RTEMS 6.1
SD card Extended HAL module driver. This file provides firmware functions to manage the following functionalities of the Secure Digital (SD) peripheral: More...
#include "stm32h7xx_hal.h"SD card Extended HAL module driver. This file provides firmware functions to manage the following functionalities of the Secure Digital (SD) peripheral:
##### How to use this driver #####
The SD Extension HAL driver can be used as follows:
(+) Configure Buffer0 and Buffer1 start address and Buffer size using HAL_SDEx_ConfigDMAMultiBuffer() function.
(+) Start Read and Write for multibuffer mode using HAL_SDEx_ReadBlocksDMAMultiBuffer()
and HAL_SDEx_WriteBlocksDMAMultiBuffer() functions.
