RTEMS 6.1
EXTI HAL module driver. This file provides firmware functions to manage the following functionalities of the General Purpose Input/Output (EXTI) peripheral: More...
#include "stm32h7xx_hal.h"EXTI HAL module driver. This file provides firmware functions to manage the following functionalities of the General Purpose Input/Output (EXTI) peripheral:
##### EXTI Peripheral features #####
(+) Each Exti line can be configured within this driver.
(+) Exti line can be configured in 3 different modes
(++) Interrupt (CORE1 or CORE2 in case of dual core line )
(++) Event (CORE1 or CORE2 in case of dual core line )
(++) a combination of the previous
(+) Configurable Exti lines can be configured with 3 different triggers
(++) Rising
(++) Falling
(++) Both of them
(+) When set in interrupt mode, configurable Exti lines have two diffenrents
interrupt pending registers which allow to distinguish which transition
occurs:
(++) Rising edge pending interrupt
(++) Falling
(+) Exti lines 0 to 15 are linked to gpio pin number 0 to 15. Gpio port can
be selected through multiplexer.
(+) PendClearSource used to set the D3 Smart Run Domain autoamtic pend clear source.
It is applicable for line with wkaeup target is Any (CPU1 , CPU2 and D3 smart run domain).
Value can be one of the following:
(++) EXTI_D3_PENDCLR_SRC_NONE : no pend clear source is selected :
In this case corresponding bit of D2PMRx register is set to 0
(+++) On a configurable Line : the D3 domain wakeup signal is
automatically cleared after after the Delay + Rising Edge detect
(+++) On a direct Line : the D3 domain wakeup signal is
cleared after the direct event input signal is cleared
(++) EXTI_D3_PENDCLR_SRC_DMACH6 : no pend clear source is selected :
In this case corresponding bit of D2PMRx register is set to 1
and corresponding bits(2) of D3PCRxL/H is set to b00 :
DMA ch6 event selected as D3 domain pendclear source
(++) EXTI_D3_PENDCLR_SRC_DMACH7 : no pend clear source is selected :
and corresponding bits(2) of D3PCRxL/H is set to b01 :
DMA ch7 event selected as D3 domain pendclear source
(++) EXTI_D3_PENDCLR_SRC_LPTIM4 : no pend clear source is selected :
and corresponding bits(2) of D3PCRxL/H is set to b10 :
LPTIM4 out selected as D3 domain pendclear source
(++) EXTI_D3_PENDCLR_SRC_LPTIM5 : no pend clear source is selected :
and corresponding bits(2) of D3PCRxL/H is set to b11 :
LPTIM5 out selected as D3 domain pendclear source
##### How to use this driver #####
(#) Configure the EXTI line using HAL_EXTI_SetConfigLine().
(++) Choose the interrupt line number by setting "Line" member from
EXTI_ConfigTypeDef structure.
(++) Configure the interrupt and/or event mode using "Mode" member from
(++) For configurable lines, configure rising and/or falling trigger
"Trigger" member from EXTI_ConfigTypeDef structure.
(++) For Exti lines linked to gpio, choose gpio port using "GPIOSel"
member from GPIO_InitTypeDef structure.
(++) For Exti lines with wkaeup target is Any (CPU1 , CPU2 and D3 smart run domain),
choose gpio D3 PendClearSource using PendClearSource
member from EXTI_PendClear_Source structure.
(#) Get current Exti configuration of a dedicated line using
HAL_EXTI_GetConfigLine().
(++) Provide exiting handle as parameter.
(++) Provide pointer on EXTI_ConfigTypeDef structure as second parameter.
(#) Clear Exti configuration of a dedicated line using HAL_EXTI_ClearConfigLine().
(#) Register callback to treat Exti interrupts using HAL_EXTI_RegisterCallback().
(++) Provide exiting handle as first parameter.
(++) Provide which callback will be registered using one value from
EXTI_CallbackIDTypeDef.
(++) Provide callback function pointer.
(#) Get interrupt pending bit using HAL_EXTI_GetPending().
(#) Clear interrupt pending bit using HAL_EXTI_ClearPending().
(#) Generate software interrupt using HAL_EXTI_GenerateSWI().
