RTEMS 6.2
am335x.h
1/*
2 * Copyright (c) 2012 Claas Ziemke. All rights reserved.
3 *
4 * Claas Ziemke
5 * Kernerstrasse 11
6 * 70182 Stuttgart
7 * Germany
8 * <claas.ziemke@gmx.net>
9 *
10 * The license and distribution terms for this file may be
11 * found in the file LICENSE in this distribution or at
12 * http://www.rtems.org/license/LICENSE.
13 *
14 * Modified by Ben Gras <beng@shrike-systems.com> to add lots
15 * of beagleboard/beaglebone definitions, delete lpc32xx specific
16 * ones, and merge with some other header files.
17 */
18
19#if !defined(_AM335X_H_)
20#define _AM335X_H_
21
22#define AM335X_MASK(Shift, Width) (((1 << (Width)) - 1) << (Shift))
23
24
25/* Interrupt controller memory map */
26#define OMAP3_DM37XX_INTR_BASE 0x48200000 /* INTCPS physical address */
27
28/* Interrupt controller memory map */
29#define OMAP3_AM335X_INTR_BASE 0x48200000 /* INTCPS physical address */
30
31#define AM335X_INT_EMUINT 0
32 /* Emulation interrupt (EMUICINTR) */
33#define AM335X_INT_COMMTX 1
34 /* CortexA8 COMMTX */
35#define AM335X_INT_COMMRX 2
36 /* CortexA8 COMMRX */
37#define AM335X_INT_BENCH 3
38 /* CortexA8 NPMUIRQ */
39#define AM335X_INT_ELM_IRQ 4
40 /* Sinterrupt (Error location process completion) */
41#define AM335X_INT_NMI 7
42 /* nmi_int */
43#define AM335X_INT_L3DEBUG 9
44 /* l3_FlagMux_top_FlagOut1 */
45#define AM335X_INT_L3APPINT 10
46 /* l3_FlagMux_top_FlagOut0 */
47#define AM335X_INT_PRCMINT 11
48 /* irq_mpu */
49#define AM335X_INT_EDMACOMPINT 12
50 /* tpcc_int_pend_po0 */
51#define AM335X_INT_EDMAMPERR 13
52 /* tpcc_mpint_pend_po */
53#define AM335X_INT_EDMAERRINT 14
54 /* tpcc_errint_pend_po */
55#define AM335X_INT_ADC_TSC_GENINT 16
56 /* gen_intr_pend */
57#define AM335X_INT_USBSSINT 17
58 /* usbss_intr_pend */
59#define AM335X_INT_USB0 18
60 /* usb0_intr_pend */
61#define AM335X_INT_USB1 19
62 /* usb1_intr_pend */
63#define AM335X_INT_PRUSS1_EVTOUT0 20
64 /* pr1_host_intr0_intr_pend */
65#define AM335X_INT_PRUSS1_EVTOUT1 21
66 /* pr1_host_intr1_intr_pend */
67#define AM335X_INT_PRUSS1_EVTOUT2 22
68 /* pr1_host_intr2_intr_pend */
69#define AM335X_INT_PRUSS1_EVTOUT3 23
70 /* pr1_host_intr3_intr_pend */
71#define AM335X_INT_PRUSS1_EVTOUT4 24
72 /* pr1_host_intr4_intr_pend */
73#define AM335X_INT_PRUSS1_EVTOUT5 25
74 /* pr1_host_intr5_intr_pend */
75#define AM335X_INT_PRUSS1_EVTOUT6 26
76 /* pr1_host_intr6_intr_pend */
77#define AM335X_INT_PRUSS1_EVTOUT7 27
78 /* pr1_host_intr7_intr_pend */
79#define AM335X_INT_MMCSD1INT 28
80 /* MMCSD1 SINTERRUPTN */
81#define AM335X_INT_MMCSD2INT 29
82 /* MMCSD2 SINTERRUPT */
83#define AM335X_INT_I2C2INT 30
84 /* I2C2 POINTRPEND */
85#define AM335X_INT_eCAP0INT 31
86 /* ecap_intr_intr_pend */
87#define AM335X_INT_GPIOINT2A 32
88 /* GPIO 2 POINTRPEND1 */
89#define AM335X_INT_GPIOINT2B 33
90 /* GPIO 2 POINTRPEND2 */
91#define AM335X_INT_USBWAKEUP 34
92 /* USBSS slv0p_Swakeup */
93#define AM335X_INT_LCDCINT 36
94 /* LCDC lcd_irq */
95#define AM335X_INT_GFXINT 37
96 /* SGX530 THALIAIRQ */
97#define AM335X_INT_ePWM2INT 39
98 /* (PWM Subsystem) epwm_intr_intr_pend */
99#define AM335X_INT_3PGSWRXTHR0 40
100 /* (Ethernet) c0_rx_thresh_pend (RX_THRESH_PULSE) */
101#define AM335X_INT_3PGSWRXINT0 41
102 /* CPSW (Ethernet) c0_rx_pend */
103#define AM335X_INT_3PGSWTXINT0 42
104 /* CPSW (Ethernet) c0_tx_pend */
105#define AM335X_INT_3PGSWMISC0 43
106 /* CPSW (Ethernet) c0_misc_pend */
107#define AM335X_INT_UART3INT 44
108 /* UART3 niq */
109#define AM335X_INT_UART4INT 45
110 /* UART4 niq */
111#define AM335X_INT_UART5INT 46
112 /* UART5 niq */
113#define AM335X_INT_eCAP1INT 47
114 /* (PWM Subsystem) ecap_intr_intr_pend */
115#define AM335X_INT_DCAN0_INT0 52
116 /* DCAN0 dcan_intr0_intr_pend */
117#define AM335X_INT_DCAN0_INT1 53
118 /* DCAN0 dcan_intr1_intr_pend */
119#define AM335X_INT_DCAN0_PARITY 54
120 /* DCAN0 dcan_uerr_intr_pend */
121#define AM335X_INT_DCAN1_INT0 55
122 /* DCAN1 dcan_intr0_intr_pend */
