RTEMS 6.2
tm27.h
1
7/*
8 * tm27.h
9 *
10 * COPYRIGHT (c) 2010 by ECE Northeastern University.
11 *
12 * The license and distribution terms for this file may be
13 * found in the file LICENSE in this distribution or at
14 * http://www.rtems.org/license
15 */
16
17#ifndef _RTEMS_TMTEST27
18#error "This is an RTEMS internal file you must not include directly."
19#endif
20
21#ifndef __tm27_h
22#define __tm27_h
23
31/*
32 * Define the interrupt mechanism for Time Test 27
33 */
34
35#define MUST_WAIT_FOR_INTERRUPT 0
36
37#define TM27_USE_VECTOR_HANDLER
38
39#define Install_tm27_vector(handler) \
40{ \
41 set_vector( handler, 0x06, 1 ); \
42}
43
44#define Cause_tm27_intr() asm volatile("raise 0x06;" : :);
45
46#define Clear_tm27_intr() /* empty */
47
48#define Lower_tm27_intr() /* empty */
49
52#endif
