RTEMS 6.1
SOURCE: http://www.kryslix.com/nsfaq/Q.12.html
Subject: What protocol do mice use? Date: 09/16/97 Updated: 11/16/00 This document was adapated from a web page produced by Tomi Engdahl then@.nosp@m.delt.nosp@m.a.hut.nosp@m..fi Microsoft serial mouse Description
The Microsoft serial mouse is the most popular 2 button mouse. It is supported by all major operating systems. The maximum tracking rate for a Microsoft mouse is 40 reports/second * 127 counts per report, in other words, 5080 counts per second. The most common range for mice is is 100 to 400 CPI (counts per inch) but can be up to 1000 CPI. A 100CPI mouse can discriminate motion up to 50.8 inches/second while a 400 CPI mouse can only discriminate motion up to 12.7 inches/second. Pinout
RTS = Request to Send CTS = Clear to Send DSR = Data Set Ready DTR = Data Terminal Ready GND = Protective Ground SGND = Signal Ground
To function correctly, both the RTS and DTR lines must be positive. DTR/DSR and RTS/CTS must NOT be shorted. RTS may be toggled negative for at least 100ms to reset the mouse. (After a cold boot, the RTS line is usually negative. This provides an automatic toggle when RTS is brought positive). When DTR is toggled the mouse should send a single byte 0x45 (ASCII 'M').
Serial data parameters: 1200bps, 7 databits, 1 stop-bit
Data packet format:
Data is sent in 3 byte packets for each event (a button is pressed or released or the mouse moves):
LB is the state of the left button (1 means down) RB is the state of the right button (1 means down) X7-X0 movement in X direction since last packet (signed byte) Y7-Y0 movement in Y direction since last packet (signed byte)
The high order bit of each byte (D7) is ignored. Bit D6 indicates the start of an event, which allows the software to synchronize with the mouse.
Graphical representation of a packet
3 Button Logitech extension
Logitech extended the 2 button mouse protocol to support 3 button mice by adding a 4th byte when the middle button is pressed (and the first packet after it is released). If a 4th byte is encountered (i.e., an extra byte with D6 set to 0) then D5 of that byte (0x20) indicates the status of the middle mouse button.
Serial data parameters: 1200bps, 8 databits, 1 stop-bit
5 byte Mouse Systems packet
LB is left button state (0=pressed, 1=released) CB is center button state (0=pressed, 1=released) RB is right button state (0=pressed, 1=released) X7-X0 movement in X direction since last packet in signed byte format (-128..+127), positive direction right Y7-Y0 movement in Y direction since last packet in signed byte format (-128..+127), positive direction up X7'-X0' movement in X direction since sending of X7-X0 packet in signed byte format (-128..+127), positive direction right Y7'-Y0' movement in Y direction since sending of Y7-Y0 in signed byte format (-128..+127), positive direction up
The last two bytes in the packet (bytes 4 and 5) contain information about movement data changes which have occured after data bytes 2 and 3 have been sent.
PS/2 mouse
The standard PS/2 mouse (such as the Logitech mouse) defaults to 160 CPI and can be switched to 40, 80, 160 or 320 CPI via software. The Microsoft mouse driver for Windows 3.x and Windows 95 defaults to 160 counts per inch. The maximum tracking rate for PS/2 mouse is 40 reports/second * 255 counts per report, or 10200 counts per second. A 100 CPI mouse could discriminate motion up to 102 inches per second while a 400 CPI mouse could discriminate motion up to 25.2 inches per second.
The PS/2 mouse connector has the following pinout when looking at the connector on the back of the computer:
Bi-directional transmission is controlled by the CLK and DATA lines. Both are fed by an open collector device which lets either host or mouse force the line to "0". During non-transmission, CLK is at "1" and DATA can be at "0" or "1".
The host can inhibit mouse transmission by forcing CLK to "0". If the host inhibits the mouse while it is transmitting, the byte must be retransmitted (if the inhibit state arrived before the 11th clock).
Receiving data: Check 'clock'. If inactive, there is a bit on the 'data' line. Each transmission unit is one start bit, eight data bits, odd parity and one stop bit. Start bits are low, stop bits high. Each clock active or inactive period is 30 to 50 microseconds. Data transition to falling edge of clock is 5 to 25 microseconds.
Sending: Check that both clock and data are high. Pull down data for start bit, and start clocking.
NOTE: Logitech has made the extension to this protocol to allow three buttons (the M bit is always 0 on 2 button mice).
References
