RTEMS 6.1
stm32h7xx_hal_adc.c File Reference
This file provides firmware functions to manage the following functionalities of the Analog to Digital Converter (ADC) peripheral: More...
#include "stm32h7xx_hal.h"
Author
MCD Application Team
  • Peripheral Control functions
  • Peripheral State functions Other functions (extended functions) are available in file "stm32h7xx_hal_adc_ex.c".
Attention
                   ##### ADC peripheral features #####
(+) 16-bit, 14-bit, 12-bit, 10-bit or 8-bit configurable resolution.
     Note: On devices STM32H72xx and STM32H73xx, these resolution are applicable to instances ADC1 and ADC2.
     ADC3 is featuring resolutions 12-bit, 10-bit, 8-bit, 6-bit.
(+) Interrupt generation at the end of regular conversion and in case of
    analog watchdog or overrun events.
(+) Single and continuous conversion modes.
(+) Scan mode for conversion of several channels sequentially.
(+) Data alignment with in-built data coherency.
(+) Programmable sampling time (channel wise)
(+) External trigger (timer or EXTI) with configurable polarity
(+) DMA request generation for transfer of conversions data of regular group.
(+) Configurable delay between conversions in Dual interleaved mode.
(+) ADC channels selectable single/differential input.
(+) ADC offset shared on 4 offset instances.
(+) ADC calibration
(+) ADC conversion of regular group.
(+) ADC supply requirements: 1.62 V to 3.6 V.
(+) ADC input range: from Vref- (connected to Vssa) to Vref+ (connected to
    Vdda or to an external voltage reference).
                   ##### How to use this driver #####
   *** Configuration of top level parameters related to ADC ***
  (#) Enable the ADC interface
      (++) As prerequisite, ADC clock must be configured at RCC top level.
      (++) Two clock settings are mandatory:
           (+++) ADC clock (core clock, also possibly conversion clock).
           (+++) ADC clock (conversions clock).
                 Two possible clock sources: synchronous clock derived from AHB clock
                 or asynchronous clock derived from system clock, the PLL2 or the PLL3 running up to 400MHz.
           (+++) Example:
                 Into HAL_ADC_MspInit() (recommended code location) or with
                 other device clock parameters configuration:
             (+++) __HAL_RCC_ADC_CLK_ENABLE();                  (mandatory)
             RCC_ADCCLKSOURCE_PLL2 enable:                   (optional: if asynchronous clock selected)
             (+++) RCC_PeriphClkInitTypeDef   RCC_PeriphClkInit;
             (+++) PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_ADC;
             (+++) PeriphClkInit.AdcClockSelection    = RCC_ADCCLKSOURCE_PLL2;
             (+++) HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit);
      (++) ADC clock source and clock prescaler are configured at ADC level with
           parameter "ClockPrescaler" using function HAL_ADC_Init().
  (#) ADC pins configuration
       (++) Enable the clock for the ADC GPIOs
            using macro __HAL_RCC_GPIOx_CLK_ENABLE()
       (++) Configure these ADC pins in analog mode
            using function HAL_GPIO_Init()
  (#) Optionally, in case of usage of ADC with interruptions:
       (++) Configure the NVIC for ADC
            using function HAL_NVIC_EnableIRQ(ADCx_IRQn)
       (++) Insert the ADC interruption handler function HAL_ADC_IRQHandler()
            into the function of corresponding ADC interruption vector
            ADCx_IRQHandler().
  (#) Optionally, in case of usage of DMA:
       (++) Configure the DMA (DMA channel, mode normal or circular, ...)
            using function HAL_DMA_Init().
       (++) Configure the NVIC for DMA
            using function HAL_NVIC_EnableIRQ(DMAx_Channelx_IRQn)
            into the function of corresponding DMA interruption vector
            DMAx_Channelx_IRQHandler().
   *** Configuration of ADC, group regular, channels parameters ***
  (#) Configure the ADC parameters (resolution, data alignment, ...)
      and regular group parameters (conversion trigger, sequencer, ...)
  (#) Configure the channels for regular group parameters (channel number,
      channel rank into sequencer, ..., into regular group)
      using function HAL_ADC_ConfigChannel().
  (#) Optionally, configure the analog watchdog parameters (channels
      monitored, thresholds, ...)
      using function HAL_ADC_AnalogWDGConfig().
   *** Execution of ADC conversions ***
  (#) Optionally, perform an automatic ADC calibration to improve the
      conversion accuracy
      using function HAL_ADCEx_Calibration_Start().
  (#) ADC driver can be used among three modes: polling, interruption,
      transfer by DMA.
