RTEMS 6.1
DMA Extension HAL module driver This file provides firmware functions to manage the following functionalities of the DMA Extension peripheral: More...
#include "stm32h7xx_hal.h"DMA Extension HAL module driver This file provides firmware functions to manage the following functionalities of the DMA Extension peripheral:
##### How to use this driver #####
The DMA Extension HAL driver can be used as follows:
(+) Start a multi buffer transfer using the HAL_DMA_MultiBufferStart() function
for polling mode or HAL_DMA_MultiBufferStart_IT() for interrupt mode.
(+) Configure the DMA_MUX Synchronization Block using HAL_DMAEx_ConfigMuxSync function.
(+) Configure the DMA_MUX Request Generator Block using HAL_DMAEx_ConfigMuxRequestGenerator function.
Functions HAL_DMAEx_EnableMuxRequestGenerator and HAL_DMAEx_DisableMuxRequestGenerator can then be used
to respectively enable/disable the request generator.
(+) To handle the DMAMUX Interrupts, the function HAL_DMAEx_MUX_IRQHandler should be called from
the DMAMUX IRQ handler i.e DMAMUX1_OVR_IRQHandler or DMAMUX2_OVR_IRQHandler .
As only one interrupt line is available for all DMAMUX channels and request generators , HAL_DMA_MUX_IRQHandler should be
called with, as parameter, the appropriate DMA handle as many as used DMAs in the user project
(exception done if a given DMA is not using the DMAMUX SYNC block neither a request generator)
-@- In Memory-to-Memory transfer mode, Multi (Double) Buffer mode is not allowed.
-@- When Multi (Double) Buffer mode is enabled, the transfer is circular by default.
-@- In Multi (Double) buffer mode, it is possible to update the base address for
the AHB memory port on the fly (DMA_SxM0AR or DMA_SxM1AR) when the stream is enabled.
-@- Multi (Double) buffer mode is possible with DMA and BDMA instances.Copyright (c) 2017 STMicroelectronics. All rights reserved.
