RTEMS 6.1
grpci2_priv Struct Reference
struct drvmgr_devdev
struct grpci2_regsregs
unsigned char ver
char irq
char irq_mode
char irq_dma
char bt_enabled
unsigned int irq_mask
unsigned int latency_timer
struct grpci2_pcibar_cfgbarcfg
unsigned int pci_area
unsigned int pci_area_end
unsigned int pci_io
unsigned int pci_conf
unsigned int pci_conf_end
uint32_t devVend
struct drvmgr_map_entry maps_up [7]
struct drvmgr_map_entry maps_down [2]
struct pcibus_config config
void(* dma_isr )(void *data)
void * dma_isr_arg
