RTEMS 6.1
RCC HAL module driver. This file provides firmware functions to manage the following functionalities of the Reset and Clock Control (RCC) peripheral: More...
#include "stm32h7xx_hal.h"RCC HAL module driver. This file provides firmware functions to manage the following functionalities of the Reset and Clock Control (RCC) peripheral:
##### RCC specific features #####
After reset the device is running from Internal High Speed oscillator
(HSI 64MHz) with Flash 0 wait state,and all peripherals are off except
internal SRAM, Flash, JTAG and PWR
(+) There is no pre-scaler on High speed (AHB) and Low speed (APB) buses;
all peripherals mapped on these buses are running at HSI speed.
(+) The clock for all peripherals is switched off, except the SRAM and FLASH.
(+) All GPIOs are in analogue mode , except the JTAG pins which
are assigned to be used for debug purpose.
Once the device started from reset, the user application has to:
(+) Configure the clock source to be used to drive the System clock
(if the application needs higher frequency/performance)
(+) Configure the System clock frequency and Flash settings
(+) Configure the AHB and APB buses pre-scalers
(+) Enable the clock for the peripheral(s) to be used
(+) Configure the clock kernel source(s) for peripherals which clocks are not
derived from the System clock through :RCC_D1CCIPR,RCC_D2CCIP1R,RCC_D2CCIP2R
and RCC_D3CCIPR registers
##### RCC Limitations #####
A delay between an RCC peripheral clock enable and the effective peripheral
enabling should be taken into account in order to manage the peripheral read/write
from/to registers.
(+) This delay depends on the peripheral mapping.
(+) If peripheral is mapped on AHB: the delay is 2 AHB clock cycle
after the clock enable bit is set on the hardware register
(+) If peripheral is mapped on APB: the delay is 2 APB clock cycle
Implemented Workaround:
(+) For AHB & APB peripherals, a dummy read to the peripheral register has been
inserted in each __HAL_RCC_PPP_CLK_ENABLE() macro.Copyright (c) 2017 STMicroelectronics. All rights reserved.
