RTEMS 6.2
acclib.h
1/******************************************************************************
2 *
3 * Name: acclib.h -- C library support. Prototypes for the (optional) local
4 * implementations of required C library functions.
5 *
6 *****************************************************************************/
7
8/******************************************************************************
9 *
10 * 1. Copyright Notice
11 *
12 * Some or all of this work - Copyright (c) 1999 - 2024, Intel Corp.
13 * All rights reserved.
14 *
15 * 2. License
16 *
17 * 2.1. This is your license from Intel Corp. under its intellectual property
18 * rights. You may have additional license terms from the party that provided
19 * you this software, covering your right to use that party's intellectual
20 * property rights.
21 *
22 * 2.2. Intel grants, free of charge, to any person ("Licensee") obtaining a
23 * copy of the source code appearing in this file ("Covered Code") an
24 * irrevocable, perpetual, worldwide license under Intel's copyrights in the
25 * base code distributed originally by Intel ("Original Intel Code") to copy,
26 * make derivatives, distribute, use and display any portion of the Covered
27 * Code in any form, with the right to sublicense such rights; and
28 *
29 * 2.3. Intel grants Licensee a non-exclusive and non-transferable patent
30 * license (with the right to sublicense), under only those claims of Intel
31 * patents that are infringed by the Original Intel Code, to make, use, sell,
32 * offer to sell, and import the Covered Code and derivative works thereof
33 * solely to the minimum extent necessary to exercise the above copyright
34 * license, and in no event shall the patent license extend to any additions
35 * to or modifications of the Original Intel Code. No other license or right
36 * is granted directly or by implication, estoppel or otherwise;
37 *
38 * The above copyright and patent license is granted only if the following
39 * conditions are met:
40 *
41 * 3. Conditions
42 *
43 * 3.1. Redistribution of Source with Rights to Further Distribute Source.
44 * Redistribution of source code of any substantial portion of the Covered
45 * Code or modification with rights to further distribute source must include
46 * the above Copyright Notice, the above License, this list of Conditions,
47 * and the following Disclaimer and Export Compliance provision. In addition,
48 * Licensee must cause all Covered Code to which Licensee contributes to
49 * contain a file documenting the changes Licensee made to create that Covered
50 * Code and the date of any change. Licensee must include in that file the
51 * documentation of any changes made by any predecessor Licensee. Licensee
52 * must include a prominent statement that the modification is derived,
53 * directly or indirectly, from Original Intel Code.
54 *
55 * 3.2. Redistribution of Source with no Rights to Further Distribute Source.
56 * Redistribution of source code of any substantial portion of the Covered
57 * Code or modification without rights to further distribute source must
58 * include the following Disclaimer and Export Compliance provision in the
59 * documentation and/or other materials provided with distribution. In
60 * addition, Licensee may not authorize further sublicense of source of any
61 * portion of the Covered Code, and must include terms to the effect that the
62 * license from Licensee to its licensee is limited to the intellectual
63 * property embodied in the software Licensee provides to its licensee, and
64 * not to intellectual property embodied in modifications its licensee may
65 * make.
66 *
67 * 3.3. Redistribution of Executable. Redistribution in executable form of any
68 * substantial portion of the Covered Code or modification must reproduce the
69 * above Copyright Notice, and the following Disclaimer and Export Compliance
70 * provision in the documentation and/or other materials provided with the
71 * distribution.
72 *
73 * 3.4. Intel retains all right, title, and interest in and to the Original
74 * Intel Code.
75 *
76 * 3.5. Neither the name Intel nor any other trademark owned or controlled by
77 * Intel shall be used in advertising or otherwise to promote the sale, use or
78 * other dealings in products derived from or relating to the Covered Code
79 * without prior written authorization from Intel.
80 *
81 * 4. Disclaimer and Export Compliance
82 *
83 * 4.1. INTEL MAKES NO WARRANTY OF ANY KIND REGARDING ANY SOFTWARE PROVIDED
84 * HERE. ANY SOFTWARE ORIGINATING FROM INTEL OR DERIVED FROM INTEL SOFTWARE
85 * IS PROVIDED "AS IS," AND INTEL WILL NOT PROVIDE ANY SUPPORT, ASSISTANCE,
86 * INSTALLATION, TRAINING OR OTHER SERVICES. INTEL WILL NOT PROVIDE ANY
87 * UPDATES, ENHANCEMENTS OR EXTENSIONS. INTEL SPECIFICALLY DISCLAIMS ANY
88 * IMPLIED WARRANTIES OF MERCHANTABILITY, NONINFRINGEMENT AND FITNESS FOR A
89 * PARTICULAR PURPOSE.
