RTEMS 6.1
DCMI HAL module driver This file provides firmware functions to manage the following functionalities of the Digital Camera Interface (DCMI) peripheral: More...
#include "stm32h7xx_hal.h"DCMI HAL module driver This file provides firmware functions to manage the following functionalities of the Digital Camera Interface (DCMI) peripheral:
##### How to use this driver #####
The sequence below describes how to use this driver to capture image
from a camera module connected to the DCMI Interface.
This sequence does not take into account the configuration of the
camera module, which should be made before to configure and enable
the DCMI to capture images.
(#) Program the required configuration through following parameters:
horizontal and vertical polarity, pixel clock polarity, Capture Rate,
Synchronization Mode, code of the frame delimiter and data width
using HAL_DCMI_Init() function.
(#) Configure the selected DMA stream to transfer Data from DCMI DR
register to the destination memory buffer.
DCMI mode, destination memory Buffer address and the data length
and enable capture using HAL_DCMI_Start_DMA() function.
(#) Optionally, configure and Enable the CROP feature to select a rectangular
window from the received image using HAL_DCMI_ConfigCrop()
and HAL_DCMI_EnableCrop() functions
(#) The capture can be stopped using HAL_DCMI_Stop() function.
(#) To control DCMI state you can use the function HAL_DCMI_GetState().
*** Callback registration ***
The compilation flag USE_HAL_DCMI_REGISTER_CALLBACKS when set to 1
allows the user to configure dynamically the driver callbacks.
Use Functions HAL_DCMI_RegisterCallback() to register an interrupt callback.
Function HAL_DCMI_RegisterCallback() allows to register following callbacks:
(+) LineEventCallback : callback for DCMI line event.
(+) FrameEventCallback : callback for DCMI Frame event.
(+) VsyncEventCallback : callback for DCMI Vsync event.
(+) ErrorCallback : callback for error detection.
(+) MspInitCallback : callback for Msp Init.
(+) MspDeInitCallback : callback for Msp DeInit.
This function takes as parameters the HAL peripheral handle, the Callback ID
and a pointer to the user callback function.
Use function HAL_DCMI_UnRegisterCallback to reset a callback to the default weak function.
HAL_DCMI_UnRegisterCallback takes as parameters the HAL peripheral handle and the Callback ID.
This function allows to reset following callbacks:
By default, after the HAL_DCMI_Init() and when the state is HAL_DCMI_STATE_RESET
all callbacks are set to the corresponding weak functions:
examples HAL_DCMI_LineEventCallback(), HAL_DCMI_FrameEventCallback().
Exception done for MspInit and MspDeInit functions that are
reset to the legacy weak functions in the HAL_DCMI_Init()/ HAL_DCMI_DeInit() only when
these callbacks are null (not registered beforehand).
If MspInit or MspDeInit are not null, the HAL_DCMI_Init()/ HAL_DCMI_DeInit()
keep and use the user MspInit/MspDeInit callbacks (registered beforehand) whatever the state.
Callbacks can be registered/unregistered in HAL_DCMI_STATE_READY state only.
Exception done MspInit/MspDeInit functions that can be registered/unregistered
in HAL_DCMI_STATE_READY or HAL_DCMI_STATE_RESET state,
thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit.
In that case first register the MspInit/MspDeInit user callbacks
using HAL_DCMI_RegisterCallback() before calling HAL_DCMI_DeInit() or HAL_DCMI_Init() function.
When the compilation flag USE_HAL_DCMI_REGISTER_CALLBACKS is set to 0 or
not defined, the callback registration feature is not available and all callbacks
are set to the corresponding weak functions.
*** DCMI HAL driver macros list ***
Below the list of most used macros in DCMI HAL driver.
(+) __HAL_DCMI_ENABLE: Enable the DCMI peripheral.
(+) __HAL_DCMI_DISABLE: Disable the DCMI peripheral.
(+) __HAL_DCMI_GET_FLAG: Get the DCMI pending flags.
(+) __HAL_DCMI_CLEAR_FLAG: Clear the DCMI pending flags.
(+) __HAL_DCMI_ENABLE_IT: Enable the specified DCMI interrupts.
(+) __HAL_DCMI_DISABLE_IT: Disable the specified DCMI interrupts.
(+) __HAL_DCMI_GET_IT_SOURCE: Check whether the specified DCMI interrupt has occurred or not.
(@) You can refer to the DCMI HAL driver header file for more useful macros
