RTEMS 6.1
IRDA HAL module driver. This file provides firmware functions to manage the following functionalities of the IrDA (Infrared Data Association) Peripheral (IRDA) More...
#include "stm32h7xx_hal.h"IRDA HAL module driver. This file provides firmware functions to manage the following functionalities of the IrDA (Infrared Data Association) Peripheral (IRDA)
##### How to use this driver #####
The IRDA HAL driver can be used as follows:
(#) Declare a IRDA_HandleTypeDef handle structure (eg. IRDA_HandleTypeDef hirda).
(#) Initialize the IRDA low level resources by implementing the HAL_IRDA_MspInit() API
in setting the associated USART or UART in IRDA mode:
(++) Enable the USARTx/UARTx interface clock.
(++) USARTx/UARTx pins configuration:
(+++) Enable the clock for the USARTx/UARTx GPIOs.
(+++) Configure these USARTx/UARTx pins (TX as alternate function pull-up, RX as alternate function Input).
(++) NVIC configuration if you need to use interrupt process (HAL_IRDA_Transmit_IT()
and HAL_IRDA_Receive_IT() APIs):
(+++) Configure the USARTx/UARTx interrupt priority.
(+++) Enable the NVIC USARTx/UARTx IRQ handle.
(+++) The specific IRDA interrupts (Transmission complete interrupt,
RXNE interrupt and Error Interrupts) will be managed using the macros
__HAL_IRDA_ENABLE_IT() and __HAL_IRDA_DISABLE_IT() inside the transmit and receive process.
(++) DMA Configuration if you need to use DMA process (HAL_IRDA_Transmit_DMA()
and HAL_IRDA_Receive_DMA() APIs):
(+++) Declare a DMA handle structure for the Tx/Rx channel.
(+++) Enable the DMAx interface clock.
(+++) Configure the declared DMA handle structure with the required Tx/Rx parameters.
(+++) Configure the DMA Tx/Rx channel.
(+++) Associate the initialized DMA handle to the IRDA DMA Tx/Rx handle.
(+++) Configure the priority and enable the NVIC for the transfer
complete interrupt on the DMA Tx/Rx channel.
(#) Program the Baud Rate, Word Length and Parity and Mode(Receiver/Transmitter),
the normal or low power mode and the clock prescaler in the hirda handle Init structure.
(#) Initialize the IRDA registers by calling the HAL_IRDA_Init() API:
(++) This API configures also the low level Hardware GPIO, CLOCK, CORTEX...etc)
by calling the customized HAL_IRDA_MspInit() API.
-@@- The specific IRDA interrupts (Transmission complete interrupt,
(#) Three operation modes are available within this driver :
*** Polling mode IO operation ***
(+) Send an amount of data in blocking mode using HAL_IRDA_Transmit()
(+) Receive an amount of data in blocking mode using HAL_IRDA_Receive()
*** Interrupt mode IO operation ***
(+) Send an amount of data in non-blocking mode using HAL_IRDA_Transmit_IT()
(+) At transmission end of transfer HAL_IRDA_TxCpltCallback() is executed and user can
add his own code by customization of function pointer HAL_IRDA_TxCpltCallback()
(+) Receive an amount of data in non-blocking mode using HAL_IRDA_Receive_IT()
(+) At reception end of transfer HAL_IRDA_RxCpltCallback() is executed and user can
add his own code by customization of function pointer HAL_IRDA_RxCpltCallback()
(+) In case of transfer Error, HAL_IRDA_ErrorCallback() function is executed and user can
add his own code by customization of function pointer HAL_IRDA_ErrorCallback()
*** DMA mode IO operation ***
(+) Send an amount of data in non-blocking mode (DMA) using HAL_IRDA_Transmit_DMA()
(+) At transmission half of transfer HAL_IRDA_TxHalfCpltCallback() is executed and user can
add his own code by customization of function pointer HAL_IRDA_TxHalfCpltCallback()
(+) Receive an amount of data in non-blocking mode (DMA) using HAL_IRDA_Receive_DMA()
(+) At reception half of transfer HAL_IRDA_RxHalfCpltCallback() is executed and user can
add his own code by customization of function pointer HAL_IRDA_RxHalfCpltCallback()
*** IRDA HAL driver macros list ***
Below the list of most used macros in IRDA HAL driver.
(+) __HAL_IRDA_ENABLE: Enable the IRDA peripheral
(+) __HAL_IRDA_DISABLE: Disable the IRDA peripheral
(+) __HAL_IRDA_GET_FLAG : Check whether the specified IRDA flag is set or not
(+) __HAL_IRDA_CLEAR_FLAG : Clear the specified IRDA pending flag
(+) __HAL_IRDA_ENABLE_IT: Enable the specified IRDA interrupt
(+) __HAL_IRDA_DISABLE_IT: Disable the specified IRDA interrupt
(+) __HAL_IRDA_GET_IT_SOURCE: Check whether or not the specified IRDA interrupt is enabled
(@) You can refer to the IRDA HAL driver header file for more useful macros
##### Callback registration #####
The compilation define USE_HAL_IRDA_REGISTER_CALLBACKS when set to 1
allows the user to configure dynamically the driver callbacks.
Use Function HAL_IRDA_RegisterCallback() to register a user callback.
Function HAL_IRDA_RegisterCallback() allows to register following callbacks:
(+) TxHalfCpltCallback : Tx Half Complete Callback.
(+) TxCpltCallback : Tx Complete Callback.
(+) RxHalfCpltCallback : Rx Half Complete Callback.
(+) RxCpltCallback : Rx Complete Callback.
(+) ErrorCallback : Error Callback.
(+) AbortCpltCallback : Abort Complete Callback.
(+) AbortTransmitCpltCallback : Abort Transmit Complete Callback.
(+) AbortReceiveCpltCallback : Abort Receive Complete Callback.
(+) MspInitCallback : IRDA MspInit.
(+) MspDeInitCallback : IRDA MspDeInit.
This function takes as parameters the HAL peripheral handle, the Callback ID
and a pointer to the user callback function.
Use function HAL_IRDA_UnRegisterCallback() to reset a callback to the default
weak function.
HAL_IRDA_UnRegisterCallback() takes as parameters the HAL peripheral handle,
and the Callback ID.
This function allows to reset following callbacks:
By default, after the HAL_IRDA_Init() and when the state is HAL_IRDA_STATE_RESET
all callbacks are set to the corresponding weak functions:
examples HAL_IRDA_TxCpltCallback(), HAL_IRDA_RxHalfCpltCallback().
Exception done for MspInit and MspDeInit functions that are respectively
reset to the legacy weak functions in the HAL_IRDA_Init()
and HAL_IRDA_DeInit() only when these callbacks are null (not registered beforehand).
If not, MspInit or MspDeInit are not null, the HAL_IRDA_Init() and HAL_IRDA_DeInit()
keep and use the user MspInit/MspDeInit callbacks (registered beforehand).
Callbacks can be registered/unregistered in HAL_IRDA_STATE_READY state only.
Exception done MspInit/MspDeInit that can be registered/unregistered
in HAL_IRDA_STATE_READY or HAL_IRDA_STATE_RESET state, thus registered (user)
MspInit/DeInit callbacks can be used during the Init/DeInit.
In that case first register the MspInit/MspDeInit user callbacks
using HAL_IRDA_RegisterCallback() before calling HAL_IRDA_DeInit()
or HAL_IRDA_Init() function.
When The compilation define USE_HAL_IRDA_REGISTER_CALLBACKS is set to 0 or
not defined, the callback registration feature is not available
and weak callbacks are used.
