RTEMS 6.1
cpuuse
This directory contains code to report and reset per-task CPU usage. If the BSP supports nanosecond timestamp granularity, this this information is very accurate. Otherwise, it is dependendent on the tick granularity.
It provides two primary features:
  • Generate a CPU Usage Report
  • Reset CPU Usage Information
NOTES:
  1. If configured for tick granularity, CPU usage is "docked" by a clock tick at each context switch.
  2. If configured for nanosecond granularity, no work is done at each clock tick. All bookkeeping is done as part of a context switch.
