RTEMS 6.2
Global BSP definitions. More...
#include <libcpu/bf533.h>#include <bspopts.h>#include <bsp/default-initial-extension.h>#include <rtems.h>#include <rtems/score/bfin.h>#include <rtems/bfin/bf533.h>Go to the source code of this file.
functions | |
| void | setLED (uint8_t value) |
| Helper Function to use the EzKits LEDS. Can be used by the Application. | |
| uint8_t | getLED (void) |
| Helper Function to use the EzKits LEDS. | |
| rtems_isr_entry | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
| Install an interrupt handler. | |
| void | Init_RTC (void) |
| void | bfin_null_isr (void) |
This include file contains all board IO definitions for TLL6527M.