123#define AM335X_INT_DCAN1_INT1 56
124 /* DCAN1 dcan_intr1_intr_pend */
125#define AM335X_INT_DCAN1_PARITY 57
126 /* DCAN1 dcan_uerr_intr_pend */
127#define AM335X_INT_ePWM0_TZINT 58
128 /* eHRPWM0 TZ interrupt (PWM epwm_tz_intr_pend Subsystem) */
129#define AM335X_INT_ePWM1_TZINT 59
130 /* eHRPWM1 TZ interrupt (PWM epwm_tz_intr_pend Subsystem) */
131#define AM335X_INT_ePWM2_TZINT 60
132 /* eHRPWM2 TZ interrupt (PWM epwm_tz_intr_pend Subsystem) */
133#define AM335X_INT_eCAP2INT 61
134 /* eCAP2 (PWM Subsystem) ecap_intr_intr_pend */
135#define AM335X_INT_GPIOINT3A 62
136 /* GPIO 3 POINTRPEND1 */
137#define AM335X_INT_GPIOINT3B 63
138 /* GPIO 3 POINTRPEND2 */
139#define AM335X_INT_MMCSD0INT 64
140 /* MMCSD0 SINTERRUPTN */
141#define AM335X_INT_SPI0INT 65
142 /* McSPI0 SINTERRUPTN */
143#define AM335X_INT_TINT0 66
144 /* Timer0 POINTR_PEND */
145#define AM335X_INT_TINT1_1MS 67
146 /* DMTIMER_1ms POINTR_PEND */
147#define AM335X_INT_TINT2 68
148 /* DMTIMER2 POINTR_PEND */
149#define AM335X_INT_TINT3 69
150 /* DMTIMER3 POINTR_PEND */
151#define AM335X_INT_I2C0INT 70
152 /* I2C0 POINTRPEND */
153#define AM335X_INT_I2C1INT 71
154 /* I2C1 POINTRPEND */
155#define AM335X_INT_UART0INT 72
156 /* UART0 niq */
157#define AM335X_INT_UART1INT 73
158 /* UART1 niq */
159#define AM335X_INT_UART2INT 74
160 /* UART2 niq */
161#define AM335X_INT_RTCINT 75
162 /* RTC timer_intr_pend */
163#define AM335X_INT_RTCALARMINT 76
164 /* RTC alarm_intr_pend */
165#define AM335X_INT_MBINT0 77
166 /* Mailbox0 (mail_u0_irq) initiator_sinterrupt_q_n */
167#define AM335X_INT_M3_TXEV 78
168 /* Wake M3 Subsystem TXEV */
169#define AM335X_INT_eQEP0INT 79
170 /* eQEP0 (PWM Subsystem) eqep_intr_intr_pend */
171#define AM335X_INT_MCATXINT0 80
172 /* McASP0 mcasp_x_intr_pend */
173#define AM335X_INT_MCARXINT0 81
174 /* McASP0 mcasp_r_intr_pend */
175#define AM335X_INT_MCATXINT1 82
176 /* McASP1 mcasp_x_intr_pend */
177#define AM335X_INT_MCARXINT1 83
178 /* McASP1 mcasp_r_intr_pend */
179#define AM335X_INT_ePWM0INT 86
180 /* (PWM Subsystem) epwm_intr_intr_pend */
181#define AM335X_INT_ePWM1INT 87
182 /* (PWM Subsystem) epwm_intr_intr_pend */
183#define AM335X_INT_eQEP1INT 88
184 /* (PWM Subsystem) eqep_intr_intr_pend */
185#define AM335X_INT_eQEP2INT 89
186 /* (PWM Subsystem) eqep_intr_intr_pend */
187#define AM335X_INT_DMA_INTR_PIN2 90
188 /* External DMA/Interrupt Pin2 */
189#define AM335X_INT_WDT1INT 91
190 /* (Public Watchdog) WDTIMER1 PO_INT_PEND */
191#define AM335X_INT_TINT4 92
192 /* DMTIMER4 POINTR_PEN */
193#define AM335X_INT_TINT5 93
194 /* DMTIMER5 POINTR_PEN */
195#define AM335X_INT_TINT6 94
196 /* DMTIMER6 POINTR_PEND */
197#define AM335X_INT_TINT7 95
198 /* DMTIMER7 POINTR_PEND */
199#define AM335X_INT_GPIOINT0A 96
200 /* GPIO 0 POINTRPEND1 */
201#define AM335X_INT_GPIOINT0B 97
202 /* GPIO 0 POINTRPEND2 */
203#define AM335X_INT_GPIOINT1A 98
204 /* GPIO 1 POINTRPEND1 */
205#define AM335X_INT_GPIOINT1B 99
206 /* GPIO 1 POINTRPEND2 */
207#define AM335X_INT_GPMCINT 100
208 /* GPMC gpmc_sinterrupt */
209#define AM335X_INT_DDRERR0 101
210 /* EMIF sys_err_intr_pend */
211#define AM335X_INT_TCERRINT0 112
212 /* TPTC0 tptc_erint_pend_po */
213#define AM335X_INT_TCERRINT1 113
214 /* TPTC1 tptc_erint_pend_po */
215#define AM335X_INT_TCERRINT2 114
216 /* TPTC2 tptc_erint_pend_po */
217#define AM335X_INT_ADC_TSC_PENINT 115
218 /* ADC_TSC pen_intr_pend */
219#define AM335X_INT_SMRFLX_Sabertooth 120
220 /* Smart Reflex 0 intrpen */
221#define AM335X_INT_SMRFLX_Core 121
222 /* Smart Reflex 1 intrpend */
223#define AM335X_INT_DMA_INTR_PIN0 123
224 /* pi_x_dma_event_intr0 (xdma_event_intr0) */
225#define AM335X_INT_DMA_INTR_PIN1 124
226 /* pi_x_dma_event_intr1 (xdma_event_intr1) */
227#define AM335X_INT_SPI1INT 125
228 /* McSPI1 SINTERRUPTN */
229
230#define OMAP3_AM335X_NR_IRQ_VECTORS 125
231
232#define AM335X_DMTIMER0_BASE 0x44E05000
233 /* DMTimer0 Registers */
234#define AM335X_DMTIMER1_1MS_BASE 0x44E31000
