RTEMS 6.2
181#define ACPI_OS_NAME "Microsoft Windows NT"
185#define ACPI_MAX_STATE_CACHE_DEPTH 96
186#define ACPI_MAX_PARSE_CACHE_DEPTH 96
187#define ACPI_MAX_EXTPARSE_CACHE_DEPTH 96
188#define ACPI_MAX_OBJECT_CACHE_DEPTH 96
189#define ACPI_MAX_NAMESPACE_CACHE_DEPTH 96
190#define ACPI_MAX_COMMENT_CACHE_DEPTH 96
196#ifndef ACPI_CHECKSUM_ABORT
197#define ACPI_CHECKSUM_ABORT FALSE
215#ifndef ACPI_REDUCED_HARDWARE
216#define ACPI_REDUCED_HARDWARE FALSE
228#define ACPI_CA_SUPPORT_LEVEL 5
232#define ACPI_MAX_SEMAPHORE_COUNT 256
236#define ACPI_MAX_REFERENCE_COUNT 0x4000
240#define ACPI_DEFAULT_PAGE_SIZE 4096
244#define ACPI_NUM_OWNERID_MASKS 128
248#define ACPI_ROOT_TABLE_SIZE_INCREMENT 4
252#define ACPI_MAX_SLEEP 2000
256#define ACPI_ADDRESS_RANGE_MAX 2
260#define ACPI_MAX_LOOP_TIMEOUT 30
271#define ACPI_METHOD_NUM_LOCALS 8
272#define ACPI_METHOD_MAX_LOCAL 7
274#define ACPI_METHOD_NUM_ARGS 7
275#define ACPI_METHOD_MAX_ARG 6
280#define ACPI_OBJ_NUM_OPERANDS 8
281#define ACPI_OBJ_MAX_OPERAND 7
285#define ACPI_RESULTS_FRAME_OBJ_NUM 8
292#define ACPI_RESULTS_OBJ_NUM_MAX 255
296#define ACPI_EBDA_PTR_LOCATION 0x0000040E
297#define ACPI_EBDA_PTR_LENGTH 2
298#define ACPI_EBDA_WINDOW_SIZE 1024
299#define ACPI_HI_RSDP_WINDOW_BASE 0x000E0000
300#define ACPI_HI_RSDP_WINDOW_SIZE 0x00020000
301#define ACPI_RSDP_SCAN_STEP 16
305#define ACPI_USER_REGION_BEGIN 0x80
309#define ACPI_MAX_ADDRESS_SPACE 255
310#define ACPI_NUM_DEFAULT_SPACES 4
314#define ACPI_MAX_MATCH_OPCODE 5
318#define ACPI_RSDP_CHECKSUM_LENGTH 20
319#define ACPI_RSDP_XCHECKSUM_LENGTH 36
325#define ACPI_SERIAL_HEADER_SIZE 2
327#define ACPI_SMBUS_DATA_SIZE 32
328#define ACPI_SMBUS_BUFFER_SIZE ACPI_SERIAL_HEADER_SIZE + ACPI_SMBUS_DATA_SIZE
330#define ACPI_IPMI_DATA_SIZE 64
331#define ACPI_IPMI_BUFFER_SIZE ACPI_SERIAL_HEADER_SIZE + ACPI_IPMI_DATA_SIZE
333#define ACPI_MAX_GSBUS_DATA_SIZE 255
334#define ACPI_MAX_GSBUS_BUFFER_SIZE ACPI_SERIAL_HEADER_SIZE + ACPI_MAX_GSBUS_DATA_SIZE
336#define ACPI_PRM_INPUT_BUFFER_SIZE 26
338#define ACPI_FFH_INPUT_BUFFER_SIZE 256
342#define ACPI_NUM_SxD_METHODS 4
343#define ACPI_NUM_SxW_METHODS 5
354#define UUID_BUFFER_LENGTH 16
355#define UUID_STRING_LENGTH 36
359#define UUID_HYPHEN1_OFFSET 8
360#define UUID_HYPHEN2_OFFSET 13
361#define UUID_HYPHEN3_OFFSET 18
362#define UUID_HYPHEN4_OFFSET 23
371#define ACPI_DEBUGGER_MAX_ARGS ACPI_METHOD_NUM_ARGS + 4
372#define ACPI_DB_LINE_BUFFER_SIZE 512
374#define ACPI_DEBUGGER_COMMAND_PROMPT '-'
375#define ACPI_DEBUGGER_EXECUTE_PROMPT '%'
