RTEMS 6.1
Intec SS555
The SS555 port was sponsored by Defence Research and Development Canada - Suffield, and is Copyright (C) 2004, Real-Time Systems Inc.
Please send any comments, improvements, or bug reports to:
David Querbach querb.nosp@m.ach@.nosp@m.realt.nosp@m.ime..nosp@m.bc.ca
Summary
BSP NAME: ss555
BOARD: Intec Automation Inc. SS555
BUS: None
CPU FAMILY: PowerPC
CPU: PowerPC MPC555
COPROCESSORS: Built-in Motorola TPU
MODE: 32 bit mode
DEBUG MONITOR: None
PERIPHERALS
TIMERS: PIT / Timebase
RESOLUTION: 1 microsecond (4 MHz crystal / 4)
SERIAL PORTS: 2 SCI
REAL-TIME CLOCK: On-chip.
DMA: None.
VIDEO: None.
SCSI: None.
NETWORKING: None.
DRIVER INFORMATION
CLOCK DRIVER: yes
CONSOLE DRIVER: yes
SHMSUPP: N/A
TIMER DRIVER: yes
NETWORK DRIVER: no
NOTES
On-chip resources:
SCI1 serial port
SCI2 serial port (console)
PIT clock
TB timing test support
DEC
SWT watchdog timer -- enable in startup/iss555.c
*CS0 external 512k 2-1-1-1 Burst SRAM
*CS1
*CS2
*CS3 CPLD
IRQ0
IRQ1
IRQ2
IRQ3
IRQ4
IRQ5
IRQ6
IRQ7
IRQ_LVL0
IRQ_LVL1
IRQ_LVL2
IRQ_LVL3
IRQ_LVL4
IRQ_LVL5 SCI
IRQ_LVL6 PIT
IRQ_LVL7
Board description
Clock rate: 40 MHz development/embeddable board
Bus width: 32-bit on-board RAM, 16-bit off-board I/O
FLASH: 512k on-chip
RAM: 512k 2-1-1-1 burst SRAM
Installation
The ss555 port uses the Intec SS555's external RAM in two different ways, depending on whether or not it is built for debugging by giving the VARIANT=DEBUG switch to make:
make VARIANT=DEBUG all
  1. In the debugging case, the linker script concanttenates the .text, .data, and .bss sections starting at location zero, so they all can be loaded into the external RAM for debugging. We assume that the debugger disables the internal Flash ROM and enables the external RAM before loading the code into the external RAM.
  2. In the normal (non-debugging) case, the linker script still places the .text section near zero, but places the start of the .data and .bss sections at the start location of the MPC555's internal RAM. The system startup code then configures the external RAM just after the internal RAM in memory, forming one large block from the two RAM devices.
Console driver
This BSP includes an termios-capable asynchronous serial line driver that supports SCI1 and SCI2. The RTEMS console is selected at configuration time with the CONSOLE_MINOR variable (see .../ss555/configure.ac). We default to SCI2 for the console, since SCI1 has some extra features which may be desired for application use.
The BSP console supports three different modes of operation:
  1. polled I/O done with termios support,
  2. polled I/O done without termios support,
  3. interrupt-driven I/O with termios support.
The mode of operation of the serial driver is determined at configure time in part by the value of the UARTS_IO_MODE variable (see .../ss555/configure.ac).
0 - polled I/O. 1 - interrupt-driven I/O.
Also, set the value of UARTS_USE_TERMIOS to select whether termios should be used to perform buffering and input/output processing. Without termios support, input processing is limited to the substitution of LF for a received CR, and output processing is limited to the transmission of a CR following the transmission of a LF. The choices for UARTS_USE_TERMIOS are:
0 - do not use termios 1 - use termios
In most real-time applications, the driver should be configured to use termios and interrupt-driven I/O. Special requirements may dictate otherwise.