235 /* DMTimer1 1ms Registers (Accurate 1ms timer) */
236#define AM335X_DMTIMER2_BASE 0x48040000
237 /* DMTimer2 Registers */
238#define AM335X_DMTIMER3_BASE 0x48042000
239 /* DMTimer3 Registers */
240#define AM335X_DMTIMER4_BASE 0x48044000
241 /* DMTimer4 Registers */
242#define AM335X_DMTIMER5_BASE 0x48046000
243 /* DMTimer5 Registers */
244#define AM335X_DMTIMER6_BASE 0x48048000
245 /* DMTimer6 Registers */
246#define AM335X_DMTIMER7_BASE 0x4804A000
247 /* DMTimer7 Registers */
248
249/* General-purpose timer registers
250 AM335x non 1MS timers have different offsets */
251#define AM335X_TIMER_TIDR 0x000
252 /* IP revision code */
253#define AM335X_TIMER_TIOCP_CFG 0x010
254 /* Controls params for GP timer L4 interface */
255#define AM335X_TIMER_IRQSTATUS_RAW 0x024
256 /* Timer IRQSTATUS Raw Register */
257#define AM335X_TIMER_IRQSTATUS 0x028
258 /* Timer IRQSTATUS Register */
259#define AM335X_TIMER_IRQENABLE_SET 0x02C
260 /* Timer IRQENABLE Set Register */
261#define AM335X_TIMER_IRQENABLE_CLR 0x030
262 /* Timer IRQENABLE Clear Register */
263#define AM335X_TIMER_IRQWAKEEN 0x034
264 /* Timer IRQ Wakeup Enable Register */
265#define AM335X_TIMER_TCLR 0x038
266 /* Controls optional features */
267#define AM335X_TIMER_TCRR 0x03C
268 /* Internal counter value */
269#define AM335X_TIMER_TLDR 0x040
270 /* Timer load value */
271#define AM335X_TIMER_TTGR 0x044
272 /* Triggers counter reload */
273#define AM335X_TIMER_TWPS 0x048
274 /* Indicates if Write-Posted pending */
275#define AM335X_TIMER_TMAR 0x04C
276 /* Value to be compared with counter */
277#define AM335X_TIMER_TCAR1 0x050
278 /* First captured value of counter register */
279#define AM335X_TIMER_TSICR 0x054
280 /* Control posted mode and functional SW reset */
281#define AM335X_TIMER_TCAR2 0x058
282 /* Second captured value of counter register */
283#define AM335X_WDT_BASE 0x44E35000
284 /* Watchdog timer */
285#define AM335X_WDT_WWPS 0x34
286 /* Command posted status */
287#define AM335X_WDT_WSPR 0x48
288 /* Activate/deactivate sequence */
289
290/* RTC registers */
291#define AM335X_RTC_BASE 0x44E3E000
292#define AM335X_RTC_SECS 0x0
293#define AM335X_RTC_MINS 0x4
294#define AM335X_RTC_HOURS 0x8
295#define AM335X_RTC_DAYS 0xc
296#define AM335X_RTC_MONTHS 0x10
297#define AM335X_RTC_YEARS 0x14
298#define AM335X_RTC_WEEKS 0x18
299#define AM335X_RTC_CTRL_REG 0x40
300#define AM335X_RTC_STATUS_REG 0x44
301#define AM335X_RTC_REV_REG 0x74
302#define AM335X_RTC_SYSCONFIG 0x78
303#define AM335X_RTC_KICK0 0x6c
304#define AM335X_RTC_KICK1 0x70
305#define AM335X_RTC_OSC_CLOCK 0x54
306
307#define AM335X_RTC_KICK0_KEY 0x83E70B13
308#define AM335X_RTC_KICK1_KEY 0x95A4F1E0
309
310/* GPIO memory-mapped registers */
311
312#define AM335X_GPIO0_BASE 0x44E07000
313 /* GPIO Bank 0 base Register */
314#define AM335X_GPIO1_BASE 0x4804C000
315 /* GPIO Bank 1 base Register */
316#define AM335X_GPIO2_BASE 0x481AC000
317 /* GPIO Bank 2 base Register */
318#define AM335X_GPIO3_BASE 0x481AE000
319 /* GPIO Bank 3 base Register */
320
321#define AM335X_GPIO_REVISION 0x00
322#define AM335X_GPIO_SYSCONFIG 0x10
323#define AM335X_GPIO_EOI 0x20
324#define AM335X_GPIO_IRQSTATUS_RAW_0 0x24
325#define AM335X_GPIO_IRQSTATUS_RAW_1 0x28
326#define AM335X_GPIO_IRQSTATUS_0 0x2C
327#define AM335X_GPIO_IRQSTATUS_1 0x30
328#define AM335X_GPIO_IRQSTATUS_SET_0 0x34
329#define AM335X_GPIO_IRQSTATUS_SET_1 0x38
330#define AM335X_GPIO_IRQSTATUS_CLR_0 0x3C
331#define AM335X_GPIO_IRQSTATUS_CLR_1 0x40
332#define AM335X_GPIO_IRQWAKEN_0 0x44
333#define AM335X_GPIO_IRQWAKEN_1 0x48
334#define AM335X_GPIO_SYSSTATUS 0x114
335#define AM335X_GPIO_CTRL 0x130
336#define AM335X_GPIO_OE 0x134
337#define AM335X_GPIO_DATAIN 0x138
338#define AM335X_GPIO_DATAOUT 0x13C
339#define AM335X_GPIO_LEVELDETECT0 0x140
340#define AM335X_GPIO_LEVELDETECT1 0x144
341#define AM335X_GPIO_RISINGDETECT 0x148
342#define AM335X_GPIO_FALLINGDETECT 0x14C
343#define AM335X_GPIO_DEBOUNCENABLE 0x150
