RTEMS 6.1
RAMECC HAL module driver. This file provides firmware functions to manage the following functionalities of the RAM ECC monitoring (RAMECC) peripheral: More...
#include "stm32h7xx_hal.h"RAMECC HAL module driver. This file provides firmware functions to manage the following functionalities of the RAM ECC monitoring (RAMECC) peripheral:
##### How to use this driver #####
(#) Enable and latch error information through HAL_RAMECC_Init().
(#) For a given Monitor, enable and disable interrupt through
HAL_RAMECC_EnableNotification().
To enable a notification for a given RAMECC instance, use global
interrupts.
To enable a notification for only RAMECC monitor, use monitor interrupts.
All possible notifications are defined in the driver header file under
RAMECC_Interrupt group.
*** Silent mode ***
(+) Use HAL_RAMECC_StartMonitor() to start RAMECC latch failing
information without enabling any notification.
*** Interrupt mode ***
(+) Use HAL_RAMECC_EnableNotification() to enable interrupts for a
given error.
(+) Configure the RAMECC interrupt priority using
HAL_NVIC_SetPriority().
(+) Enable the RAMECC IRQ handler using HAL_NVIC_EnableIRQ().
(+) Start RAMECC latch failing information using HAL_RAMECC_StartMonitor().
*** Failing information ***
(#) Use HAL_RAMECC_GetFailingAddress() function to return the RAMECC
failing address.
(#) Use HAL_RAMECC_GetFailingDataLow() function to return the RAMECC
failing data low.
(#) Use HAL_RAMECC_GetFailingDataHigh() function to return the RAMECC
failing data high.
(#) Use HAL_RAMECC_GetHammingErrorCode() function to return the RAMECC
Hamming bits injected.
(#) Use HAL_RAMECC_IsECCSingleErrorDetected() function to check if a single
error was detected and corrected.
(#) Use HAL_RAMECC_IsECCDoubleErrorDetected() function to check if a double
error was dedetected.
*** RAMECC HAL driver macros list ***
Below the list of used macros in RAMECC HAL driver.
(+) __HAL_RAMECC_ENABLE_IT : Enable the specified ECCRAM Monitor
interrupts.
(+) __HAL_RAMECC_DISABLE_IT : Disable the specified ECCRAM Monitor
interrupts.
(+) __HAL_RAMECC_GET_FLAG : Return the current RAMECC Monitor selected
flag.
(+) __HAL_RAMECC_CLEAR_FLAG : Clear the current RAMECC Monitor selected
flag.
##### Callback registration #####
(#) The compilation define USE_HAL_RAMECC_REGISTER_CALLBACKS when set to 1
allows the user to configure dynamically the driver callback.
(#) Use Function HAL_RAMECC_RegisterCallback() to register a user callback.
(#) Function HAL_RAMECC_RegisterCallback() allows to register following callback:
(+) RAMECCErrorCode : RAMECC error code detection.
(#) This function takes as parameters the HAL peripheral handle
and a pointer to the user callback function.
(#) Use function HAL_RAMECC_UnRegisterCallback() to reset a callback to the default
weak function.
(#) HAL_RAMECC_UnRegisterCallback() takes as parameters the HAL peripheral handle.
(#) This function allows to reset following callback:
(#) When The compilation define USE_HAL_RAMECC_REGISTER_CALLBACKS is set to 0 or
not defined, the callback registration feature is not available
and weak callbacks are used.
