RTEMS 6.1
stm32h7xx_hal_spi.c File Reference
SPI HAL module driver. This file provides firmware functions to manage the following functionalities of the Serial Peripheral Interface (SPI) peripheral: More...
#include "stm32h7xx_hal.h"
Author
MCD Application Team
  • Initialization and de-initialization functions
  • IO operation functions
  • Peripheral Control functions
  • Peripheral State functions
Attention
                      ##### How to use this driver #####
    The SPI HAL driver can be used as follows:
    (#) Declare a SPI_HandleTypeDef handle structure, for example:
        SPI_HandleTypeDef  hspi;
    (#)Initialize the SPI low level resources by implementing the HAL_SPI_MspInit() API:
        (##) Enable the SPIx interface clock
        (##) SPI pins configuration
            (+++) Enable the clock for the SPI GPIOs
            (+++) Configure these SPI pins as alternate function push-pull
        (##) NVIC configuration if you need to use interrupt process or DMA process
            (+++) Configure the SPIx interrupt priority
            (+++) Enable the NVIC SPI IRQ handle
        (##) DMA Configuration if you need to use DMA process
            (+++) Declare a DMA_HandleTypeDef handle structure for the transmit or receive Stream/Channel
            (+++) Enable the DMAx clock
            (+++) Configure the DMA handle parameters
            (+++) Configure the DMA Tx or Rx Stream/Channel
            (+++) Associate the initialized hdma_tx handle to the hspi DMA Tx or Rx handle
            (+++) Configure the priority and enable the NVIC for the transfer complete interrupt on the DMA Tx
    (#) Program the Mode, BidirectionalMode , Data size, Baudrate Prescaler, NSS
        management, Clock polarity and phase, FirstBit and CRC configuration in the hspi Init structure.
    (#) Initialize the SPI registers by calling the HAL_SPI_Init() API:
        (++) This API configures also the low level Hardware GPIO, CLOCK, CORTEX...etc)
            by calling the customized HAL_SPI_MspInit() API.
     Callback registration:
    (#) The compilation flag USE_HAL_SPI_REGISTER_CALLBACKS when set to 1UL
        allows the user to configure dynamically the driver callbacks.
        Use Functions HAL_SPI_RegisterCallback() to register an interrupt callback.
        Function HAL_SPI_RegisterCallback() allows to register following callbacks:
          (+) TxCpltCallback        : SPI Tx Completed callback
          (+) RxCpltCallback        : SPI Rx Completed callback
          (+) TxRxCpltCallback      : SPI TxRx Completed callback
          (+) TxHalfCpltCallback    : SPI Tx Half Completed callback
          (+) RxHalfCpltCallback    : SPI Rx Half Completed callback
          (+) TxRxHalfCpltCallback  : SPI TxRx Half Completed callback
          (+) ErrorCallback         : SPI Error callback
          (+) AbortCpltCallback     : SPI Abort callback
          (+) SuspendCallback       : SPI Suspend callback
          (+) MspInitCallback       : SPI Msp Init callback
          (+) MspDeInitCallback     : SPI Msp DeInit callback
        This function takes as parameters the HAL peripheral handle, the Callback ID
        and a pointer to the user callback function.
    (#) Use function HAL_SPI_UnRegisterCallback to reset a callback to the default
        weak function.
        HAL_SPI_UnRegisterCallback takes as parameters the HAL peripheral handle,
        and the Callback ID.
        This function allows to reset following callbacks:
     By default, after the HAL_SPI_Init() and when the state is HAL_SPI_STATE_RESET
     all callbacks are set to the corresponding weak functions:
     examples HAL_SPI_MasterTxCpltCallback(), HAL_SPI_MasterRxCpltCallback().
     Exception done for MspInit and MspDeInit functions that are
     reset to the legacy weak functions in the HAL_SPI_Init()/ HAL_SPI_DeInit() only when
     these callbacks are null (not registered beforehand).
     If MspInit or MspDeInit are not null, the HAL_SPI_Init()/ HAL_SPI_DeInit()
     keep and use the user MspInit/MspDeInit callbacks (registered beforehand) whatever the state.
     Callbacks can be registered/unregistered in HAL_SPI_STATE_READY state only.
     Exception done MspInit/MspDeInit functions that can be registered/unregistered
     in HAL_SPI_STATE_READY or HAL_SPI_STATE_RESET state,
     thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit.
     Then, the user first registers the MspInit/MspDeInit user callbacks
     using HAL_SPI_RegisterCallback() before calling HAL_SPI_DeInit()
     or HAL_SPI_Init() function.
     When The compilation define USE_HAL_PPP_REGISTER_CALLBACKS is set to 0 or not defined,
     the callback registering feature is not available and weak callbacks are used.
     SuspendCallback restriction:
         SuspendCallback is called only when MasterReceiverAutoSusp is enabled and
     EOT interrupt is activated. SuspendCallback is used in relation with functions
     HAL_SPI_Transmit_IT, HAL_SPI_Receive_IT and HAL_SPI_TransmitReceive_IT.
    Circular mode restriction:
    (+) The DMA circular mode cannot be used when the SPI is configured in these modes:
        (++) Master 2Lines RxOnly
        (++) Master 1Line Rx
    (+) The CRC feature is not managed when the DMA circular mode is enabled
    (+) The functions HAL_SPI_DMAPause()/ HAL_SPI_DMAResume() are not supported. Return always
        HAL_ERROR with ErrorCode set to HAL_SPI_ERROR_NOT_SUPPORTED.
        Those functions are maintained for backward compatibility reasons.