344#define AM335X_GPIO_DEBOUNCINGTIME 0x154
345#define AM335X_GPIO_CLEARDATAOUT 0x190
346#define AM335X_GPIO_SETDATAOUT 0x194
347
348/* AM335X Pad Configuration Register Base */
349#define AM335X_PADCONF_BASE 0x44E10000
350
351/* Memory mapped register offset for Control Module */
352#define AM335X_CONF_GPMC_AD0 0x800
353#define AM335X_CONF_GPMC_AD1 0x804
354#define AM335X_CONF_GPMC_AD2 0x808
355#define AM335X_CONF_GPMC_AD3 0x80C
356#define AM335X_CONF_GPMC_AD4 0x810
357#define AM335X_CONF_GPMC_AD5 0x814
358#define AM335X_CONF_GPMC_AD6 0x818
359#define AM335X_CONF_GPMC_AD7 0x81C
360#define AM335X_CONF_GPMC_AD8 0x820
361#define AM335X_CONF_GPMC_AD9 0x824
362#define AM335X_CONF_GPMC_AD10 0x828
363#define AM335X_CONF_GPMC_AD11 0x82C
364#define AM335X_CONF_GPMC_AD12 0x830
365#define AM335X_CONF_GPMC_AD13 0x834
366#define AM335X_CONF_GPMC_AD14 0x838
367#define AM335X_CONF_GPMC_AD15 0x83C
368#define AM335X_CONF_GPMC_A0 0x840
369#define AM335X_CONF_GPMC_A1 0x844
370#define AM335X_CONF_GPMC_A2 0x848
371#define AM335X_CONF_GPMC_A3 0x84C
372#define AM335X_CONF_GPMC_A4 0x850
373#define AM335X_CONF_GPMC_A5 0x854
374#define AM335X_CONF_GPMC_A6 0x858
375#define AM335X_CONF_GPMC_A7 0x85C
376#define AM335X_CONF_GPMC_A8 0x860
377#define AM335X_CONF_GPMC_A9 0x864
378#define AM335X_CONF_GPMC_A10 0x868
379#define AM335X_CONF_GPMC_A11 0x86C
380#define AM335X_CONF_GPMC_WAIT0 0x870
381#define AM335X_CONF_GPMC_WPN 0x874
382#define AM335X_CONF_GPMC_BEN1 0x878
383#define AM335X_CONF_GPMC_CSN0 0x87C
384#define AM335X_CONF_GPMC_CSN1 0x880
385#define AM335X_CONF_GPMC_CSN2 0x884
386#define AM335X_CONF_GPMC_CSN3 0x888
387#define AM335X_CONF_GPMC_CLK 0x88C
388#define AM335X_CONF_GPMC_ADVN_ALE 0x890
389#define AM335X_CONF_GPMC_OEN_REN 0x894
390#define AM335X_CONF_GPMC_WEN 0x898
391#define AM335X_CONF_GPMC_BEN0_CLE 0x89C
392#define AM335X_CONF_LCD_DATA0 0x8A0
393#define AM335X_CONF_LCD_DATA1 0x8A4
394#define AM335X_CONF_LCD_DATA2 0x8A8
395#define AM335X_CONF_LCD_DATA3 0x8AC
396#define AM335X_CONF_LCD_DATA4 0x8B0
397#define AM335X_CONF_LCD_DATA5 0x8B4
398#define AM335X_CONF_LCD_DATA6 0x8B8
399#define AM335X_CONF_LCD_DATA7 0x8BC
400#define AM335X_CONF_LCD_DATA8 0x8C0
401#define AM335X_CONF_LCD_DATA9 0x8C4
402#define AM335X_CONF_LCD_DATA10 0x8C8
403#define AM335X_CONF_LCD_DATA11 0x8CC
404#define AM335X_CONF_LCD_DATA12 0x8D0
405#define AM335X_CONF_LCD_DATA13 0x8D4
406#define AM335X_CONF_LCD_DATA14 0x8D8
407#define AM335X_CONF_LCD_DATA15 0x8DC
408#define AM335X_CONF_LCD_VSYNC 0x8E0
409#define AM335X_CONF_LCD_HSYNC 0x8E4
410#define AM335X_CONF_LCD_PCLK 0x8E8
411#define AM335X_CONF_LCD_AC_BIAS_EN 0x8EC
412#define AM335X_CONF_MMC0_DAT3 0x8F0
413#define AM335X_CONF_MMC0_DAT2 0x8F4
414#define AM335X_CONF_MMC0_DAT1 0x8F8
415#define AM335X_CONF_MMC0_DAT0 0x8FC
416#define AM335X_CONF_MMC0_CLK 0x900
417#define AM335X_CONF_MMC0_CMD 0x904
418#define AM335X_CONF_MII1_COL 0x908
419#define AM335X_CONF_MII1_CRS 0x90C
420#define AM335X_CONF_MII1_RX_ER 0x910
421#define AM335X_CONF_MII1_TX_EN 0x914
422#define AM335X_CONF_MII1_RX_DV 0x918
423#define AM335X_CONF_MII1_TXD3 0x91C
424#define AM335X_CONF_MII1_TXD2 0x920
425#define AM335X_CONF_MII1_TXD1 0x924
426#define AM335X_CONF_MII1_TXD0 0x928
427#define AM335X_CONF_MII1_TX_CLK 0x92C
428#define AM335X_CONF_MII1_RX_CLK 0x930
429#define AM335X_CONF_MII1_RXD3 0x934
430#define AM335X_CONF_MII1_RXD2 0x938
431#define AM335X_CONF_MII1_RXD1 0x93C
432#define AM335X_CONF_MII1_RXD0 0x940
433#define AM335X_CONF_RMII1_REF_CLK 0x944
434#define AM335X_CONF_MDIO 0x948
435#define AM335X_CONF_MDC 0x94C
436#define AM335X_CONF_SPI0_SCLK 0x950
437#define AM335X_CONF_SPI0_D0 0x954
438#define AM335X_CONF_SPI0_D1 0x958
439#define AM335X_CONF_SPI0_CS0 0x95C
440#define AM335X_CONF_SPI0_CS1 0x960
441#define AM335X_CONF_ECAP0_IN_PWM0_OUT 0x964
442#define AM335X_CONF_UART0_CTSN 0x968
443#define AM335X_CONF_UART0_RTSN 0x96C
444#define AM335X_CONF_UART0_RXD 0x970
445#define AM335X_CONF_UART0_TXD 0x974
