RTEMS 6.1
tqm8xx
Summary
BSP NAME: tqm8xx
BOARD: various boards based on TQ Components TQM8xx modules
BUS: No backplane.
CPU FAMILY: PowerPC
CPU: PowerPC MPC860 or MPC866
COPROCESSORS: Built-in Motorola QUICC
MODE: 32 bit mode
BOOT MONITOR: TQMon
PERIPHERALS
TIMERS: PIT / Timebase
RESOLUTION: 1 microsecond / frequency = clock-speed / 16
SERIAL PORTS: 1-4 SCCs, 1-2 SMC
REAL-TIME CLOCK: <none>
DMA: Each SCC and SMC.
VIDEO: <none>
SCSI: <none>
NETWORKING: Ethernet 10 Mbps on SCC1 and/or
10/100Mbps on FEC (for MPC866T)
DRIVER INFORMATION
CLOCK DRIVER: yes
CONSOLE DRIVER: yes
SHMSUPP: N/A
TIMER DRIVER: yes
NETWORK DRIVER: yes
NOTES
On-chip resources:
SCC1 network or serial port
SCC2 serial port
SCC3 serial port
SCC4 serial port
SMC1 serial port
SMC2 serial port
CLK1 network
CLK2 network
CLK3
CLK4
CLK5
CLK6
CLK7
CLK8
BRG1 console
BRG2 console
BRG3 console
BRG4 console
RTC
PIT clock
TB
DEC
SWT
UPMA
UPMB
IRQ0
IRQ1
IRQ2
IRQ3
IRQ4
IRQ5
IRQ6
IRQ7
IRQ_LVL0
IRQ_LVL1
IRQ_LVL2
IRQ_LVL3
IRQ_LVL4
IRQ_LVL5
IRQ_LVL6
IRQ_LVL7
Board description
Clock rate: 50MHz - 133MHz.
Bus width: 32 bit Flash, 32 bit DRAM
FLASH: 2-8MB
RAM: 32-256MB SDRAM
Console driver
This BSP contains a console driver for polled and interrupt-driven operation. It supports SCCs and SMCs. During BSP configuration, various variables can be set to activate a certain channels and to specify the console channel:
CONS_SMC1_MODE, CONS_SMC2_MODE, CONS_SCC[1-4]_MODE can be set to CONS_MODE_UNUSED, CONS_MODE_POLLED or CONS_MODE_IRQ
The driver always uses termios.
Floating-point
The MPC8xx do not have floating-point units. All code should get compiled with the appropriate -mcpu flag. The nof variants of the gcc runtime libraries should be used for linking.
Miscellaneous
All development was based on the mbx8xx and gen68360 port.
Test Configuration
Board: pghplus
CPU: Motorola MPC866T
Clock Speed: 133MHz
RAM: 64MByte
Cache Configuration: Instruction cache on; data cache on, copyback mode.
