RTEMS 6.1
Public Member Functions | Data Fields
gr_cpci_gr740_priv Struct Reference
 SPIN_DECLARE (devlock)
struct drvmgr_devdev
char prefix [16]
pci_dev_t pcidev
struct pci_dev_infodevinfo
uint32_t ahbmst2pci_map
int eirq
genirq_t genirq
unsigned int amba_freq_hz
unsigned int cg_en_mask
struct irqmp_regsirq
struct gr740_grcg_regscg
struct grpci2_regsgrpci2
struct drvmgr_map_entry bus_maps_up [2]
struct drvmgr_map_entry bus_maps_down [4]
struct ambapp_bus abus
struct ambapp_mmap amba_maps [5]
struct ambapp_config config
