RTEMS 6.1
serial
This is the serial controller portion of the libchip library. This directory contains the source code for reusable console driver support code. Each individual driver is configured using the console_tbl data structure. This structure is defined and explained in the console.h file.
The reusable chip drivers do not directly access the serial controller. They access the registers on the controller via a set of up to four functions which are provided by the BSP. These functins set and get general registers and data buffers. Some chips can access the data buffers as general registers and thus the driver may not require those interface routines.
Status
  • Hardware flow control is not currently supported. Some of the chip drivers (in particular the z8530) have support for hardware flow control but this has not been tested in the libchip context. There will need to be a way to totally disabled hardware flow control which is not currently in this.
  • "ulClockSpeed" configuration item field to become a pointer to a table of chip specific information. For example, the z8530 should specify clock speed and clock divisor setting.
  • A termios structure should be included to specify the initial settings. Right now all drivers default to 9600, 8N1.
  • Need to switch to passing pointers rather than a minor number to functions which are strictly internal to each chip driver. This should be a performance win.
  • Need a test which prompts you for termios settings and tests them. Until this happens, testing for the variety of settings possible will be limited. This test should be able to test any serial port while prompts come to the console.
MC68681
  • Works interrupt and polled.
  • Hardware flow control not included.
NS16650
  • ns16550_set-attributes function is untested.
  • Hardware flow control included but is currently disabled in ISR.
Z85C30
  • Works polled and interrupt.
  • Needs to support mode where more specific vectors are generated.
Configuration Table Use
sDeviceName
The name of this device.
deviceType
This field must be SERIAL_MC68681.
pDeviceFns
The device interface control table. This may be:
  • mc68681_fns for interrupt driven IO
  • mc68681_fns_polled for polled IO
deviceProbe
This is the address of the routine which probes to see if the device is present.
pDeviceFlow
This field is ignored as hardware flow control is not currently supported.
ulMargin
This is currently unused.
ulHysteresis
pDeviceParams
This is set to the default settings.
ulCtrlPort1
This field is the base address of the entire DUART.
ulCtrlPort2
This field is the base address of the port specific registers.
ulDataPort
This field is bit mapped as follows: bit 0: baud rate set a or b bit 1-2: BRG selection ("Select Extend bit")
Note: If both ports on single DUART are not configured for the same baud rate set, then unexpected results will occur.
Note: On the Exar 88c681, if a standard clock of 3.6864 Mhz is used and the "Select Extend bit" is 0 (disabled), then the default MC68681 baud rate table is selected.
getRegister setRegister
These follow standard conventions.
getData setData
These are unused since the TX and RX data registers can be accessed as regular registers.
ulClock
This is a pointer to a baud rate mapping table. If set to mc68681_baud_rate_table, then the CSR/ACR/X bit mappings shown in the 68681 and 88681 manuals are used. Otherwise, the board specific baud rate mapping is used.
NULL is not a valid value.
ulIntVector
This is the interrupt vector number associated with this chip.
Status
There are no known problems with this driver.
sDeviceName
deviceType
This field must be SERIAL_NS16550.
pDeviceFns
  • ns16550_fns for interrupt driven IO
  • ns16550_fns_polled for polled IO
deviceProbe
pDeviceFlow
ulMargin
ulHysteresis
pDeviceParams
This is set to the default settings.  At this point, it is the default
baud rate cast as a (void *).
ulCtrlPort1
This field is the base address of this port on the UART.
ulCtrlPort2
This field is unused for the NS16550.
ulDataPort
getData setData
ulClock
This is the clock constant which is divided by the desired baud to get the value programmed into the part. The formula for this for 9600 baud is:
chip_divisor_value = ulClock / 9600.
NOTE: When ulClock is 0, the correct value for a PC (115,200) is used.
ulIntVector
xr88681
The Exar XR88681 is an enhanced version of the Motorola MC68681 and is supported by the mc68681 driver.
z85c30
sDeviceName
deviceType
This field must be SERIAL_Z85C30.
pDeviceFns
  • z85c30_fns for interrupt driven IO
  • z85c30_fns_polled for polled IO
deviceProbe
pDeviceFlow
This field is set to one of the following values:
  • NULL for no hardware flow control
  • z85c30_flow_RTSCTS for RTS/CTS based flow control
  • z85c30_flow_DTRCTS for DTR/CTS based flow control
ulMargin
ulHysteresis
pDeviceParams
ulCtrlPort1
This field is the address of the control register for this port.
ulCtrlPort2
This field is the address of the control register for chip.
ulDataPort
This field is the address of the data register for this port.
getData setData
ulClock
This is the clock speed of the baud rate clock. NULL, then the CSR/ACR/X bit mappings shown in the 68681 and 88681 manuals are used. Otherwise, the board specific baud rate mapping is used.
ulIntVector
