RTEMS 6.1
stm32h7xx_hal_rng.c File Reference
RNG HAL module driver. This file provides firmware functions to manage the following functionalities of the Random Number Generator (RNG) peripheral: More...
#include "stm32h7xx_hal.h"
Author
MCD Application Team
  • Initialization and configuration functions
  • Peripheral Control functions
  • Peripheral State functions
Attention
                   ##### How to use this driver #####
    The RNG HAL driver can be used as follows:
    (#) Enable the RNG controller clock using __HAL_RCC_RNG_CLK_ENABLE() macro
        in HAL_RNG_MspInit().
    (#) Activate the RNG peripheral using HAL_RNG_Init() function.
    (#) Wait until the 32 bit Random Number Generator contains a valid
        random data using (polling/interrupt) mode.
    (#) Get the 32 bit random number using HAL_RNG_GenerateRandomNumber() function.
  ##### Callback registration #####
  The compilation define USE_HAL_RNG_REGISTER_CALLBACKS when set to 1
  allows the user to configure dynamically the driver callbacks.
  Use Function HAL_RNG_RegisterCallback() to register a user callback.
  Function HAL_RNG_RegisterCallback() allows to register following callbacks:
  (+) ErrorCallback             : RNG Error Callback.
  (+) MspInitCallback           : RNG MspInit.
  (+) MspDeInitCallback         : RNG MspDeInit.
  This function takes as parameters the HAL peripheral handle, the Callback ID
  and a pointer to the user callback function.
  Use function HAL_RNG_UnRegisterCallback() to reset a callback to the default
  weak (overridden) function.
  HAL_RNG_UnRegisterCallback() takes as parameters the HAL peripheral handle,
  and the Callback ID.
  This function allows to reset following callbacks:
  For specific callback ReadyDataCallback, use dedicated register callbacks:
  respectively HAL_RNG_RegisterReadyDataCallback() , HAL_RNG_UnRegisterReadyDataCallback().
  By default, after the HAL_RNG_Init() and when the state is HAL_RNG_STATE_RESET
  all callbacks are set to the corresponding weak (overridden) functions:
  example HAL_RNG_ErrorCallback().
  Exception done for MspInit and MspDeInit functions that are respectively
  reset to the legacy weak (overridden) functions in the HAL_RNG_Init()
  and HAL_RNG_DeInit() only when these callbacks are null (not registered beforehand).
  If not, MspInit or MspDeInit are not null, the HAL_RNG_Init() and HAL_RNG_DeInit()
  keep and use the user MspInit/MspDeInit callbacks (registered beforehand).
  Callbacks can be registered/unregistered in HAL_RNG_STATE_READY state only.
  Exception done MspInit/MspDeInit that can be registered/unregistered
  in HAL_RNG_STATE_READY or HAL_RNG_STATE_RESET state, thus registered (user)
  MspInit/DeInit callbacks can be used during the Init/DeInit.
  In that case first register the MspInit/MspDeInit user callbacks
  using HAL_RNG_RegisterCallback() before calling HAL_RNG_DeInit()
  or HAL_RNG_Init() function.
  When The compilation define USE_HAL_RNG_REGISTER_CALLBACKS is set to 0 or
  not defined, the callback registration feature is not available
  and weak (overridden) callbacks are used.
