RTEMS 6.1
MMC card HAL module driver. This file provides firmware functions to manage the following functionalities of the Secure Digital (MMC) peripheral: More...
#include "stm32h7xx_hal.h"MMC card HAL module driver. This file provides firmware functions to manage the following functionalities of the Secure Digital (MMC) peripheral:
##### How to use this driver #####
This driver implements a high level communication layer for read and write from/to
this memory. The needed STM32 hardware resources (SDMMC and GPIO) are performed by
the user in HAL_MMC_MspInit() function (MSP layer).
Basically, the MSP layer configuration should be the same as we provide in the
examples.
You can easily tailor this configuration according to hardware resources.
This driver is a generic layered driver for SDMMC memories which uses the HAL
SDMMC driver functions to interface with MMC and eMMC cards devices.
It is used as follows:
(#)Initialize the SDMMC low level resources by implement the HAL_MMC_MspInit() API:
(##) Enable the SDMMC interface clock using __HAL_RCC_SDMMC_CLK_ENABLE();
(##) SDMMC pins configuration for MMC card
(+++) Enable the clock for the SDMMC GPIOs using the functions __HAL_RCC_GPIOx_CLK_ENABLE();
(+++) Configure these SDMMC pins as alternate function pull-up using HAL_GPIO_Init()
and according to your pin assignment;
(##) NVIC configuration if you need to use interrupt process (HAL_MMC_ReadBlocks_IT()
and HAL_MMC_WriteBlocks_IT() APIs).
(+++) Configure the SDMMC interrupt priorities using function HAL_NVIC_SetPriority();
(+++) Enable the NVIC SDMMC IRQs using function HAL_NVIC_EnableIRQ()
(+++) SDMMC interrupts are managed using the macros __HAL_MMC_ENABLE_IT()
and __HAL_MMC_DISABLE_IT() inside the communication process.
(+++) SDMMC interrupts pending bits are managed using the macros __HAL_MMC_GET_IT()
and __HAL_MMC_CLEAR_IT()
(##) No general propose DMA Configuration is needed, an Internal DMA for SDMMC Peripheral are used.
(#) At this stage, you can perform MMC read/write/erase operations after MMC card initialization
*** MMC Card Initialization and configuration ***
To initialize the MMC Card, use the HAL_MMC_Init() function. It Initializes
SDMMC Peripheral (STM32 side) and the MMC Card, and put it into StandBy State (Ready for data transfer).
This function provide the following operations:
(#) Initialize the SDMMC peripheral interface with default configuration.
The initialization process is done at 400KHz. You can change or adapt
this frequency by adjusting the "ClockDiv" field.
The MMC Card frequency (SDMMC_CK) is computed as follows:
SDMMC_CK = SDMMCCLK / (2 * ClockDiv)
In initialization mode and according to the MMC Card standard,
make sure that the SDMMC_CK frequency doesn't exceed 400KHz.
This phase of initialization is done through SDMMC_Init() and
SDMMC_PowerState_ON() SDMMC low level APIs.
(#) Initialize the MMC card. The API used is HAL_MMC_InitCard().
This phase allows the card initialization and identification
and check the MMC Card type (Standard Capacity or High Capacity)
The initialization flow is compatible with MMC standard.
This API (HAL_MMC_InitCard()) could be used also to reinitialize the card in case
of plug-off plug-in.
(#) Configure the MMC Card Data transfer frequency. By Default, the card transfer
In transfer mode and according to the MMC Card standard, make sure that the
SDMMC_CK frequency doesn't exceed 25MHz and 100MHz in High-speed mode switch.
(#) Select the corresponding MMC Card according to the address read with the step 2.
(#) Configure the MMC Card in wide bus mode: 4-bits data.
*** MMC Card Read operation ***
(+) You can read from MMC card in polling mode by using function HAL_MMC_ReadBlocks().
This function support only 512-bytes block length (the block size should be
chosen as 512 bytes).
You can choose either one block read operation or multiple block read operation
by adjusting the "NumberOfBlocks" parameter.
After this, you have to ensure that the transfer is done correctly. The check is done
through HAL_MMC_GetCardState() function for MMC card state.
(+) You can read from MMC card in DMA mode by using function HAL_MMC_ReadBlocks_DMA().
You could also check the DMA transfer process through the MMC Rx interrupt event.