      (++) ADC conversion by polling:
        (+++) Activate the ADC peripheral and start conversions
              using function HAL_ADC_Start()
        (+++) Wait for ADC conversion completion
              using function HAL_ADC_PollForConversion()
        (+++) Retrieve conversion results
              using function HAL_ADC_GetValue()
        (+++) Stop conversion and disable the ADC peripheral
              using function HAL_ADC_Stop()
      (++) ADC conversion by interruption:
              using function HAL_ADC_Start_IT()
        (+++) Wait for ADC conversion completion by call of function
              HAL_ADC_ConvCpltCallback()
              (this function must be implemented in user program)
              using function HAL_ADC_Stop_IT()
      (++) ADC conversion with transfer by DMA:
              using function HAL_ADC_Start_DMA()
              HAL_ADC_ConvCpltCallback() or HAL_ADC_ConvHalfCpltCallback()
              (these functions must be implemented in user program)
        (+++) Conversion results are automatically transferred by DMA into
              destination variable address.
              using function HAL_ADC_Stop_DMA()
  (@) Callback functions must be implemented in user program:
    (+@) HAL_ADC_ErrorCallback()
    (+@) HAL_ADC_LevelOutOfWindowCallback() (callback of analog watchdog)
    (+@) HAL_ADC_ConvCpltCallback()
    (+@) HAL_ADC_ConvHalfCpltCallback
   *** Deinitialization of ADC ***
  (#) Disable the ADC interface
    (++) ADC clock can be hard reset and disabled at RCC top level.
      (++) Hard reset of ADC peripherals
           using macro __HAL_RCC_ADCx_FORCE_RESET(), __HAL_RCC_ADCx_RELEASE_RESET().
      (++) ADC clock disable
           using the equivalent macro/functions as configuration step.
           (+++) Example:
                 Into HAL_ADC_MspDeInit() (recommended code location) or with
             (+++) __HAL_RCC_ADC_CLK_DISABLE();                  (if not used anymore)
             RCC_ADCCLKSOURCE_CLKP restore:                      (optional)
             (+++) PeriphClkInit.AdcClockSelection    = RCC_ADCCLKSOURCE_CLKP;
       (++) Disable the clock for the ADC GPIOs
            using macro __HAL_RCC_GPIOx_CLK_DISABLE()
       (++) Disable the NVIC for ADC
       (++) Deinitialize the DMA
       (++) Disable the NVIC for DMA
  *** Callback registration ***
   The compilation flag USE_HAL_ADC_REGISTER_CALLBACKS, when set to 1,
   allows the user to configure dynamically the driver callbacks.
   Use Functions HAL_ADC_RegisterCallback()
   to register an interrupt callback.
   Function HAL_ADC_RegisterCallback() allows to register following callbacks:
     (+) ConvCpltCallback               : ADC conversion complete callback
     (+) ConvHalfCpltCallback           : ADC conversion DMA half-transfer callback
     (+) LevelOutOfWindowCallback       : ADC analog watchdog 1 callback
     (+) ErrorCallback                  : ADC error callback
     (+) InjectedConvCpltCallback       : ADC group injected conversion complete callback
     (+) InjectedQueueOverflowCallback  : ADC group injected context queue overflow callback
     (+) LevelOutOfWindow2Callback      : ADC analog watchdog 2 callback
     (+) LevelOutOfWindow3Callback      : ADC analog watchdog 3 callback
     (+) EndOfSamplingCallback          : ADC end of sampling callback
     (+) MspInitCallback                : ADC Msp Init callback
     (+) MspDeInitCallback              : ADC Msp DeInit callback
   This function takes as parameters the HAL peripheral handle, the Callback ID
   and a pointer to the user callback function.
   Use function HAL_ADC_UnRegisterCallback to reset a callback to the default
   weak function.
   HAL_ADC_UnRegisterCallback takes as parameters the HAL peripheral handle,
   and the Callback ID.
   This function allows to reset following callbacks:
   By default, after the HAL_ADC_Init() and when the state is HAL_ADC_STATE_RESET
   all callbacks are set to the corresponding weak functions:
   examples HAL_ADC_ConvCpltCallback(), HAL_ADC_ErrorCallback().
   Exception done for MspInit and MspDeInit functions that are
   reset to the legacy weak functions in the HAL_ADC_Init()/ HAL_ADC_DeInit() only when
   these callbacks are null (not registered beforehand).
   If MspInit or MspDeInit are not null, the HAL_ADC_Init()/ HAL_ADC_DeInit()
   keep and use the user MspInit/MspDeInit callbacks (registered beforehand) whatever the state.
   Callbacks can be registered/unregistered in HAL_ADC_STATE_READY state only.
   Exception done MspInit/MspDeInit functions that can be registered/unregistered
   in HAL_ADC_STATE_READY or HAL_ADC_STATE_RESET state,
   thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit.
   Then, the user first registers the MspInit/MspDeInit user callbacks
   using HAL_ADC_RegisterCallback() before calling HAL_ADC_DeInit()
   or HAL_ADC_Init() function.
   When the compilation flag USE_HAL_ADC_REGISTER_CALLBACKS is set to 0 or
   not defined, the callback registration feature is not available and all callbacks
   are set to the corresponding weak functions.
