RTEMS 6.1
CEC HAL module driver. This file provides firmware functions to manage the following functionalities of the High Definition Multimedia Interface Consumer Electronics Control Peripheral (CEC). More...
#include "stm32h7xx_hal.h"CEC HAL module driver. This file provides firmware functions to manage the following functionalities of the High Definition Multimedia Interface Consumer Electronics Control Peripheral (CEC).
##### How to use this driver #####
The CEC HAL driver can be used as follow:
(#) Declare a CEC_HandleTypeDef handle structure.
(#) Initialize the CEC low level resources by implementing the HAL_CEC_MspInit ()API:
(##) Enable the CEC interface clock.
(##) CEC pins configuration:
(+++) Enable the clock for the CEC GPIOs.
(+++) Configure these CEC pins as alternate function pull-up.
(##) NVIC configuration if you need to use interrupt process (HAL_CEC_Transmit_IT()
and HAL_CEC_Receive_IT() APIs):
(+++) Configure the CEC interrupt priority.
(+++) Enable the NVIC CEC IRQ handle.
(+++) The specific CEC interrupts (Transmission complete interrupt,
RXNE interrupt and Error Interrupts) will be managed using the macros
__HAL_CEC_ENABLE_IT() and __HAL_CEC_DISABLE_IT() inside the transmit
and receive process.
(#) Program the Signal Free Time (SFT) and SFT option, Tolerance, reception stop in
in case of Bit Rising Error, Error-Bit generation conditions, device logical
address and Listen mode in the hcec Init structure.
(#) Initialize the CEC registers by calling the HAL_CEC_Init() API.
(@) This API (HAL_CEC_Init()) configures also the low level Hardware (GPIO, CLOCK, CORTEX...etc)
by calling the customed HAL_CEC_MspInit() API.
*** Callback registration ***
The compilation define USE_HAL_CEC_REGISTER_CALLBACKS when set to 1
allows the user to configure dynamically the driver callbacks.
Use Functions HAL_CEC_RegisterCallback() or HAL_CEC_RegisterXXXCallback()
to register an interrupt callback.
Function HAL_CEC_RegisterCallback() allows to register following callbacks:
(+) TxCpltCallback : Tx Transfer completed callback.
(+) ErrorCallback : callback for error detection.
(+) MspInitCallback : CEC MspInit.
(+) MspDeInitCallback : CEC MspDeInit.
This function takes as parameters the HAL peripheral handle, the Callback ID
and a pointer to the user callback function.
For specific callback HAL_CEC_RxCpltCallback use dedicated register callbacks
HAL_CEC_RegisterRxCpltCallback().
Use function HAL_CEC_UnRegisterCallback() to reset a callback to the default
weak function.
HAL_CEC_UnRegisterCallback() takes as parameters the HAL peripheral handle,
and the Callback ID.
This function allows to reset following callbacks:
For callback HAL_CEC_RxCpltCallback use dedicated unregister callback :
HAL_CEC_UnRegisterRxCpltCallback().
By default, after the HAL_CEC_Init() and when the state is HAL_CEC_STATE_RESET
all callbacks are set to the corresponding weak functions :
examples HAL_CEC_TxCpltCallback() , HAL_CEC_RxCpltCallback().
Exception done for MspInit and MspDeInit functions that are
reset to the legacy weak function in the HAL_CEC_Init()/ HAL_CEC_DeInit() only when
these callbacks are null (not registered beforehand).
if not, MspInit or MspDeInit are not null, the HAL_CEC_Init() / HAL_CEC_DeInit()
keep and use the user MspInit/MspDeInit functions (registered beforehand)
Callbacks can be registered/unregistered in HAL_CEC_STATE_READY state only.
Exception done MspInit/MspDeInit callbacks that can be registered/unregistered
in HAL_CEC_STATE_READY or HAL_CEC_STATE_RESET state,
thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit.
In that case first register the MspInit/MspDeInit user callbacks
using HAL_CEC_RegisterCallback() before calling HAL_CEC_DeInit()
or HAL_CEC_Init() function.
When the compilation define USE_HAL_CEC_REGISTER_CALLBACKS is set to 0 or
not defined, the callback registration feature is not available and all callbacks
are set to the corresponding weak functions.
