP_INTVEC_AVEC7 (31) |
| #define | BSP_INTLVL_AVEC7 (7) |
| #define | BSP_INTPRIO_AVEC7 (3) |
| #define | BSP_INTVEC_TIMER1 (BSP_INTVEC_AVEC5) |
| #define | BSP_INTLVL_TIMER1 (BSP_INTLVL_AVEC5) |
| #define | BSP_INTPRIO_TIMER1 (2) |
| #define | BSP_INTVEC_TIMER2 (BSP_INTVEC_AVEC6) |
| #define | BSP_INTLVL_TIMER2 (BSP_INTLVL_AVEC6) |
| #define | BSP_INTPRIO_TIMER2 (2) |
| #define | BSP_INTVEC_MBUS (BSP_INTVEC_AVEC4) |
| #define | BSP_INTLVL_MBUS (BSP_INTLVL_AVEC4) |
| #define | BSP_INTPRIO_MBUS (2) |
| #define | BSP_INTVEC_UART1 (64) |
| #define | BSP_INTLVL_UART1 (4) |
| #define | BSP_INTPRIO_UART1 (0) |
| #define | BSP_INTVEC_UART2 (65) |
| #define | BSP_INTLVL_UART2 (4) |
| #define | BSP_INTPRIO_UART2 (1) |
| #define | BSP_INTVEC_DMA0 (66) |
| #define | BSP_INTLVL_DMA0 (3) |
| #define | BSP_INTPRIO_DMA0 (1) |
| #define | BSP_INTVEC_DMA1 (67) |
| #define | BSP_INTLVL_DMA1 (3) |
| #define | BSP_INTPRIO_DMA1 (2) |
| #define | DS1307_I2C_BUS_NUMBER (0) |
| #define | BSP_SYSTEM_FREQUENCY ((unsigned int)&_SYS_CLOCK_FREQUENCY) |
| #define | BSP_MBUS_FREQUENCY (16000) |
| #define | I2C_NUMBER_OF_BUSES (1) |
| #define | I2C_SELECT_BUS(bus) |
| #define | rtems_bsp_delay(microseconds) |
| rtems_isr_entry | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
| Install an interrupt handler. | |
| void | Init5206e (void) |
| char | _SYS_CLOCK_FREQUENCY |
| rtems_isr_entry | M68Kvec [] |
| rtems_isr(* | rtems_clock_hook )(rtems_vector_number) |