Polled I/O must be used when running the timing tests. It must also be used to run some other tests and some samples, such as the cdtest. Some tests change the interrupt mask and will hang interrupt-driven I/O indefinitely. Others, such as cdtest, perform console output from the static constructors before the console is opened, causing the test to hang. Still other tests produce output that is supposed to be in some specific order. For these tests, termios should not be used, as termios buffers output and the transmission of the buffers occur at somewhat unpredictable times.
The real solution is to fix the tests so that they work with interrupt-driven I/O and termios.
printk() and debug output
The implementation of printk() in RTEMS is mostly independent of most system services. The printk() function can therefore be used to print messages to a debug console, particularly when debugging startup code or device drivers, i.e. code that runs before the console driver is opened or that runs with interrupts disabled.
Support is provided to send printk output to either port. Specify the desired port at configure time by setting the value of PRINTK_MINOR to one of SCI1_MINOR or SCI2_MINOR.
printk() always uses polled I/O, and never uses termios.
If the printk() port is opened by RTEMS, then UARTS_IO_MODE must be set for polled I/O, otherwise the I/O functions will be in conflict. Using printk() before the port is initialized is, of course, not possible. This initialization occurs in console_initialize(), which is called by rtems_initialize_executive_early().
Watchdog Timer
The MPC555 watchdog timer can be enabled at configuration time by defining the WATCHDOG_TIMEOUT variable. This variable sets the watchdog timeout period in steps of
  2048          2048
---------  =  ---------  =  51.2 usec
 Fsystem       40 MHz
or about 1/20 msec. When WATCHDOG_TIMEOUT is left undefined, the watchdog timer is disabled.
Miscellaneous
Most code came from the mbx8xx port, except for the floating-point handling which came from the mpc8260ads.
Host System
The port was developed on an x86 box running Debian 3.0. The toolchain was built from the sources at rtems.org, except for the autotools which came from the Debian distribution.
Test Configuration
Board: Intec SS555 v1.1
CPU: Motorola MPC555LFMZP40, mask 1K83H
Clock Speed: Crystal 4.0 MHz, CPU 40.0 MHz
RAM: 512K bytes of 2-1-1-1 Burst SRAM
Times Reported in: Microseconds
Timer Source: Timebase clock
GCC Flags: -O4 -fno-keep-inline-functions -mcpu=(821/860)
Console: Operates in polled mode on SMC2. No I/O through EPPC-Bug.
Test Results
Single processor tests:
All tests passed, except that:
  • sp09 aborts due to memory shortage
  • sp20 needs to be run with output buffering enabled (see buffer_test_io.h)
Multi-processor tests:
Not applicable.
Library tests: All tests passed. Note that the termios test only works if the system is rebuilt with termios enabled.
Posix tests: All tests passed, except that:
  • the message queue test failed with "errno (91 - File or path name too long)"
Timing tests: Due to memory limitations, many of the tests will not run unless you set OPERATION_COUNT=20 at configuration time.
To run tm27 (the interrupt latency timer test), short CN5-48 to CN5-50 on the SS555 board.
All tests run cleanly, except for tm26, which gives a "PANIC 12" after it exits. This doesn't seem to cause a problem otherwise.
See the times file for the results of the timing tests.
Network tests:
Not applicable.
Sample programs: These run correctly, except that:
  • The "minimum" sample is not designed to run properly on any system.
  • The loopback, fileio, unilimited, and pppd tests fail due to memory limitations.
  • The paranoia program dies on a floating-point assist exception.
Various non-BSP-dependent support routines.
timer - Support for the RTEMS timer tick, using the Programmable Interval Timer (PIT).
console-generic - Console support via the on-chip dual SCI port in the QSMCM module.
exception - Installation and deinstallation of exception handlers, by manipulation of exception vector table.
irq - Exception handler for all external and decrementer interrupts. Generalized interrupt handler which calls specific handlers via entries in the interrupt connection table. Interrupt connection table maintenance routines. USIU and UIMB interrupt masking and level control.
timer - Support for RTEMS timer tests, using the PowerPC timebase (TB) registers.
vectors - Compressed MPC5XX exception vector table, exception handler prologues, default exception handler. Code to initialize table with default handlers.
