RTEMS 6.2
barrier.h
2
11/*
12 * Copyright (C) 2025 Mazen Adel Elmessady
13 * Copyright (C) 2020, 2021 embedded brains GmbH & Co. KG
14 * Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 * 1. Redistributions of source code must retain the above copyright
20 * notice, this list of conditions and the following disclaimer.
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in the
23 * documentation and/or other materials provided with the distribution.
24 *
25 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35 * POSSIBILITY OF SUCH DAMAGE.
36 */
37
38/*
39 * This file is part of the RTEMS quality process and was automatically
40 * generated. If you find something that needs to be fixed or
41 * worded better please post a report or patch to an RTEMS mailing list
42 * or raise a bug report:
43 *
44 * https://www.rtems.org/bugs.html
45 *
46 * For information on updating and regenerating please refer to the How-To
47 * section in the Software Requirements Engineering chapter of the
48 * RTEMS Software Engineering manual. The manual is provided as a part of
49 * a release. For development sources please refer to the online
50 * documentation at:
51 *
52 * https://docs.rtems.org
53 */
54
55/* Generated from spec:/rtems/barrier/if/header */
56
57#ifndef _RTEMS_RTEMS_BARRIER_H
58#define _RTEMS_RTEMS_BARRIER_H
59
60#include <stdint.h>
61#include <rtems/rtems/attr.h>
62#include <rtems/rtems/status.h>
63#include <rtems/rtems/types.h>
64
65#ifdef __cplusplus
66extern "C" {
67#endif
68
69/* Generated from spec:/rtems/barrier/if/group */
70
80/* Generated from spec:/rtems/barrier/if/create */
81
169 rtems_name name,
170 rtems_attribute attribute_set,
171 uint32_t maximum_waiters,
172 rtems_id *id
173);
174
175/* Generated from spec:/rtems/barrier/if/ident */
176
223
224/* Generated from spec:/rtems/barrier/if/delete */
225
265
266/* Generated from spec:/rtems/barrier/if/wait */
267
314
315/* Generated from spec:/rtems/barrier/if/release */
316
351rtems_status_code rtems_barrier_release( rtems_id id, uint32_t *released );
352
353/* Generated from spec:/rtems/barrier/if/get-number-waiting */
354
386 rtems_id id,
387 uint32_t *waiting
388);
389
390#ifdef __cplusplus
391}
392#endif
393
394#endif /* _RTEMS_RTEMS_BARRIER_H */
This header file provides Classic API directive attributes.
This header file provides types used by the Classic API.
uint32_t rtems_attribute
This type represents Classic API attributes.
Definition: attr.h:96
rtems_status_code rtems_barrier_get_number_waiting(rtems_id id, uint32_t *waiting)
Gets the number of tasks waiting at the barrier.
Definition: barriergetnumwaiting.c:43
rtems_status_code rtems_barrier_wait(rtems_id id, rtems_interval timeout)
Waits at the barrier.
Definition: barrierwait.c:51
rtems_status_code rtems_barrier_delete(rtems_id id)
Deletes the barrier.
Definition: barrierdelete.c:44
rtems_status_code rtems_barrier_create(rtems_name name, rtems_attribute attribute_set, uint32_t maximum_waiters, rtems_id *id)
Creates a barrier.
Definition: barriercreate.c:49
rtems_status_code rtems_barrier_release(rtems_id id, uint32_t *released)
Releases the barrier.
Definition: barrierrelease.c:44
rtems_status_code rtems_barrier_ident(rtems_name name, rtems_id *id)
Identifies a barrier by the object name.
Definition: barrierident.c:45
rtems_status_code
Definition: status.h:85
uint32_t rtems_name
This type represents Classic API object names.
Definition: types.h:226
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition: types.h:94
Watchdog_Interval rtems_interval
This type represents clock tick intervals.
Definition: types.h:114
This header file provides the status codes of Classic API directives and support functions.
