RTEMS 6.1
Extended USART HAL module driver. This file provides firmware functions to manage the following extended functionalities of the Universal Synchronous Receiver Transmitter Peripheral (USART). More...
#include "stm32h7xx_hal.h"Extended USART HAL module driver. This file provides firmware functions to manage the following extended functionalities of the Universal Synchronous Receiver Transmitter Peripheral (USART).
##### USART peripheral extended features #####
(#) FIFO mode enabling/disabling and RX/TX FIFO threshold programming.
-@- When USART operates in FIFO mode, FIFO mode must be enabled prior
starting RX/TX transfers. Also RX/TX FIFO thresholds must be
configured prior starting RX/TX transfers.
(#) Slave mode enabling/disabling and NSS pin configuration.
-@- When USART operates in Slave mode, Slave mode must be enabled prior
