RTEMS 6.1
usiii
BSP NAME: usiii
BOARD:
BUS: n/a
CPU FAMILY: SPARC V9 (a.k.a. sun4u)
CPU: UltraSPARC III
COPROCESSORS:
MODE: n/a
DEBUG MONITOR:
PERIPHERALS
TIMERS: TICK register (ASR 4)
RESOLUTION: CPU clock resolution
SERIAL PORTS:
REAL-TIME CLOCK:
DMA: none
VIDEO: none
SCSI: none
NETWORKING: none
DRIVER INFORMATION
CLOCK DRIVER:
IOSUPP DRIVER:
SHMSUPP:
TIMER DRIVER:
TTY DRIVER:
STDIO
PORT:
ELECTRICAL:
BAUD:
BITS PER CHARACTER:
PARITY:
STOP BITS:
Board description
clock rate:
bus width:
ROM:
RAM:
This BSP is designed to operate on the UltraSPARC III SPARC64 and similar processors.
This BSP has been run on the Simics simulator with the serengeti target.
Simics: A commercially available simulator licensed by Virtutech. https://www.simics.net/
