RTEMS 6.1
HCD HAL module driver. This file provides firmware functions to manage the following functionalities of the USB Peripheral Controller: More...
#include "stm32h7xx_hal.h"HCD HAL module driver. This file provides firmware functions to manage the following functionalities of the USB Peripheral Controller:
##### How to use this driver #####
(#)Declare a HCD_HandleTypeDef handle structure, for example:
HCD_HandleTypeDef hhcd;
(#)Fill parameters of Init structure in HCD handle
(#)Call HAL_HCD_Init() API to initialize the HCD peripheral (Core, Host core, ...)
(#)Initialize the HCD low level resources through the HAL_HCD_MspInit() API:
(##) Enable the HCD/USB Low Level interface clock using the following macros
(+++) __HAL_RCC_USB_OTG_FS_CLK_ENABLE();
(+++) __HAL_RCC_USB_OTG_HS_CLK_ENABLE(); (For High Speed Mode)
(+++) __HAL_RCC_USB_OTG_HS_ULPI_CLK_ENABLE(); (For High Speed Mode)
(##) Initialize the related GPIO clocks
(##) Configure HCD pin-out
(##) Configure HCD NVIC interrupt
(#)Associate the Upper USB Host stack to the HAL HCD Driver:
(##) hhcd.pData = phost;
(#)Enable HCD transmission and reception:
(##) HAL_HCD_Start();