446#define AM335X_CONF_UART1_CTSN 0x978
447#define AM335X_CONF_UART1_RTSN 0x97C
448#define AM335X_CONF_UART1_RXD 0x980
449#define AM335X_CONF_UART1_TXD 0x984
450#define AM335X_CONF_I2C0_SDA 0x988
451#define AM335X_CONF_I2C0_SCL 0x98C
452#define AM335X_CONF_MCASP0_ACLKX 0x990
453#define AM335X_CONF_MCASP0_FSX 0x994
454#define AM335X_CONF_MCASP0_AXR0 0x998
455#define AM335X_CONF_MCASP0_AHCLKR 0x99C
456#define AM335X_CONF_MCASP0_ACLKR 0x9A0
457#define AM335X_CONF_MCASP0_FSR 0x9A4
458#define AM335X_CONF_MCASP0_AXR1 0x9A8
459#define AM335X_CONF_MCASP0_AHCLKX 0x9AC
460#define AM335X_CONF_XDMA_EVENT_INTR0 0x9B0
461#define AM335X_CONF_XDMA_EVENT_INTR1 0x9B4
462#define AM335X_CONF_WARMRSTN 0x9B8
463#define AM335X_CONF_NNMI 0x9C0
464#define AM335X_CONF_TMS 0x9D0
465#define AM335X_CONF_TDI 0x9D4
466#define AM335X_CONF_TDO 0x9D8
467#define AM335X_CONF_TCK 0x9DC
468#define AM335X_CONF_TRSTN 0x9E0
469#define AM335X_CONF_EMU0 0x9E4
470#define AM335X_CONF_EMU1 0x9E8
471#define AM335X_CONF_RTC_PWRONRSTN 0x9F8
472#define AM335X_CONF_PMIC_POWER_EN 0x9FC
473#define AM335X_CONF_EXT_WAKEUP 0xA00
474#define AM335X_CONF_RTC_KALDO_ENN 0xA04
475#define AM335X_CONF_USB0_DRVVBUS 0xA1C
476#define AM335X_CONF_USB1_DRVVBUS 0xA34
477
478/* Registers for PWM Subsystem */
479#define AM335X_PWMSS_CTRL (0x664)
480#define AM335X_CM_PER_EPWMSS0_CLKCTRL (0xD4)
481#define AM335X_CM_PER_EPWMSS1_CLKCTRL (0xCC)
482#define AM335X_CM_PER_EPWMSS2_CLKCTRL (0xD8)
483#define AM335X_CONTROL_MODULE (0x44e10000)
484#define AM335X_CM_PER_ADDR (0x44e00000)
485#define AM335X_PWMSS_CLKSTATUS (0xC)
486#define AM335X_PWMSS0_MMAP_ADDR 0x48300000
487#define AM335X_PWMSS1_MMAP_ADDR 0x48302000
488#define AM335X_PWMSS2_MMAP_ADDR 0x48304000
489#define AM335X_PWMSS_MMAP_LEN 0x1000
490#define AM335X_PWMSS_IDVER 0x0
491#define AM335X_PWMSS_SYSCONFIG 0x4
492#define AM335X_PWMSS_CLKCONFIG 0x8
493#define AM335X_PWMSS_CLK_EN_ACK 0x100
494#define AM335X_EPWM_TBCTL 0x0
495#define AM335X_EPWM_TBSTS 0x2
496#define AM335X_EPWM_TBPHSHR 0x4
497#define AM335X_EPWM_TBPHS 0x6
498#define AM335X_EPWM_TBCNT 0x8
499#define AM335X_EPWM_TBPRD 0xA
500#define AM335X_EPWM_CMPCTL 0xE
501#define AM335X_EPWM_CMPAHR 0x10
502#define AM335X_EPWM_CMPA 0x12
503#define AM335X_EPWM_CMPB 0x14
504#define AM335X_EPWM_AQCTLA 0x16
505#define AM335X_EPWM_AQCTLB 0x18
506#define AM335X_EPWM_AQSFRC 0x1A
507#define AM335X_EPWM_AQCSFRC 0x1C
508#define AM335X_EPWM_DBCTL 0x1E
509#define AM335X_EPWM_DBRED 0x20
510#define AM335X_EPWM_DBFED 0x22
511#define AM335X_TBCTL_CTRMODE_UP 0x0
512#define AM335X_TBCTL_CTRMODE_DOWN 0x1
513#define AM335X_TBCTL_CTRMODE_UPDOWN 0x2
514#define AM335X_TBCTL_CTRMODE_FREEZE 0x3
515#define AM335X_EPWM_AQCTLA_ZRO_XALOW (0x0001u)
516#define AM335X_EPWM_AQCTLA_ZRO_XAHIGH (0x0002u)
517#define AM335X_EPWM_AQCTLA_CAU_EPWMXATOGGLE (0x0003u)
518#define AM335X_EPWM_AQCTLA_CAU_SHIFT (0x0004u)
519#define AM335X_EPWM_AQCTLA_ZRO_XBLOW (0x0001u)
520#define AM335X_EPWM_AQCTLB_ZRO_XBHIGH (0x0002u)
521#define AM335X_EPWM_AQCTLB_CBU_EPWMXBTOGGLE (0x0003u)
522#define AM335X_EPWM_AQCTLB_CBU_SHIFT (0x0008u)
523#define AM335X_EPWM_TBCTL_CTRMODE_STOPFREEZE (0x0003u)
524#define AM335X_PWMSS_CTRL_PWMSS0_TBCLKEN (0x00000001u)
525#define AM335X_PWMSS_CTRL_PWMSS1_TBCLKEN (0x00000002u)
526#define AM335X_PWMSS_CTRL_PWMSS2_TBCLKEN (0x00000004u)
527#define AM335X_CM_PER_EPWMSS0_CLKCTRL_MODULEMODE_ENABLE (0x2u)
528#define AM335X_CM_PER_EPWMSS1_CLKCTRL_MODULEMODE_ENABLE (0x2u)
529#define AM335X_CM_PER_EPWMSS2_CLKCTRL_MODULEMODE_ENABLE (0x2u)
530#define AM335X_TBCTL_CLKDIV_MASK (3 << 10)
531#define AM335X_TBCTL_HSPCLKDIV_MASK (3 << 7)
532#define AM335X_EPWM_TBCTL_CLKDIV (0x1C00u)
533#define AM335X_EPWM_TBCTL_CLKDIV_SHIFT (0x000Au)
534#define AM335X_EPWM_TBCTL_HSPCLKDIV (0x0380u)
535#define AM335X_EPWM_TBCTL_HSPCLKDIV_SHIFT (0x0007u)
536#define AM335X_EPWM_TBCTL_PRDLD (0x0008u)
537#define AM335X_EPWM_PRD_LOAD_SHADOW_MASK AM335X_EPWM_TBCTL_PRDLD
538#define AM335X_EPWM_SHADOW_WRITE_ENABLE 0x0
