RTEMS 6.1
DSI HAL module driver. This file provides firmware functions to manage the following functionalities of the DSI peripheral: More...
#include "stm32h7xx_hal.h"DSI HAL module driver. This file provides firmware functions to manage the following functionalities of the DSI peripheral:
##### How to use this driver #####
The DSI HAL driver can be used as follows:
(#) Declare a DSI_HandleTypeDef handle structure, for example: DSI_HandleTypeDef hdsi;
(#) Initialize the DSI low level resources by implementing the HAL_DSI_MspInit() API:
(##) Enable the DSI interface clock
(##) NVIC configuration if you need to use interrupt process
(+++) Configure the DSI interrupt priority
(+++) Enable the NVIC DSI IRQ Channel
(#) Initialize the DSI Host peripheral, the required PLL parameters, number of lances and
TX Escape clock divider by calling the HAL_DSI_Init() API which calls HAL_DSI_MspInit().
*** Configuration ***
(#) Use HAL_DSI_ConfigAdaptedCommandMode() function to configure the DSI host in adapted
command mode.
(#) When operating in video mode , use HAL_DSI_ConfigVideoMode() to configure the DSI host.
(#) Function HAL_DSI_ConfigCommand() is used to configure the DSI commands behavior in low power mode.
(#) To configure the DSI PHY timings parameters, use function HAL_DSI_ConfigPhyTimer().
(#) The DSI Host can be started/stopped using respectively functions HAL_DSI_Start() and HAL_DSI_Stop().
Functions HAL_DSI_ShortWrite(), HAL_DSI_LongWrite() and HAL_DSI_Read() allows respectively
to write DSI short packets, long packets and to read DSI packets.
(#) The DSI Host Offers two Low power modes :
(++) Low Power Mode on data lanes only: Only DSI data lanes are shut down.
It is possible to enter/exit from this mode using respectively functions HAL_DSI_EnterULPMData()
and HAL_DSI_ExitULPMData()
(++) Low Power Mode on data and clock lanes : All DSI lanes are shut down including data and clock lanes.
It is possible to enter/exit from this mode using respectively functions HAL_DSI_EnterULPM()
and HAL_DSI_ExitULPM()
(#) To control DSI state you can use the following function: HAL_DSI_GetState()
*** Error management ***
(#) User can select the DSI errors to be reported/monitored using function HAL_DSI_ConfigErrorMonitor()
When an error occurs, the callback HAL_DSI_ErrorCallback() is asserted and then user can retrieve
the error code by calling function HAL_DSI_GetError()
*** DSI HAL driver macros list ***
Below the list of most used macros in DSI HAL driver.
(+) __HAL_DSI_ENABLE: Enable the DSI Host.
(+) __HAL_DSI_DISABLE: Disable the DSI Host.
(+) __HAL_DSI_WRAPPER_ENABLE: Enables the DSI wrapper.
(+) __HAL_DSI_WRAPPER_DISABLE: Disable the DSI wrapper.
(+) __HAL_DSI_PLL_ENABLE: Enables the DSI PLL.
(+) __HAL_DSI_PLL_DISABLE: Disables the DSI PLL.
(+) __HAL_DSI_REG_ENABLE: Enables the DSI regulator.
(+) __HAL_DSI_REG_DISABLE: Disables the DSI regulator.
(+) __HAL_DSI_GET_FLAG: Get the DSI pending flags.
(+) __HAL_DSI_CLEAR_FLAG: Clears the DSI pending flags.
(+) __HAL_DSI_ENABLE_IT: Enables the specified DSI interrupts.
(+) __HAL_DSI_DISABLE_IT: Disables the specified DSI interrupts.
(+) __HAL_DSI_GET_IT_SOURCE: Checks whether the specified DSI interrupt source is enabled or not.
(@) You can refer to the DSI HAL driver header file for more useful macros
*** Callback registration ***
The compilation define USE_HAL_DSI_REGISTER_CALLBACKS when set to 1
allows the user to configure dynamically the driver callbacks.
Use Function HAL_DSI_RegisterCallback() to register a callback.
Function HAL_DSI_RegisterCallback() allows to register following callbacks:
(+) TearingEffectCallback : DSI Tearing Effect Callback.
(+) EndOfRefreshCallback : DSI End Of Refresh Callback.
(+) ErrorCallback : DSI Error Callback
(+) MspInitCallback : DSI MspInit.
(+) MspDeInitCallback : DSI MspDeInit.
This function takes as parameters the HAL peripheral handle, the callback ID
and a pointer to the user callback function.
Use function HAL_DSI_UnRegisterCallback() to reset a callback to the default
weak function.
HAL_DSI_UnRegisterCallback takes as parameters the HAL peripheral handle,
and the callback ID.
This function allows to reset following callbacks:
By default, after the HAL_DSI_Init and when the state is HAL_DSI_STATE_RESET
all callbacks are set to the corresponding weak functions:
examples HAL_DSI_TearingEffectCallback(), HAL_DSI_EndOfRefreshCallback().
Exception done for MspInit and MspDeInit functions that are respectively
reset to the legacy weak (overridden) functions in the HAL_DSI_Init()
and HAL_DSI_DeInit() only when these callbacks are null (not registered beforehand).
If not, MspInit or MspDeInit are not null, the HAL_DSI_Init() and HAL_DSI_DeInit()
keep and use the user MspInit/MspDeInit callbacks (registered beforehand).
Callbacks can be registered/unregistered in HAL_DSI_STATE_READY state only.
Exception done MspInit/MspDeInit that can be registered/unregistered
in HAL_DSI_STATE_READY or HAL_DSI_STATE_RESET state,
thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit.
In that case first register the MspInit/MspDeInit user callbacks
using HAL_DSI_RegisterCallback() before calling HAL_DSI_DeInit()
or HAL_DSI_Init() function.
When The compilation define USE_HAL_DSI_REGISTER_CALLBACKS is set to 0 or
not defined, the callback registration feature is not available and all callbacks
are set to the corresponding weak functions.
