RTEMS 6.1
imx_gpc Struct Reference
uint32_t lpcr_a7_bsc
uint32_t lpcr_a7_ad
uint32_t lpcr_m4
uint32_t reserved_0c [2]
uint32_t slpcr
uint32_t reserved_18 [2]
uint32_t mlpcr
uint32_t pgc_ack_sel_a7
uint32_t pgc_ack_sel_m4
uint32_t misc
uint32_t imr1_core0_a7
uint32_t imr2_core0_a7
uint32_t imr3_core0_a7
uint32_t imr4_core0_a7
uint32_t imr1_core1_a7
uint32_t imr2_core1_a7
uint32_t imr3_core1_a7
uint32_t imr4_core1_a7
uint32_t imr1_m4
uint32_t imr2_m4
uint32_t imr3_m4
uint32_t imr4_m4
uint32_t reserved_60 [4]
uint32_t isr1_a7
uint32_t isr2_a7
uint32_t isr3_a7
uint32_t isr4_a7
uint32_t isr1_m4
uint32_t isr2_m4
uint32_t isr3_m4
uint32_t isr4_m4
uint32_t reserved_90 [8]
uint32_t slt0_cfg
uint32_t slt1_cfg
uint32_t slt2_cfg
uint32_t slt3_cfg
uint32_t slt4_cfg
uint32_t slt5_cfg
uint32_t slt6_cfg
uint32_t slt7_cfg
uint32_t slt8_cfg
uint32_t slt9_cfg
uint32_t reserved_d8 [5]
uint32_t pgc_cpu_mapping
uint32_t cpu_pgc_sw_pup_req
uint32_t reserved_f4
uint32_t pu_pgc_sw_pup_req
uint32_t cpu_pgc_sw_pdn_req
uint32_t reserved_100
uint32_t pu_pgc_sw_pdn_req
uint32_t reserved_108 [10]
uint32_t cpu_pgc_pup_status1
uint32_t a7_mix_pgc_pup_status0
uint32_t a7_mix_pgc_pup_status1
uint32_t a7_mix_pgc_pup_status2
uint32_t m4_mix_pgc_pup_status0
uint32_t m4_mix_pgc_pup_status1
uint32_t m4_mix_pgc_pup_status2
uint32_t a7_pu_pgc_pup_status0
uint32_t a7_pu_pgc_pup_status1
uint32_t a7_pu_pgc_pup_status2
uint32_t m4_pu_pgc_pup_status0
uint32_t m4_pu_pgc_pup_status1
uint32_t m4_pu_pgc_pup_status2
uint32_t reserved_164 [3]
uint32_t cpu_pgc_pdn_status1
uint32_t reserved_174 [6]
uint32_t a7_pu_pgc_pdn_status0
uint32_t a7_pu_pgc_pdn_status1
uint32_t a7_pu_pgc_pdn_status2
uint32_t m4_pu_pgc_pdn_status0
uint32_t m4_pu_pgc_pdn_status1
uint32_t m4_pu_pgc_pdn_status2
uint32_t reserved_1a4 [3]
uint32_t a7_mix_pdn_flg
uint32_t a7_pu_pdn_flg
uint32_t m4_mix_pdn_flg
uint32_t m4_pu_pdn_flg
uint32_t reserved_1c0 [400]
uint32_t pgc_a7core0_ctrl
uint32_t pgc_a7core0_pupscr
uint32_t pgc_a7core0_pdnscr
uint32_t pgc_a7core0_sr
uint32_t reserved_810 [12]
uint32_t pgc_a7core1_ctrl
uint32_t pgc_a7core1_pupscr
uint32_t pgc_a7core1_pdnscr
uint32_t pgc_a7core1_sr
uint32_t reserved_850 [12]
uint32_t pgc_a7scu_ctrl
uint32_t pgc_a7scu_pupscr
uint32_t pgc_a7scu_pdnscr
uint32_t pgc_a7scu_sr
uint32_t pgc_scu_auxsw
uint32_t reserved_894 [11]
uint32_t pgc_mix_ctrl
uint32_t pgc_mix_pupscr
uint32_t pgc_mix_pdnscr
uint32_t pgc_mix_sr
uint32_t reserved_8d0 [12]
uint32_t pgc_mipi_ctrl
uint32_t pgc_mipi_pupscr
uint32_t pgc_mipi_pdnscr
uint32_t pgc_mipi_sr
uint32_t reserved_910 [12]
uint32_t pgc_pcie_ctrl
uint32_t pgc_pcie_pupscr
uint32_t pgc_pcie_pdnscr
uint32_t pgc_pcie_sr
uint32_t reserved_950 [176]
uint32_t pgc_mipi_auxsw
uint32_t reserved_c14 [15]
uint32_t pgc_pcie_auxsw
uint32_t reserved_c54 [43]
uint32_t pgc_hsic_ctrl
uint32_t pgc_hsic_pupscr
uint32_t pgc_hsic_pdnscr
uint32_t pgc_hsic_sr