90 *
91 * 4.2. IN NO EVENT SHALL INTEL HAVE ANY LIABILITY TO LICENSEE, ITS LICENSEES
92 * OR ANY OTHER THIRD PARTY, FOR ANY LOST PROFITS, LOST DATA, LOSS OF USE OR
93 * COSTS OF PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES, OR FOR ANY INDIRECT,
94 * SPECIAL OR CONSEQUENTIAL DAMAGES ARISING OUT OF THIS AGREEMENT, UNDER ANY
95 * CAUSE OF ACTION OR THEORY OF LIABILITY, AND IRRESPECTIVE OF WHETHER INTEL
96 * HAS ADVANCE NOTICE OF THE POSSIBILITY OF SUCH DAMAGES. THESE LIMITATIONS
97 * SHALL APPLY NOTWITHSTANDING THE FAILURE OF THE ESSENTIAL PURPOSE OF ANY
98 * LIMITED REMEDY.
99 *
100 * 4.3. Licensee shall not export, either directly or indirectly, any of this
101 * software or system incorporating such software without first obtaining any
102 * required license or other approval from the U. S. Department of Commerce or
103 * any other agency or department of the United States Government. In the
104 * event Licensee exports any such software from the United States or
105 * re-exports any such software from a foreign destination, Licensee shall
106 * ensure that the distribution and export/re-export of the software is in
107 * compliance with all laws, regulations, orders, or other restrictions of the
108 * U.S. Export Administration Regulations. Licensee agrees that neither it nor
109 * any of its subsidiaries will export/re-export any technical data, process,
110 * software, or service, directly or indirectly, to any country for which the
111 * United States government or any agency thereof requires an export license,
112 * other governmental approval, or letter of assurance, without first obtaining
113 * such license, approval or letter.
114 *
115 *****************************************************************************
116 *
117 * Alternatively, you may choose to be licensed under the terms of the
118 * following license:
119 *
120 * Redistribution and use in source and binary forms, with or without
121 * modification, are permitted provided that the following conditions
122 * are met:
123 * 1. Redistributions of source code must retain the above copyright
124 * notice, this list of conditions, and the following disclaimer,
125 * without modification.
126 * 2. Redistributions in binary form must reproduce at minimum a disclaimer
127 * substantially similar to the "NO WARRANTY" disclaimer below
128 * ("Disclaimer") and any redistribution must be conditioned upon
129 * including a substantially similar Disclaimer requirement for further
130 * binary redistribution.
131 * 3. Neither the names of the above-listed copyright holders nor the names
132 * of any contributors may be used to endorse or promote products derived
133 * from this software without specific prior written permission.
134 *
135 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
136 * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
137 * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
138 * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
139 * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
140 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
141 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
142 * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
143 * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
144 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
145 * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
146 *
147 * Alternatively, you may choose to be licensed under the terms of the
148 * GNU General Public License ("GPL") version 2 as published by the Free
149 * Software Foundation.
150 *
151 *****************************************************************************/
152
153#ifndef _ACCLIB_H
154#define _ACCLIB_H
155
156
157/*
158 * Prototypes and macros for local implementations of C library functions
159 */
160
161/* is* functions. The AcpiGbl_Ctypes array is defined in utclib.c */
162
163extern const UINT8 AcpiGbl_Ctypes[];
164
165#define _ACPI_XA 0x00 /* extra alphabetic - not supported */
166#define _ACPI_XS 0x40 /* extra space */
167#define _ACPI_BB 0x00 /* BEL, BS, etc. - not supported */
168#define _ACPI_CN 0x20 /* CR, FF, HT, NL, VT */
169#define _ACPI_DI 0x04 /* '0'-'9' */
170#define _ACPI_LO 0x02 /* 'a'-'z' */
171#define _ACPI_PU 0x10 /* punctuation */
172#define _ACPI_SP 0x08 /* space, tab, CR, LF, VT, FF */
173#define _ACPI_UP 0x01 /* 'A'-'Z' */
174#define _ACPI_XD 0x80 /* '0'-'9', 'A'-'F', 'a'-'f' */
175
176#define isdigit(c) (AcpiGbl_Ctypes[(unsigned char)(c)] & (_ACPI_DI))