(+) You can read from MMC card in Interrupt mode by using function HAL_MMC_ReadBlocks_IT().
This function allows the read of 512 bytes blocks.
You could also check the IT transfer process through the MMC Rx interrupt event.
*** MMC Card Write operation ***
(+) You can write to MMC card in polling mode by using function HAL_MMC_WriteBlocks().
(+) You can write to MMC card in DMA mode by using function HAL_MMC_WriteBlocks_DMA().
chosen as 512 byte).
You could also check the DMA transfer process through the MMC Tx interrupt event.
(+) You can write to MMC card in Interrupt mode by using function HAL_MMC_WriteBlocks_IT().
You could also check the IT transfer process through the MMC Tx interrupt event.
*** MMC card information ***
(+) To get MMC card information, you can use the function HAL_MMC_GetCardInfo().
It returns useful information about the MMC card such as block size, card type,
block number ...
*** MMC card CSD register ***
(+) The HAL_MMC_GetCardCSD() API allows to get the parameters of the CSD register.
Some of the CSD parameters are useful for card initialization and identification.
*** MMC card CID register ***
(+) The HAL_MMC_GetCardCID() API allows to get the parameters of the CID register.
Some of the CID parameters are useful for card initialization and identification.
*** MMC HAL driver macros list ***
Below the list of most used macros in MMC HAL driver.
(+) __HAL_MMC_ENABLE_IT: Enable the MMC device interrupt
(+) __HAL_MMC_DISABLE_IT: Disable the MMC device interrupt
(+) __HAL_MMC_GET_FLAG:Check whether the specified MMC flag is set or not
(+) __HAL_MMC_CLEAR_FLAG: Clear the MMC's pending flags
(@) You can refer to the MMC HAL driver header file for more useful macros
*** Callback registration ***
The compilation define USE_HAL_MMC_REGISTER_CALLBACKS when set to 1
allows the user to configure dynamically the driver callbacks.
Use Functions HAL_MMC_RegisterCallback() to register a user callback,
it allows to register following callbacks:
(+) TxCpltCallback : callback when a transmission transfer is completed.
(+) RxCpltCallback : callback when a reception transfer is completed.
(+) ErrorCallback : callback when error occurs.
(+) AbortCpltCallback : callback when abort is completed.
(+) Read_DMADblBuf0CpltCallback : callback when the DMA reception of first buffer is completed.
(+) Read_DMADblBuf1CpltCallback : callback when the DMA reception of second buffer is completed.
(+) Write_DMADblBuf0CpltCallback : callback when the DMA transmission of first buffer is completed.
(+) Write_DMADblBuf1CpltCallback : callback when the DMA transmission of second buffer is completed.
(+) MspInitCallback : MMC MspInit.
(+) MspDeInitCallback : MMC MspDeInit.
This function takes as parameters the HAL peripheral handle, the Callback ID
and a pointer to the user callback function.
Use function HAL_MMC_UnRegisterCallback() to reset a callback to the default
weak (surcharged) function. It allows to reset following callbacks:
This function) takes as parameters the HAL peripheral handle and the Callback ID.
By default, after the HAL_MMC_Init and if the state is HAL_MMC_STATE_RESET
all callbacks are reset to the corresponding legacy weak (surcharged) functions.
Exception done for MspInit and MspDeInit callbacks that are respectively
reset to the legacy weak (surcharged) functions in the HAL_MMC_Init
and HAL_MMC_DeInit only when these callbacks are null (not registered beforehand).
If not, MspInit or MspDeInit are not null, the HAL_MMC_Init and HAL_MMC_DeInit
keep and use the user MspInit/MspDeInit callbacks (registered beforehand)
Callbacks can be registered/unregistered in READY state only.
Exception done for MspInit/MspDeInit callbacks that can be registered/unregistered
in READY or RESET state, thus registered (user) MspInit/DeInit callbacks can be used
during the Init/DeInit.
In that case first register the MspInit/MspDeInit user callbacks
using HAL_MMC_RegisterCallback before calling HAL_MMC_DeInit
or HAL_MMC_Init function.
When The compilation define USE_HAL_MMC_REGISTER_CALLBACKS is set to 0 or
not defined, the callback registering feature is not available
and weak (surcharged) callbacks are used.
