RTEMS 6.1
Extended RTC HAL module driver. This file provides firmware functions to manage the following functionalities of the Real Time Clock (RTC) Extended peripheral: More...
#include "stm32h7xx_hal.h"Extended RTC HAL module driver. This file provides firmware functions to manage the following functionalities of the Real Time Clock (RTC) Extended peripheral:
##### How to use this driver #####
(+) Enable the RTC domain access.
(+) Configure the RTC Prescaler (Asynchronous and Synchronous) and RTC hour
format using the HAL_RTC_Init() function.
*** RTC Wakeup configuration ***
(+) To configure the RTC Wakeup Clock source and Counter use the HAL_RTCEx_SetWakeUpTimer()
function. You can also configure the RTC Wakeup timer with interrupt mode
using the HAL_RTCEx_SetWakeUpTimer_IT() function.
(+) To read the RTC WakeUp Counter register, use the HAL_RTCEx_GetWakeUpTimer()
function.
*** Outputs configuration ***
[..] The RTC has 2 different outputs:
(+) RTC_ALARM: this output is used to manage the RTC Alarm A, Alarm B
and WaKeUp signals.
To output the selected RTC signal, use the HAL_RTC_Init() function.
(+) RTC_CALIB: this output is 512Hz signal or 1Hz.
To enable the RTC_CALIB, use the HAL_RTCEx_SetCalibrationOutPut() function.
(+) Two pins can be used as RTC_ALARM or RTC_CALIB (PC13, PB2) managed on
the RTC_OR register.
(+) When the RTC_CALIB or RTC_ALARM output is selected, the RTC_OUT pin is
automatically configured in output alternate function.
*** Smooth digital Calibration configuration ***
(+) Configure the RTC Original Digital Calibration Value and the corresponding
calibration cycle period (32s,16s and 8s) using the HAL_RTCEx_SetSmoothCalib()
function.
*** TimeStamp configuration ***
(+) Enable the RTC TimeStamp using the HAL_RTCEx_SetTimeStamp() function.
You can also configure the RTC TimeStamp with interrupt mode using the
HAL_RTCEx_SetTimeStamp_IT() function.
(+) To read the RTC TimeStamp Time and Date register, use the HAL_RTCEx_GetTimeStamp()
function.
*** Internal TimeStamp configuration ***
(+) Enable the RTC internal TimeStamp using the HAL_RTCEx_SetInternalTimeStamp() function.
User has to check internal timestamp occurrence using __HAL_RTC_INTERNAL_TIMESTAMP_GET_FLAG.
function.
*** Tamper configuration ***
(+) Enable the RTC Tamper and configure the Tamper filter count, trigger Edge
or Level according to the Tamper filter (if equal to 0 Edge else Level)
value, sampling frequency, NoErase, MaskFlag, precharge or discharge and
Pull-UP using the HAL_RTCEx_SetTamper() function. You can configure RTC Tamper
with interrupt mode using HAL_RTCEx_SetTamper_IT() function.
(+) The default configuration of the Tamper erases the backup registers. To avoid
erase, enable the NoErase field on the RTC_TAMPCR register.
*** Backup Data Registers configuration ***
(+) To write to the RTC Backup Data registers, use the HAL_RTCEx_BKUPWrite()
function.
(+) To read the RTC Backup Data registers, use the HAL_RTCEx_BKUPRead()
function.
