RTEMS 6.2
Global BSP definitions. More...
| #define | BSP_FEATURE_IRQ_EXTENSION |
| #define | CONFIG_ARM_CLK 60000000L |
| #define | LPC22xx_Fcclk CONFIG_ARM_CLK |
| system clk frequecy,<=60Mhz, defined in system configuration | |
| #define | LPC22xx_Fcco LPC22xx_Fcclk * 4 |
| #define | LPC22xx_Fpclk (LPC22xx_Fcclk /4) *1 |
| VPB clk frequency,1,1/2,1/4 times of Fcclk. | |
| #define | PLLFEED_DATA1 0xAA |
| #define | PLLFEED_DATA2 0x55 |
| #define | FOSC 11059200 |
| OSC [Hz]. | |
| #define | FCCLK FOSC<<2 |
| Core clk [Hz]. | |
| #define | JOEL_M Fcclk / Fosc |
| #define | P_min Fcco_MIN / (2*Fcclk) + 1; |
| #define | P_max Fcco_MAX / (2*Fcclk); |
| #define | UART_BPS 115200 |
| #define | TIMER_PRECISION 10 |
| Time Precision time [us]. | |
| #define | I2CSPEED 20000 |
| I2C Speed [bit/s]. | |
| #define | SPISPEED 1500000 |
| SPI Speed [bit/s]. | |
| #define | SPI_CS_PIN P0_13 |
| SPI EEPROM CS pin. | |
| #define | SPI_CS_PIN_FUNC PINSEL0_bit.SPI_CS_PIN |
| #define | CS8900A_BASE 0x82000000 |
| CS8900A definition. | |
| #define | RTL8019AS_BASE 0x82000000 |
| RTL8019AS definition. | |
Fcclk range: 10MHz ~ MCU allowed frequency | |
| #define | Fcclk_MIN 10000000L |
| #define | Fcclk_MAX 60000000L |
Fcco range: 156MHz ~ 320MHz | |
| #define | Fcco_MIN 156000000L |
| #define | Fcco_MAX 320000000L |
PLL PLLCON register bit descriptions | |
| #define | PLLCON_ENABLE_BIT 0 |
| #define | PLLCON_CONNECT_BIT 1 |
PLL PLLSTAT register bit descriptions | |
| #define | PLLSTAT_ENABLE_BIT 8 |
| #define | PLLSTAT_CONNECT_BIT 9 |
| #define | PLLSTAT_LOCK_BIT 10 |
PM Peripheral Type | |
| #define | PC_TIMER0 0x2 |
| #define | PC_TIMER1 0x4 |
| #define | PC_UART0 0x8 |
| #define | PC_UART1 0x10 |
| #define | PC_PWM0 0x20 |
| #define | PC_I2C 0x80 |
| #define | PC_SPI0 0x100 |
| #define | PC_RTC 0x200 |
System Configure | |
| #define | Fosc 11059200 |
| osc freq,10MHz~25MHz, change to a real one if needed | |
| #define | Fcclk (Fosc << 2) |
| system freq 2^n time of Fosc(1~32) <=60MHZ | |
| #define | Fcco (Fcclk <<2) |
| CCO freq 2,4,8,16 time of Fcclk 156MHz~320MHz. | |
| #define | Fpclk (Fcclk >>2) * 1 |
| VPB freq only(Fcclk / 4) 1~4. | |
Uarts buffers size | |
| #define | RXBUFSIZE 32 |
| #define | TXBUFSIZE 32 |
Flash definition | |
| #define | RTL22XX_FLASH_SIZE (0x80000-RTL22XX_FLASH_BOOT) |
| Total area of Flash region in words 8 bit. | |
| #define | RTL22XX_FLASH_BEGIN 0x80000000 |
| #define | RTL22XX_FLASH_BASE (RTL22XX_FLASH_BEGIN+RTL22XX_FLASH_BOOT) |
| First 0x8000 bytes reserved for boot loader etc. | |
SRAM definition | |
| #define | SRAM_SIZE 0x100000 |
| #define | SRAM_BASE 0x81000000 |
Network driver configuration | |
| #define | RTEMS_BSP_NETWORK_DRIVER_NAME "eth0" |
| #define | RTEMS_BSP_NETWORK_DRIVER_ATTACH cs8900_driver_attach |
| int | cs8900_driver_attach (struct rtems_bsdnet_ifconfig *config, int attaching) |
| void | UART0_Ini (void) |