539#define AM335X_EPWM_SHADOW_WRITE_DISABLE 0x1
540#define AM335X_EPWM_TBCTL_PRDLD_SHIFT (0x0003u)
541#define AM335X_EPWM_TBCTL_CTRMODE (0x0003u)
542#define AM335X_EPWM_COUNTER_MODE_MASK AM335X_EPWM_TBCTL_CTRMODE
543#define AM335X_TBCTL_FREERUN (2 << 14)
544#define AM335X_TBCTL_CTRMODE_SHIFT (0x0000u)
545#define AM335X_EPWM_COUNT_UP (AM335X_TBCTL_CTRMODE_UP << \
546 AM335X_TBCTL_CTRMODE_SHIFT)
547
548#define AM335X_EPWM_REGS (0x00000200)
549#define AM335X_EPWM_0_REGS (AM335X_PWMSS0_MMAP_ADDR + AM335X_EPWM_REGS)
550#define AM335X_EPWM_1_REGS (AM335X_PWMSS1_MMAP_ADDR + AM335X_EPWM_REGS)
551#define AM335X_EPWM_2_REGS (AM335X_PWMSS2_MMAP_ADDR + AM335X_EPWM_REGS)
552
553#define AM335X_CM_PER_EPWMSS0_CLKCTRL_MODULEMODE (0x00000003u)
554#define AM335X_CM_PER_EPWMSS0_CLKCTRL_IDLEST_FUNC (0x0u)
555#define AM335X_CM_PER_EPWMSS0_CLKCTRL_IDLEST_SHIFT (0x00000010u)
556#define AM335X_CM_PER_EPWMSS0_CLKCTRL_IDLEST (0x00030000u)
557
558#define AM335X_CM_PER_EPWMSS1_CLKCTRL_MODULEMODE (0x00000003u)
559#define AM335X_CM_PER_EPWMSS1_CLKCTRL_IDLEST (0x00030000u)
560#define AM335X_CM_PER_EPWMSS1_CLKCTRL_IDLEST_FUNC (0x0u)
561#define AM335X_CM_PER_EPWMSS1_CLKCTRL_IDLEST_SHIFT (0x00000010u)
562
563#define AM335X_CM_PER_EPWMSS2_CLKCTRL_MODULEMODE (0x00000003u)
564#define AM335X_CM_PER_EPWMSS2_CLKCTRL_IDLEST_FUNC (0x0u)
565#define AM335X_CM_PER_EPWMSS2_CLKCTRL_IDLEST_SHIFT (0x00000010u)
566#define AM335X_CM_PER_EPWMSS2_CLKCTRL_IDLEST (0x00030000u)
567
568
569
570/* I2C registers */
571#define AM335X_I2C0_BASE 0x44e0b000
572 /* I2C0 base address */
573#define AM335X_I2C1_BASE 0x4802a000
574 /* I2C1 base address */
575#define AM335X_I2C2_BASE 0x4819c000
576 /* I2C2 base address */
577#define AM335X_I2C_REVNB_LO 0x00
578 /* Module Revision Register (low bytes) */
579#define AM335X_I2C_REVNB_HI 0x04
580 /* Module Revision Register (high bytes) */
581#define AM335X_I2C_SYSC 0x10
582 /* System Configuration Register */
583#define AM335X_I2C_IRQSTATUS_RAW 0x24
584 /* I2C Status Raw Register */
585#define AM335X_I2C_IRQSTATUS 0x28
586 /* I2C Status Register */
587#define AM335X_I2C_IRQENABLE_SET 0x2c
588 /* I2C Interrupt Enable Set Register */
589#define AM335X_I2C_IRQENABLE_CLR 0x30
590 /* I2C Interrupt Enable Clear Register */
591#define AM335X_I2C_WE 0x34
592 /* I2C Wakeup Enable Register */
593#define AM335X_I2C_DMARXENABLE_SET 0x38
594 /* Receive DMA Enable Set Register */
595#define AM335X_I2C_DMATXENABLE_SET 0x3c
596 /* Transmit DMA Enable Set Register */
597#define AM335X_I2C_DMARXENABLE_CLR 0x40
598 /* Receive DMA Enable Clear Register */
599#define AM335X_I2C_DMATXENABLE_CLR 0x44
600 /* Transmit DMA Enable Clear Register */
601#define AM335X_I2C_DMARXWAKE_EN 0x48
602 /* Receive DMA Wakeup Register */
603#define AM335X_I2C_DMATXWAKE_EN 0x4c
604 /* Transmit DMA Wakeup Register */
605#define AM335X_I2C_SYSS 0x90
606 /* System Status Register */
607#define AM335X_I2C_BUF 0x94
608 /* Buffer Configuration Register */
609#define AM335X_I2C_CNT 0x98
610 /* Data Counter Register */
611#define AM335X_I2C_DATA 0x9c
612 /* Data Access Register */
613#define AM335X_I2C_CON 0xa4
614 /* I2C Configuration Register */
615#define AM335X_I2C_OA 0xa8
616 /* I2C Own Address Register */
617#define AM335X_I2C_SA 0xac
618 /* I2C Slave Address Register */
619#define AM335X_I2C_PSC 0xb0
620 /* I2C Clock Prescaler Register */
621#define AM335X_I2C_SCLL 0xb4
622 /* I2C SCL Low Time Register */
623#define AM335X_I2C_SCLH 0xb8
624 /* I2C SCL High Time Register */
625#define AM335X_I2C_SYSTEST 0xbc
626 /* System Test Register */
627#define AM335X_I2C_BUFSTAT 0xc0
628 /* I2C Buffer Status Register */
629#define AM335X_I2C_OA1 0xc4
630 /* I2C Own Address 1 Register */
631#define AM335X_I2C_OA2 0xc8
632 /* I2C Own Address 2 Register */
633#define AM335X_I2C_OA3 0xcc
634 /* I2C Own Address 3 Register */
635#define AM335X_I2C_ACTOA 0xd0
636 /* Active Own Address Register */
637#define AM335X_I2C_SBLOCK 0xd4