177#define isspace(c) (AcpiGbl_Ctypes[(unsigned char)(c)] & (_ACPI_SP))
178#define isxdigit(c) (AcpiGbl_Ctypes[(unsigned char)(c)] & (_ACPI_XD))
179#define isupper(c) (AcpiGbl_Ctypes[(unsigned char)(c)] & (_ACPI_UP))
180#define islower(c) (AcpiGbl_Ctypes[(unsigned char)(c)] & (_ACPI_LO))
181#define isprint(c) (AcpiGbl_Ctypes[(unsigned char)(c)] & (_ACPI_LO | _ACPI_UP | _ACPI_DI | _ACPI_XS | _ACPI_PU))
182#define isalpha(c) (AcpiGbl_Ctypes[(unsigned char)(c)] & (_ACPI_LO | _ACPI_UP))
183
184/* Error code */
185
186#define EPERM 1 /* Operation not permitted */
187#define ENOENT 2 /* No such file or directory */
188#define EINTR 4 /* Interrupted system call */
189#define EIO 5 /* I/O error */
190#define EBADF 9 /* Bad file number */
191#define EAGAIN 11 /* Try again */
192#define ENOMEM 12 /* Out of memory */
193#define EACCES 13 /* Permission denied */
194#define EFAULT 14 /* Bad address */
195#define EBUSY 16 /* Device or resource busy */
196#define EEXIST 17 /* File exists */
197#define ENODEV 19 /* No such device */
198#define EINVAL 22 /* Invalid argument */
199#define EPIPE 32 /* Broken pipe */
200#define ERANGE 34 /* Math result not representable */
201
202/* Strings */
203
204char *
205strcat (
206 char *DstString,
207 const char *SrcString);
208
209char *
210strchr (
211 const char *String,
212 int ch);
213
214char *
215strpbrk (
216 const char *String,
217 const char *Delimiters);
218
219char *
220strtok (
221 char *String,
222 const char *Delimiters);
223
224char *
225strcpy (
226 char *DstString,
227 const char *SrcString);
228
229int
230strcmp (
231 const char *String1,
232 const char *String2);
233
234ACPI_SIZE
235strlen (
236 const char *String);
237
238char *
239strncat (
240 char *DstString,
241 const char *SrcString,
242 ACPI_SIZE Count);
243
244int
245strncmp (
246 const char *String1,
247 const char *String2,
248 ACPI_SIZE Count);
249
250char *
251strncpy (
252 char *DstString,
253 const char *SrcString,
254 ACPI_SIZE Count);
255
256char *
257strstr (
258 char *String1,
259 char *String2);
260
261
262/* Conversion */
263
264UINT32
265strtoul (
266 const char *String,
267 char **Terminator,
268 UINT32 Base);
269
270
271/* Memory */
272
273int
274memcmp (
275 void *Buffer1,
276 void *Buffer2,
277 ACPI_SIZE Count);
278
279void *
280memcpy (
281 void *Dest,
282 const void *Src,
283 ACPI_SIZE Count);
284
285void *
286memmove (
287 void *Dest,
288 const void *Src,
289 ACPI_SIZE Count);
290
291void *
292memset (
293 void *Dest,
294 int Value,
295 ACPI_SIZE Count);
296
297
298/* upper/lower case */
299
300int
301tolower (
302 int c);
303
304int
305toupper (
306 int c);
307
308/*
309 * utprint - printf/vprintf output functions
310 */
311const char *
312AcpiUtScanNumber (
313 const char *String,
314 UINT64 *NumberPtr);
315
316const char *
317AcpiUtPrintNumber (
318 char *String,
319 UINT64 Number);
320
321int
322vsnprintf (
323 char *String,
324 ACPI_SIZE Size,
325 const char *Format,
326 va_list Args);
327
328int
329snprintf (
330 char *String,
331 ACPI_SIZE Size,
332 const char *Format,
333 ...);
334
335int
336sprintf (
337 char *String,
338 const char *Format,
339 ...);
340
341#ifdef ACPI_APPLICATION
342#define SEEK_SET 0
343#define SEEK_CUR 1
344#define SEEK_END 2
345
346/*
347 * NOTE: Currently we only need to update errno for file IOs. Other
348 * Clibrary invocations in ACPICA do not make decisions according to
349 * the errno.
350 */
351extern int errno;
352
353#ifndef EOF
354#define EOF (-1)
355#endif
356
357#define putchar(c) fputc(stdout, c)
358#define getchar(c) fgetc(stdin)
359
360int
361vprintf (
362 const char *Format,
363 va_list Args);
364
365int
366printf (
367 const char *Format,
368 ...);
369
370int
371vfprintf (
372 FILE *File,
373 const char *Format,
374 va_list Args);
375
376int
377fprintf (
378 FILE *File,
379 const char *Format,
380 ...);
381
382FILE *
383fopen (
384 const char *Path,
385 const char *Modes);
386
387void
388fclose (
389 FILE *File);
390
391int
392fread (
393 void *Buffer,
394 ACPI_SIZE Size,
395 ACPI_SIZE Count,
396 FILE *File);
397
398int
399fwrite (
400 void *Buffer,
401 ACPI_SIZE Size,
402 ACPI_SIZE Count,
403 FILE *File);
404
405int
406fseek (
407 FILE *File,
408 long Offset,
409 int From);
410
411long
412ftell (
413 FILE *File);
414
415int
416fgetc (
417 FILE *File);
418
419int
420fputc (
421 FILE *File,
422 char c);
423
424char *
425fgets (
426 char *s,
427 ACPI_SIZE Size,
428 FILE *File);
429#endif
430
431#endif /* _ACCLIB_H */
