RTEMS 6.2
ambapp_bus_grlib.h
2
3/* LEON3 GRLIB AMBA Plug & Play bus driver interface.
4 *
5 * COPYRIGHT (c) 2008.
6 * Cobham Gaisler AB.
7 *
8 * This is driver is a wrapper for the general AMBA Plug & Play bus
9 * driver. This is the root bus driver for GRLIB systems.
10 *
11 * Redistribution and use in source and binary forms, with or without
12 * modification, are permitted provided that the following conditions
13 * are met:
14 * 1. Redistributions of source code must retain the above copyright
15 * notice, this list of conditions and the following disclaimer.
16 * 2. Redistributions in binary form must reproduce the above copyright
17 * notice, this list of conditions and the following disclaimer in the
18 * documentation and/or other materials provided with the distribution.
19 *
20 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
21 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
22 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
23 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
24 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
25 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
26 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
27 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
28 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
29 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
30 * POSSIBILITY OF SUCH DAMAGE.
31 */
32
33#ifndef __AMBAPP_BUS_GRLIB_H__
34#define __AMBAPP_BUS_GRLIB_H__
35
36#ifdef __cplusplus
37extern "C" {
38#endif
39
41 struct ambapp_bus *abus;
42 struct drvmgr_bus_res *resources;
43};
44
45/* Register GRLIB AMBA PnP Bus as root bus at driver manager */
46extern int ambapp_grlib_root_register(struct grlib_config *config);
47
48/* Register bus driver to Driver Manager */
49void ambapp_grlib_register(void);
50
51#ifdef __cplusplus
52}
53#endif
54
55#endif
Definition: ambapp.h:133
Definition: deflate.c:114
Definition: drvmgr.h:238
Definition: ambapp_bus_grlib.h:40