638 /* I2C Clock Blocking Enable Register */
639
640#define AM335X_CM_PER_L4LS_CLKSTCTRL (0x0)
641#define AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP (0x2u)
642#define AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL (0x00000003u)
643#define AM335X_CM_PER_L4LS_CLKCTRL (0x60)
644#define AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE (0x2u)
645#define AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE (0x00000003u)
646#define AM335X_CM_PER_I2C1_CLKCTRL (0x48)
647#define AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE_ENABLE (0x2u)
648#define AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE (0x00000003u)
649#define AM335X_CM_PER_I2C2_CLKCTRL (0x44)
650#define AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE_ENABLE (0x2u)
651#define AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE (0x00000003u)
652#define AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_L4LS_GCLK (0x00000100u)
653#define AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_I2C_FCLK (0x01000000u)
654#define AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE (0x00000003u)
655#define AM335X_CM_PER_SPI0_CLKCTRL (0x4c)
656#define AM335X_CM_PER_SPI0_CLKCTRL_MODULEMODE_ENABLE (0x2u)
657#define AM335X_CM_PER_SPI0_CLKCTRL_MODULEMODE (0x00000003u)
658#define AM335X_I2C_CON_XSA (0x00000100u)
659#define AM335X_I2C_CFG_10BIT_SLAVE_ADDR AM335X_I2C_CON_XSA
660#define AM335X_I2C_CON_XSA_SHIFT (0x00000008u)
661#define AM335X_I2C_CFG_7BIT_SLAVE_ADDR (0 << AM335X_I2C_CON_XSA_SHIFT)
662#define AM335X_I2C_CON_I2C_EN (0x00008000u)
663#define AM335X_I2C_CON_TRX (0x00000200u)
664#define AM335X_I2C_CON_MST (0x00000400u)
665#define AM335X_I2C_CON_STB (0x00000800u)
666#define AM335X_I2C_SYSC_AUTOIDLE (0x00000001u)
667#define AM335X_I2C_SYSC_SRST (0x00000002u)
668#define AM335X_I2C_SYSC_ENAWAKEUP (0x00000004u)
669#define AM335X_I2C_SYSS_RDONE (0x00000001u)
670
671/*I2C0 module clock registers*/
672#define AM335X_CM_WKUP_CONTROL_CLKCTRL (0x4)
673#define AM335X_CM_WKUP_CLKSTCTRL (0x0)
674#define AM335X_CM_WKUP_I2C0_CLKCTRL (0xb8)
675#define AM335X_CM_WKUP_I2C0_CLKCTRL_MODULEMODE_ENABLE (0x2u)
676#define AM335X_CM_WKUP_I2C0_CLKCTRL_MODULEMODE (0x00000003u)
677#define AM335X_CM_WKUP_CONTROL_CLKCTRL_IDLEST_FUNC (0x0u)
678#define AM335X_CM_WKUP_CONTROL_CLKCTRL_IDLEST_SHIFT (0x00000010u)
679#define AM335X_CM_WKUP_CONTROL_CLKCTRL_IDLEST (0x00030000u)
680#define AM335X_CM_WKUP_CLKSTCTRL_CLKACTIVITY_I2C0_GFCLK (0x00000800u)
681#define AM335X_CM_WKUP_I2C0_CLKCTRL_IDLEST_FUNC (0x0u)
682#define AM335X_CM_WKUP_I2C0_CLKCTRL_IDLEST_SHIFT (0x00000010u)
683#define AM335X_CM_WKUP_I2C0_CLKCTRL_IDLEST (0x00030000u)
684#define AM335X_SOC_CM_WKUP_REGS (AM335X_CM_PER_ADDR + 0x400)
685
686/* SPI0 module clock registers */
687#define AM335X_CM_PER_CONTROL_CLKCTRL_IDLEST_FUNC (0x0u)
688#define AM335X_CM_PER_CONTROL_CLKCTRL_IDLEST_SHIFT (0x00000010u)
689#define AM335X_CM_PER_CONTROL_CLKCTRL_IDLEST (0x00030000u)
690
691
692#define AM335X_I2C_BUF_TXTRSH_SHIFT (0)
693#define AM335X_I2C_BUF_TXTRSH_MASK (0x0000003Fu)
694#define AM335X_I2C_BUF_TXTRSH(X) (((X) << AM335X_I2C_BUF_TXTRSH_SHIFT) \
695 & AM335X_I2C_BUF_TXTRSH_MASK)
696#define AM335X_I2C_BUF_TXFIFO_CLR (0x00000040u)
697#define AM335X_I2C_BUF_RXTRSH_SHIFT (8)
698#define AM335X_I2C_BUF_RXTRSH_MASK (0x00003F00u)
699#define AM335X_I2C_BUF_RXTRSH(X) (((X) << AM335X_I2C_BUF_RXTRSH_SHIFT) \
700 & AM335X_I2C_BUF_RXTRSH_MASK)
701#define AM335X_I2C_BUF_RXFIFO_CLR (0x00004000u)
702
703/* I2C status Register */
704#define AM335X_I2C_IRQSTATUS_AL (1 << 0)
705#define AM335X_I2C_IRQSTATUS_NACK (1 << 1)
706#define AM335X_I2C_IRQSTATUS_ARDY (1 << 2)
707#define AM335X_I2C_IRQSTATUS_RRDY (1 << 3)
708#define AM335X_I2C_IRQSTATUS_XRDY (1 << 4)
709#define AM335X_I2C_IRQSTATUS_GC (1 << 5)
710#define AM335X_I2C_IRQSTATUS_STC (1 << 6)
711#define AM335X_I2C_IRQSTATUS_AERR (1 << 7)
712#define AM335X_I2C_IRQSTATUS_BF (1 << 8)
713#define AM335X_I2C_IRQSTATUS_AAS (1 << 9)
