RTEMS 6.1
SWPMI HAL module driver. This file provides firmware functions to manage the following functionalities of the Single Wire Protocol Master Interface (SWPMI). More...
#include "stm32h7xx_hal.h"SWPMI HAL module driver. This file provides firmware functions to manage the following functionalities of the Single Wire Protocol Master Interface (SWPMI).
##### How to use this driver #####
The SWPMI HAL driver can be used as follows:
(#) Declare a SWPMI_HandleTypeDef handle structure (eg. SWPMI_HandleTypeDef hswpmi).
(#) Initialize the SWPMI low level resources by implementing the HAL_SWPMI_MspInit() API:
(##) Enable the SWPMIx interface clock with __HAL_RCC_SWPMIx_CLK_ENABLE().
(##) SWPMI IO configuration:
(+++) Enable the clock for the SWPMI GPIO.
(+++) Configure these SWPMI pins as alternate function pull-up.
(##) NVIC configuration if you need to use interrupt process (HAL_SWPMI_Transmit_IT()
and HAL_SWPMI_Receive_IT() APIs):
(+++) Configure the SWPMIx interrupt priority with HAL_NVIC_SetPriority().
(+++) Enable the NVIC SWPMI IRQ handle with HAL_NVIC_EnableIRQ().
(##) DMA Configuration if you need to use DMA process (HAL_SWPMI_Transmit_DMA()
and HAL_SWPMI_Receive_DMA() APIs):
(+++) Declare a DMA handle structure for the Tx/Rx streams.
(+++) Enable the DMAx interface clock.
(+++) Configure the declared DMA handle structure with the required
Tx/Rx parameters.
(+++) Configure the DMA Tx/Rx streams and requests.
(+++) Associate the initialized DMA handle to the SWPMI DMA Tx/Rx handle.
(+++) Configure the priority and enable the NVIC for the transfer complete
interrupt on the DMA Tx/Rx streams.
(#) Program the Bite Rate, Tx Buffering mode, Rx Buffering mode in the Init structure.
(#) Enable the SWPMI peripheral by calling the HAL_SWPMI_Init() function.
Three operation modes are available within this driver :
*** Polling mode IO operation ***
(+) Send an amount of data in blocking mode using HAL_SWPMI_Transmit()
(+) Receive an amount of data in blocking mode using HAL_SWPMI_Receive()
*** Interrupt mode IO operation ***
(+) Send an amount of data in non-blocking mode using HAL_SWPMI_Transmit_IT()
(+) At transmission end of transfer HAL_SWPMI_TxCpltCallback() is executed and user can
add his own code by customization of function pointer HAL_SWPMI_TxCpltCallback()
(+) Receive an amount of data in non-blocking mode using HAL_SWPMI_Receive_IT()
(+) At reception end of transfer HAL_SWPMI_RxCpltCallback() is executed and user can
add his own code by customization of function pointer HAL_SWPMI_RxCpltCallback()
(+) In case of flag error, HAL_SWPMI_ErrorCallback() function is executed and user can
add his own code by customization of function pointer HAL_SWPMI_ErrorCallback()
*** DMA mode IO operation ***
(+) Send an amount of data in non-blocking mode (DMA) using HAL_SWPMI_Transmit_DMA()
(+) Receive an amount of data in non-blocking mode (DMA) using HAL_SWPMI_Receive_DMA()
(+) Stop the DMA Transfer using HAL_SWPMI_DMAStop()
*** SWPMI HAL driver additional function list ***
Below the list the others API available SWPMI HAL driver :
(+) HAL_SWPMI_EnableLoopback(): Enable the loopback mode for test purpose only
(+) HAL_SWPMI_DisableLoopback(): Disable the loopback mode
*** SWPMI HAL driver macros list ***
Below the list of most used macros in SWPMI HAL driver :
(+) __HAL_SWPMI_ENABLE(): Enable the SWPMI peripheral
(+) __HAL_SWPMI_DISABLE(): Disable the SWPMI peripheral
(+) __HAL_SWPMI_TRANSCEIVER_ENABLE(): Enable the SWPMI peripheral transceiver
(+) __HAL_SWPMI_TRANSCEIVER_DISABLE(): Disable the SWPMI peripheral transceiver
(+) __HAL_SWPMI_ENABLE_IT(): Enable the specified SWPMI interrupts
(+) __HAL_SWPMI_DISABLE_IT(): Disable the specified SWPMI interrupts
(+) __HAL_SWPMI_GET_IT_SOURCE(): Check if the specified SWPMI interrupt source is
enabled or disabled
(+) __HAL_SWPMI_GET_FLAG(): Check whether the specified SWPMI flag is set or not
*** Callback registration ***
The compilation define USE_HAL_SWPMI_REGISTER_CALLBACKS when set to 1
allows the user to configure dynamically the driver callbacks.
Use function HAL_SWPMI_RegisterCallback() to register a user callback. It allows
to register the following callbacks:
(+) RxCpltCallback : SWPMI receive complete.
(+) RxHalfCpltCallback : SWPMI receive half complete.
(+) TxCpltCallback : SWPMI transmit complete.
(+) TxHalfCpltCallback : SWPMI transmit half complete.
(+) ErrorCallback : SWPMI error.
(+) MspInitCallback : SWPMI MspInit.
(+) MspDeInitCallback : SWPMI MspDeInit.
This function takes as parameters the HAL peripheral handle, the callback ID
and a pointer to the user callback function.
Use function HAL_SWPMI_UnRegisterCallback() to reset a callback to the default
weak (surcharged) function.
HAL_SWPMI_UnRegisterCallback() takes as parameters the HAL peripheral handle,
and the callback ID.
This function allows to reset following callbacks:
By default, after the HAL_SWPMI_Init and if the state is HAL_SWPMI_STATE_RESET
all callbacks are reset to the corresponding legacy weak (surcharged) functions:
examples HAL_SWPMI_RxCpltCallback(), HAL_SWPMI_ErrorCallback().
Exception done for MspInit and MspDeInit callbacks that are respectively
reset to the legacy weak (surcharged) functions in the HAL_SWPMI_Init
and HAL_SWPMI_DeInit only when these callbacks are null (not registered beforehand).
If not, MspInit or MspDeInit are not null, the HAL_SWPMI_Init and HAL_SWPMI_DeInit
keep and use the user MspInit/MspDeInit callbacks (registered beforehand).
Callbacks can be registered/unregistered in READY state only.
Exception done for MspInit/MspDeInit callbacks that can be registered/unregistered
in READY or RESET state, thus registered (user) MspInit/DeInit callbacks can be used
during the Init/DeInit.
In that case first register the MspInit/MspDeInit user callbacks
using HAL_SWPMI_RegisterCallback before calling HAL_SWPMI_DeInit
or HAL_SWPMI_Init function.
When the compilation define USE_HAL_SWPMI_REGISTER_CALLBACKS is set to 0 or
not defined, the callback registering feature is not available
and weak (surcharged) callbacks are used.
