RTEMS 6.1
shsim
Simple BSP for the SH simulator built into gdb.
Simulator Invocation
sh-rtems[elf|]-gdb <executable>
(gdb) target sim
(gdb) set archi [sh|sh2]
(gdb) load <executable>
(gdb) run
Status
  • The simulator invocation procedure outlined above produces error messages with gdb-5.0, nevertheless seems to work. With gdb versions > 5.0 these error messages are gone. I.e. if you plan to seriously work with the gdb simulator better use gdb versions > 5.0.
  • gdb's simulator is not able to correctly emulate memory areas esp. shadowing and non-consecutive memory. I.e. access to memory areas besides area 0 will (bogusly) generate SIGBUS exceptions. This includes access to area 5 (On-chip peripherials) and prevents simulation of configuration and access to on-chip peripherials.
  • Due to limitations of the simulator you will only be able to run applications which do not try to access any SH control registers.
Currently, this excludes all applications, which apply timers and serial devices, i.e. almost any real world application.
  • This BSP supports 3 different console devices (cf. configure –help):
  • trap34, an interface base on gdb's trap34 emulation. Known to work with gdb-5.0.
  • gdbsci1, a stripped down sci device driver adapted to apply gdb's sci1 emulation. This is known to fail with gdb-5.0, because of a bug in gdb-5.0's sh-sim, a patch is submitted, but .. ~==
  • devnull, redirection of console io to /dev/null. Try to single step this, if you want to understand the details on how SH-RTEMS console redirection works.
NOTE: the trap34 interface is incomplete and is temporarily disabled inside of configure.in.