714#define AM335X_I2C_IRQSTATUS_XUDF (1 << 10)
715#define AM335X_I2C_IRQSTATUS_ROVR (1 << 11)
716#define AM335X_I2C_IRQSTATUS_BB (1 << 12)
717#define AM335X_I2C_IRQSTATUS_RDR (1 << 13)
718#define AM335X_I2C_IRQSTATUS_XDR (1 << 14)
719
720#define AM335X_I2C_INT_RECV_READY AM335X_I2C_IRQSTATUS_RRDY
721#define AM335X_I2C_CON_STOP (0x00000002u)
722#define AM335X_I2C_CON_START (0x00000001u)
723#define AM335X_I2C_CFG_MST_RX AM335X_I2C_CON_MST
724#define AM335X_I2C_CFG_MST_TX (AM335X_I2C_CON_TRX | AM335X_I2C_CON_MST)
725#define AM335X_CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L4_GCLK (0x00000020u)
726#define AM335X_I2C_INT_STOP_CONDITION AM335X_I2C_IRQSTATUS_BF
727
728
729/* SPI registers */
730#define AM335X_SPI0_BASE 0x48030000
731 /* SPI0 base address */
732#define AM335X_SPI1_BASE 0x481A0000
733 /* SPI1 base address */
734
735#define AM335X_SPI_REVISION 0x000
736#define AM335X_SPI_SYSCONFIG 0x110
737#define AM335X_SPI_SYSSTATUS 0x114
738#define AM335X_SPI_IRQSTATUS 0x118
739#define AM335X_SPI_IRQENABLE 0x11c
740#define AM335X_SPI_WAKEUPENABLE 0x120
741#define AM335X_SPI_SYST 0x124
742#define AM335X_SPI_MODULCTRL 0x128
743#define AM335X_SPI_CH0CONF 0x12c
744#define AM335X_SPI_CH0STAT 0x130
745#define AM335X_SPI_CH0CTRL 0x134
746#define AM335X_SPI_TX0 0x138
747#define AM335X_SPI_RX0 0x13C
748#define AM335X_SPI_XFERLEVEL 0x17c
749
750/* SPI sysconfig Register */
751#define AM335X_SPI_SYSCONFIG_SOFTRESET (1 << 1)
752
753/* SPI sysstatus Register */
754#define AM335X_SPI_SYSSTATUS_RESETDONE (1 << 0)
755
756/* SPI interrupt status Register */
757#define AM335X_SPI_IRQSTATUS_TX0_EMPTY (1 << 0)
758#define AM335X_SPI_IRQSTATUS_RX0_FULL (1 << 2)
759
760/* SPI interrupt enable Register */
761#define AM335X_SPI_IRQENABLE_TX0_EMPTY (1 << 0)
762#define AM335X_SPI_IRQENABLE_RX0_FULL (1 << 2)
763
764/* SPI system Register */
765#define AM335X_SPI_SYST_SPIEN_0 (1 << 0)
766#define AM335X_SPI_SYST_SPIDAT_0 (1 << 4)
767#define AM335X_SPI_SYST_SPIDAT_1 (1 << 5)
768#define AM335X_SPI_SYST_SPIDATDIR0 (1 << 8)
769#define AM335X_SPI_SYST_SPIDATDIR1 (1 << 9)
770#define AM335X_SPI_SYST_SSB (1 << 11)
771
772/* SPI modulctrl Register */
773#define AM335X_SPI_MODULCTRL_SINGLE (1 << 0)
774#define AM335X_SPI_MODULCTRL_PIN34 (1 << 1)
775#define AM335X_SPI_MODULCTRL_MS (1 << 2)
776
777/* SPI Channel 0 Configuration Register */
778#define AM335X_SPI_CH0CONF_PHA (1 << 0)
779#define AM335X_SPI_CH0CONF_POL (1 << 1)
780#define AM335X_SPI_CH0CONF_CLKD_SHIFT 2
781#define AM335X_SPI_CH0CONF_CLKD_WIDTH 4
782#define AM335X_SPI_CH0CONF_CLKD_MASK AM335X_MASK(AM335X_SPI_CH0CONF_CLKD_SHIFT, AM335X_SPI_CH0CONF_CLKD_WIDTH)
783#define AM335X_SPI_CH0CONF_CLKD(X) (((X) << AM335X_SPI_CH0CONF_CLKD_SHIFT) & AM335X_SPI_CH0CONF_CLKD_MASK)
784#define AM335X_SPI_CH0CONF_EPOL (1 << 6)
785#define AM335X_SPI_CH0CONF_WL_SHIFT 7
786#define AM335X_SPI_CH0CONF_WL_WIDTH 5
787#define AM335X_SPI_CH0CONF_WL_MASK AM335X_MASK(AM335X_SPI_CH0CONF_WL_SHIFT, AM335X_SPI_CH0CONF_WL_WIDTH)
788#define AM335X_SPI_CH0CONF_WL(X) (((X) << AM335X_SPI_CH0CONF_WL_SHIFT) & AM335X_SPI_CH0CONF_WL_MASK)
789#define AM335X_SPI_CH0CONF_TRM_SHIFT 12
790#define AM335X_SPI_CH0CONF_TRM_WIDTH 2
791#define AM335X_SPI_CH0CONF_TRM_MASK AM335X_MASK(AM335X_SPI_CH0CONF_TRM_SHIFT, AM335X_SPI_CH0CONF_TRM_WIDTH)
792#define AM335X_SPI_CH0CONF_TRM(X) (((X) << AM335X_SPI_CH0CONF_TRM_SHIFT) & AM335X_SPI_CH0CONF_TRM_MASK)
793#define AM335X_SPI_CH0CONF_DPE0 (1 << 16)
794#define AM335X_SPI_CH0CONF_DPE1 (1 << 17)
795#define AM335X_SPI_CH0CONF_IS (1 << 18)
796#define AM335X_SPI_CH0CONF_FORCE (1 << 20)
797#define AM335X_SPI_CH0CONF_SBPOL (1 << 27)
798#define AM335X_SPI_CH0CONF_FFEW (1 << 27)
799#define AM335X_SPI_CH0CONF_FFER (1 << 28)
800
801/* SPI Channel 0 Status Register */
802#define AM335X_SPI_CH0STAT_RXS (1 << 0)
803#define AM335X_SPI_CH0STAT_TXS (1 << 1)
804
805/* SPI Channel 0 Control Register */
806#define AM335X_SPI_CH0CTRL_EN (1 << 0)
807
808#endif
